SL/R231: Trunk Partition and CPO
My dealer said the CPO won’t cover it. Says the part number is rejected. Will cost $1,100 to repair less the $300 he charges for the diagnostic. I called MBUSA and they said it will take them 1-2 days to decide whether to offer a courtesy repair.
The language in the CPO says Retractable Hardtop: Mechanical linkages, hydraulic unit, valves/solenoids, switches and sensors.
If a system, item, part or accessory is not listed in the section of this agreement entitled “What is Covered,” it is not covered by this agreement.
Do I have a leg to stand on if I litigate?
I would be kind, courteous, and grateful if they offer to do anything. Is the CPO extension cancelable? Many Extended Service Agreements are cancelable by law, depending on where you are. California? Who knows?
That said they should absolutely cover this, courtesy or not. Work with the dealer/Service manager.
They can easily get this covered for you…
Before getting a VSC, I actually talked to my Mercedes dealership's service manager about their experience with VSC companies and was told that both Endurance and Fidelity have good payment reputations based on the dealership's experience. They could not actually recommend a VSC and could not offer an extended warranty through Mercedes because of the age of my car. I have used Endurance once to cover a failed hydraulic line for the trunk. Endurance covered the repair (~$1000) and paid the dealership quickly. Since you have a little time, do some research with the local dealership or whatever shop you use and see what they say.
With regard to litigating, it's never as simple as people believe. It's much better to try to work things out without involving lawyers. (I think that's also Biblical.). Unless there is significant money at stake, it's often more expensive to litigate in terms of time, money, or both. In my state, there is no jury for a small claim, so you are relying on the judge to make a decision. If you don't like the decision, you may appeal it to a higher court, which becomes more expensive. And some states don't allow recovery of attorney fees, even if you win. My experience with courts is that (1) there are no guarantees, no matter how strong you think your case is, and (2) they should be avoided if possible. I personally don't consider $1100 to meet the threshold of litigation. As a matter of principle, it sucks that Mercedes is not covering this problem.
You can also go 3rd party as suggested but I recommend the factory extended warranty for a car coming off a lease it is still covered by factory warranty and because of the cash-out option.
