SL/R231: How reliable is the 2013-2016 SL550?
Old Jul 18, 2025 | 08:11 PM
mjr24's Avatar
M6 Gran Coupe
Specifically with the engine…..some have said it’s been problematic in other models?
Old Jul 18, 2025 | 09:43 PM
C280 Sport's Avatar
MB’s of all kinds.
R231 in general has been a solid car across the board. There are not many people reporting major issues like with the previous generation R230. Most R231’s never had ABC, so that alone takes away tons of potential failures. The V8 in the SL has been used across the MB lineup for many years. The engine is tried and true but does have some issues here and there. Cylinder scoring and coolant/oil leaks.
Old Jul 18, 2025 | 09:55 PM
chassis's Avatar
2017 GLE350 4MATIC
M278 is a time bomb waiting to explode in your wallet. Bore scoring is the biggest issue, there are several others.
Old Jul 19, 2025 | 02:02 AM
mjr24's Avatar
M6 Gran Coupe
Did they fix this issue on the 278 after 2015? I read they did....but not sure if that's true.
Old Jul 19, 2025 | 06:56 AM
chassis's Avatar
2017 GLE350 4MATIC
No one knows. Avoid all MB engines except M276 and M113 non-K.
Old Jul 19, 2025 | 08:50 AM
C280 Sport's Avatar
MB’s of all kinds.
This guy with the same rhetoric. There are plenty of M278 engines running around the world on MB’s across the lineup and not having major issues. Yea there have been some of them with major issues but a PPI can help avoid these major issues.
Old Jul 19, 2025 | 10:23 AM
RA1126's Avatar
My tech friends at the dealership told me years ago when I bought my 2013 SL550 that the R231 was probably the best car MB ever produced. They also indicated that the ABC suspension was modified with many changes from the R230 car and estimated 80k miles or more before any major issues. Of course any car can blow a hydraulic hose and anytime. Incidentally, I wouldn't touch a R231 without ABC suspension, it's what makes the whole car what it is. If you're searching for a 2013 to 2016 you should be able to find one with ABC if you desire. However, I bought a 2020 in April of 2024, which I consider a last year car, and took eighteen months to find. It was worth the wait, original MSRP was $136,110, has every option including ABC, Magic Sky, B&O Sound, a $4500 Designo leather interior package, soft close doors and more. ABC was optional for the SL550 and SL63, but was not an option for the SL65, it was built in the design of the car. Good luck on your search. Do look at a few, search for one with at least one of the major options. I post pictures to show the beauty of an SL550. We go through life once, buy the car, drive it and enjoy it.
Thor
Old Jul 19, 2025 | 10:38 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Online fear mongering is much more common than m278 engine failures.
Remember MB makes millions of engines world wide. These engines push the performance/efficiency envelope so MUST be maintained and fed proper fuel.
So we have reports of what? A dozen or two failures? How many people are happily running their M278’s and will never come to (or even know) an MB forum exists to complain? Most of these failures come from second hand owners, with unknown TRUE history, not just what’s on carfax.
Plenty of HIGH MILEAGE M278 litter the classified ads in Autotrader. Many with much more than 150k miles.
203k:
https://www.autotrader.com/cars-for-...ckType=listing
197k:
175k:
162k
There are many, many more listed! You can do a search nationwide, by highest mileage.
Forum member @Timo Schroeder has an early M278 with over 250k miles, I believe he’s original owner too.
Those that think the 2015+ M278’s are sleeved are sadly mistaken, MB just switched to iron to spray the cylinders instead of Silitec. Other manufacturers such as Ferrari have done this also in an effort to help prevent this type of failure. But, they still keep happening, as nothing will save an engine from detonation/pre-ignition damage. Even sleeved, engines just chew up the weakest part, which will now be the piston skirts made out of Aluminum.
As far as ABC goes that’s a personal choice. I’ve driven ALL the R231’s. ABC and non ABC, AMG etc.. . I worked for MB (and other MFG’ers ) as a tech, though before the R231 came out. Sure the R231’s ABC is more reliable than the R230, but as these cars age, parts availability will plague these systems. MB and other manufacturers are aggressively discontinuing parts at a much greater rate than seen ever before.
I used to flip cars when I was younger, but typically now keep my cars for over 20 years. So always look to K.I.S.S.
R231 will be the last SL I will probably own.
I’ve driven EVERY iteration of the R231, when properly tuned via tire pressure and tire compound, the non ABC car is less harsh than the AMG cars.
I would rate ride from softest to stiffest (not handling)
Non AMG SL with ABC - Non AMG SL with Springs and soft tires like Michelin Sports - Non AMG SL with Springs and run flats - SL63 non run flats - SL63 AMG run flats. Wheel size is also a factor, 18’s are softer than 19’s which are softer than 20’s. The larger the wheel the more critical tire choice and pressure becomes. It’s all a balance of what you’re looking for in a car. It’s nice to have options…
Good Luck.
Old Jul 19, 2025 | 12:39 PM
docjoe's Avatar
SL400
I have been told by many knowledgeable sources that the M276 (the SL 400) is bulletproof. It is the superior of the two engines, that is the M278 in the M 276. I've never had even a hint of a problem with my engine and yes, I am possibly bias in that I own an SL 400.
When the SL 400 was released, I believe back in 2013 or 2014, Car and Driver Magazine wrote an article on it based on their test, drive an inspection. They said it was the best handling and most spirited Mercedes they had ever driven. They really love that car. You can do an Internet search and find that very article it is still posted.
Old Jul 19, 2025 | 02:34 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
2015 Mercedes-Benz SL400 Test – Review – Car and Driver https://share.google/DtnteK2QfFzD0fgr1
Old Jul 19, 2025 | 03:53 PM
C280 Sport's Avatar
MB’s of all kinds.
203k:
197k:
175k:
162k
Good Luck.
100%. This is all true. Forums are also made up of many people who are paranoid to have any even small issues outside of warranty. This idea that MB engines all over are just blowing up is just silly! Reminds me of the IMS issue on 996’s. Mine was fine.
Old Jul 19, 2025 | 03:54 PM
C280 Sport's Avatar
MB’s of all kinds.
Love the SL400 for everything that it is. It’s a great balance and drives so well. Some people on the forum actually enjoy it more over the SL550. I am actually one of them.
Old Jul 19, 2025 | 03:59 PM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
The later "facelift" r230 (2009-2012) with the m273 is also a very safe choice. I looked at many over the years before I bought mine in 2020 and its been trouble free over the 5 seasons I have owned it. I follow these on BaT and other sites and its incredibly rare to see one with any major work having been done.
Best part is you don't have that butt ugly nose of the R231. They really screwed it up trying to meet the euro pedestrian impact regs imho.
Old Jul 19, 2025 | 04:03 PM
There really are no wrong answers here, It’s great to have choices.
No matter which iteration, you’re getting the last Vario Roof MB will probably make. They all drive fantastic! Like all things, it’s about your personal expectations. That’s why it’s nice to have choices .
Overall while still pretty complex, it’s still toned down tech wise to make the car fairly reliable for owners willing to keep them long term. Parts availability, for me, is always a problem for complex older cars (with low production numbers). It’s the little things that usually get you
For what it’s worth, My ‘13 SL550 (47k) has been easily as reliable as my R129 SL600 was, if not more so. Doesn’t even compare power wise.
So hopefully, long term R231 will continue it’s reliability. We’ll see…
If you’re just going to drive it for 5 years, pick the lowest mileage, best condition model you choose and enjoy. After some typical used car “fixes”. Chances are it will be a great car.
All great convertible’s, you’ll have lots of fun.
Let us know.
Old Jul 20, 2025 | 02:07 AM
mjr24's Avatar
M6 Gran Coupe
Good replies.....although after having a 215 CL and two of the 230 SL models, I was pretty convinced going into this that I want nothing to do with ABC anymore even if it's more reliable in the 231. I had nothing but issues with ABC in my 2000 CL500 with 10k miles (back in 2004) and then again on my 2004 SL55 I owned in 2011 (with like 50k miles).
I just feel if I'm going to keep the car for a long time (this would be just a fun third car) that I'd be wise to stay away from ABC.
Old Jul 20, 2025 | 02:12 AM
mjr24's Avatar
M6 Gran Coupe
Thor
Correct me if wrong, but I believe ABC is standard on the SL63 (which is why I was avoiding it)....
Old Jul 20, 2025 | 06:36 AM
docsout's Avatar
2023 S Class 2013 SL
"crconsulting", may I ask what sites you used to search for your car, for 15mos? I'm only familiar with carguru, and automax. Thanks.
Old Jul 20, 2025 | 09:23 AM
Those sites are good.
I personally use Autotrader too.(see link below) I ‘d take my time to find the right car locally. Not sure I looked 15 mo, but I looked for a while. I wasn't in a hurry and wanted to buy locally, so I could check them with XENTRY, on the cars I was interested in.
Run Carfax AND Autocheck. If you can get the VMI from MB that’s also worth looking at…
https://www.autotrader.com/cars-for-...2013&zip=94559
Good Luck
Old Jul 20, 2025 | 10:01 AM
Sadly some of my friends/customers left MB because they had so many issues with ABC and SBC on their early R230’s.
I skipped that model all together (R230)​​​​​​. But to be fair, the R231’s ABC is much improved over the R230’s, especially the early models. ADSII on the SL600 (R129) was OK, but parts availability started being an issue. Which is typical as these cars age. (I believe for the R231 parts availability may become worse). In the time I owned it, close to 20 years, I did the nitrogen spheres on all four corners three times (R129). Now that I’m older, I really don’t want to crawl under a car unless I have to.
Once you get the right tires and pressure combo the ride is excellent, The non ABC cars get a little more body roll, especially the V8, but it’s pretty mild. It’s a 4000lb Grand Tourer, not a race car. Problem with test driving cars, tire pressure, rubber age, heat cycles and tire compounds are out of your control. You can definitely feel old tires on larger diameter wheels. They are so much harsher.
Test drive a few models, see what you think. That’s what’s important….
Good Luck
Old Jul 20, 2025 | 11:09 PM
mjr24's Avatar
M6 Gran Coupe
Good Luck
So, in other words, it will feel/handle like a race car (even without ABC) given that my daily is a 6,000 pound BMW i7, LOL.
