SL/R231: Maintaining rubber door & other seals?
Old Feb 27, 2023 | 10:18 AM
Streamliner's Avatar
As my SL sits idle during this very unusual spell of very wet weather, I got to wondering about the numerous, rubber seals in the doors, roof, trunk, etc. Does anyone have a recommendation for a great product that will help keep the seals pliable & protected over the years? Thanks!
Old Feb 27, 2023 | 12:14 PM
chassis's Avatar
2017 GLE350 4MATIC
Gummi Pflege. Amazon photo from Germany (I’m in DE now). Available in the U.S.
Old Feb 27, 2023 | 12:51 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
There's some good info in the linked thread below.
MB makes a product too. PN is in that thread...
https://mbworld.org/forums/sl-class-...of-noises.html
Old Feb 27, 2023 | 02:35 PM
TennesseeZ4's Avatar
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
Been using Krytox on the seals of my cars for some time, very pleased with the results.
Old Feb 27, 2023 | 04:24 PM
rorywquin's Avatar
Shanks’s Pony
Krytox GPL105. Which is what MB sell. Expensive but lasts .
I used Gummi Pflege on my SLK (3 years)and had to refresh it frequently.
Purchased Krytox, and have not needed to redo the seals for 3years.
Be careful using it. A little goes a long way and it is impossible to remove (need a special solvent) if you get it where you do not want it.
It is recommended by the car manufacturers.
Old Feb 27, 2023 | 04:27 PM
rorywquin's Avatar
Shanks’s Pony
Beware of the “cheap" Krytox on Ebay.
If you are paying less than about £40 for a small bottle, it is not genuine. Get it from your local agents.
Old Feb 27, 2023 | 04:56 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Is this the same stuff, it's GPL205?
Amazon Amazon
On a side note: Is it true that it is best to keep the engine running when you have the top in a semi-open state in order to clean and lubricate all of the various rubber seals? I have heard or read that the top may close on its own if the engine is not kept running.
Old Feb 28, 2023 | 02:19 AM
rorywquin's Avatar
Shanks’s Pony
​​​​​​https://www.amazon.com/Krytox-Grease...82982874&psc=1
No mate. You need the GPL 105 it is clear and runny like baby oil. Comes in a little bottle with an applicator. I did all the rubbers on the SL (using my fingers) and my garage doors (rubber contact area was folding the rubber seal over) and still have 80% left. It goes a loong way.
I have some correspondence from the UK importer (I believe that it is a Dupont product) which I can forward to you if interested. Watch-out for the Ebay knock-offs.
It is a heavy roof. Some people make a prop (from an old broomhandle between the top of the wind screen and the roof to keep it open. MB used to sell a service tool for the job. Apparently keeping the engine running is a solution. I have not tried with the engine running (it does slowly fall closed without it running be careful).
Old Feb 28, 2023 | 10:06 AM
tbirdvet's Avatar
GLK350
Silicone spray/lube
Old Mar 2, 2023 | 10:38 AM
Thanks to all who responded.
