SL/R231: Update for MB Maps
Old Aug 27, 2023 | 10:00 AM
  #51
BenzNinja's Avatar
Former Vendor
Originally Posted by rmorin49
I believe V20 was released in 2019 so it's 4 years old but perhaps it is the latest that will work on my 2015.. My dealer updated my mapset in June 2019 when I bought the car.so I'm a bit confused as to what to do. I was hoping to get a version that would be current.
you are likely running V19 and for sure not 20
20 was released NOV 14 2019
Old Aug 27, 2023 | 10:30 AM
  #52
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Thanks. Do you envision a later version being released that will work on my 2015?
Old Aug 27, 2023 | 11:27 AM
  #53
BenzNinja's Avatar
Former Vendor
as you can see above, it looks like they are not in a hurry
Old Aug 27, 2023 | 11:33 AM
  #54
rmorin49's Avatar
Veteran: Army
Old Aug 27, 2023 | 12:02 PM
  #55
W205C43PFL's Avatar
Peter means that they are slow to release map updates, and from the screenshot he provided above, you can see the maps are at least one month old for newer COMAND systems, and two years old for NTG 5.2
Old Aug 27, 2023 | 12:15 PM
  #56
rmorin49's Avatar
Veteran: Army
Kinda makes sense that MB is slow to release for older models and perhaps won't release any newer mapsets. I guess I can always use my phone and Google maps if it becomes a big issue. If they haven't released a new mapset for my car since Nov 2019 that doesn't look good for the future.
Old Aug 27, 2023 | 12:59 PM
  #57
W205C43PFL's Avatar
It is usually preferred to use phone anyways, especially with smartphone integration, can use Google maps and Waze, the real time traffic and traffic reporting is pretty nice. That said, for here maps, if it is updated, they are pretty good. I usually prefer here maps over the aforementioned two, especially with the augmented reality feature plus it is better integrated, shows directions on the head-up display as well.
Old Dec 5, 2023 | 05:37 PM
  #58
docjoe's Avatar
SL400
yes a computer with windows
you get the software that runs on windows
make your usb
go with the usb thumb drive to your car and done
Windows PC only? I only have Apple Mac computers. Is your software compatible with Apple Mac? Thanks, Joe
Old Dec 5, 2023 | 06:03 PM
  #59
BenzNinja's Avatar
Former Vendor
yes unfortunately only pc
it's the official program free to all
Old Dec 5, 2023 | 06:12 PM
  #60
JettaRed's Avatar
Veteran: Army
No one should have only Macs. Get a decent Windows 10 laptop, refurbished from Amazon, for under $200. Windows has been trying to copy Macs for years, so the learning curve won't be too bad.
Amazon Amazon
Old Dec 7, 2023 | 02:48 PM
  #61
docjoe's Avatar
SL400
I am a newbie to Mercedes and this map updates discussion. I have read this thread closely and have some dumb questions.
My car (which is my first Mercedes - a 2015 SL400 - that I love to drive), has only one USB port, and that is in the center console. Is that the USB I would use to update my maps? I watched a YouTube video and it looked like the update thumb drive was being inserted into the head unit of the dash. Confusing.
I ask because on the head unit in my car there is a slot for a memory card, but no USB port, and that seems the most likely location to make changes via software updates to the the head unit, ie, map data.
Has anyone actually purchased a map update (on a USB thumb drive or memory card) from either BENZNINJA or MBNAVUPDATE.COM and successfully updated map data?
Lastly, it appears that my car is NTG 4.7, and the latest maps are actually 2019 data? That is already 4+ years old data. Ugh.
I don't want to attempt the RoadTop installation, although linking AppleMaps via my iPhone would be great. I lack the technical skill to do this myself.
Thanks for insights and suggestions on my questions above, and know that I have learned a great deal about my new toy from this group!!
Joe
Old Dec 7, 2023 | 03:24 PM
  #62
rmorin49's Avatar
Veteran: Army
I sent a PM.
Old Dec 7, 2023 | 06:22 PM
  #63
JettaRed's Avatar
Veteran: Army
Joe
1. Yes, I have updated my maps.
2. Yes, you use the USB port in the center console.
3. The latest is version is Version 20.0, dated 11/14/2019.
4. Have you read through the thread Step by Step CarPlay Install sticky at the top of this forum? It seems daunting, but you can probably do it.
Old Dec 8, 2023 | 09:03 AM
  #64
docjoe's Avatar
SL400
Thank you JettaRed.
And I appreciate your confidence in my ability to install electronic devices into complex circuitry and maybe I’ll give it a try. :-)
best regards
joe
Old Dec 8, 2023 | 11:33 AM
  #65
rmorin49's Avatar
Veteran: Army
Originally Posted by WN1X
The time required by the dealer is two minutes to plug in the thumb drive, enter the update code to start the update, and leaving the car running for the 20 minutes or so. I made a point of telling my service advisor and they just charged me for the software--no labor.
Is it mandatory to have the engine running during the entire update? I understand it can take up to 2 hours.
Old Dec 8, 2023 | 03:47 PM
  #66
JettaRed's Avatar
Veteran: Army
I can't say it took 2 hours, but I do remember having to start the engine and even drive around a bit for it to finish up.
Old Dec 8, 2023 | 05:55 PM
  #67
rmorin49's Avatar
Veteran: Army
Originally Posted by JettaRed
I can's say it took 2 hours, but I do remember having to start the engine and even drive around a bit for it to finish up.
I asked a seller on ebay and he replied that the engine does not have to be running but he recommended a battery tender to make sure the battery isn't depleted during the update.
I have my SL on a tender whenever it is parked in the garage. I need to confirm that the ignition can be turned on and kept on without someone sitting in the driver's seat for an extended time.
Old Dec 18, 2023 | 11:20 AM
  #68
rmorin49's Avatar
Veteran: Army
Success! I purchased the latest mapset(V20) from an ebay seller. It arrived in about 3 days on a USB stick with good directions. It took about 45 mintuest to install. I did have to restart one time. Ended up driving around as I was afraid to turn off the engine while it was installing and didn't feel like sitting in the car idling for a long time. Bottom line, it worked.
Old Dec 18, 2023 | 02:24 PM
  #69
docjoe's Avatar
SL400
Question
Please post details of the purchase - who, how much, etc. for the rest of us searchers.
And, what date or version did you get?
Thanks,
Docjoe
Old Dec 18, 2023 | 03:27 PM
  #70
rmorin49's Avatar
Veteran: Army
Thanks,
Docjoe
https://www.ebay.com/itm/12621078104...mis&media=COPY
Old Dec 18, 2023 | 03:34 PM
  #71
BenzNinja's Avatar
Former Vendor
Order your maps here:
https://benzninja.com/maps/
Old Dec 18, 2023 | 05:00 PM
  #72
Dr. Manhattan's Avatar
'17 SL450, '25 Lyriq, '25 Sonata Hybrid, '96 Corvette GS coupe
Assuming that I have to order the correct update for the specific model of NAV that's installed in my 2017 SL 450, how can I find out which model/version of firmware/hardware my car has? When I bought my car in 2020, the dealer had ostensibly updated the maps. From what I gather here, my maps may already be the latest version available. I'll have to check on this stuff...
Old Dec 18, 2023 | 07:10 PM
  #73
BenzNinja's Avatar
Former Vendor
Just send me a request with the form
Old Dec 28, 2023 | 12:19 PM
  #74
Haz1's Avatar
SL 550
I have a VISA dispute in with MBNAVUPDATE right now. Been in contact, said they'd send a USB when I couldn't get a Windows PC, then didn't, then said they'd refund, didn't, then said they credited back my credit card with the refund. Didn't. This has been going on two months. I'd avoid this one.
Old Dec 28, 2023 | 02:40 PM
  #75
Montreal300's Avatar
SL 550 (2014) Kia Sorento (2016)
Same here, I finally gave up.
