SL/R231: AMG Brake caliper question.
Old Sep 7, 2025 | 03:44 PM
ryanholi0's Avatar
2x 2013 r231 SL550
So I acquired a second SL550 2013 and my first one had the 19" AMG wheels and the grey "Mercedes Benz" silk screened logo on them. Well this second SL550 I acquired has these hideous looking raw calipers and they are slightly smaller and had aftermarket 18" wheels on it. I have since got a hold of the AMG 5 spoke 19' wheels but I have to either paint the calipers or get some used, Larger calipers and front rotors as they look a little smaller too.
If you didn't order the car with the AMG wheel upgrade, did it come with raw finish calipers? Is the larger Calipers and rotors a direct bolt on if I find a set of used ones on eBay?
Thanks everyone.
Ryan
Old Sep 7, 2025 | 08:01 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Thanks everyone.
Ryan
Standard brakes for non-AMG cars - bead blasted/raw finish: front: 342mm x 32mm vented, 320mm x 24mm unvented
U28 Sport package for non-AMG engined cars - Painted with MB Text: front: 360mm x 36mm vented, 320mm x 24mm vented
B06 Standard for AMG cars : front: 390mm x 36mm vented, 360mm x 26mm vented
B07 Carbon-Ceramic for AMG cars : front: 402mm x 39mm carbon, 360mm x 32mm carbon
All brakes packages for the R231 are pretty much bolt on and interchangeable.
Good Luck
B06 AMG Brakes and 471 AMG LSD installed!
Old Sep 7, 2025 | 08:43 PM
ryanholi0's Avatar
2x 2013 r231 SL550
Thanks so much!
So what did the standard 18" rims look like on the 2013 and up? I don't think I have ever seen a pic of one with the non AMG wheels.
Old Sep 7, 2025 | 09:03 PM
see below
Old Sep 7, 2025 | 10:06 PM
ryanholi0's Avatar
2x 2013 r231 SL550
Those AMG 6 pistons look really good on there! Love it!
I have one quick question. So I just now bought the U28 painted calipers on ebay and got an excellent deal. Will I be able to use the 342mm x 32mm rotors that are on it now or do I need to get the 360x36 rotors as well?
Thanks so much for your advice!
Ryan
Old Sep 7, 2025 | 10:43 PM
You’ll need the matching rotors…
Old Sep 8, 2025 | 09:33 PM
ryanholi0's Avatar
2x 2013 r231 SL550
Was able to pickup a nice set of used U28 Painted front calipers for less than what the Brembo 360mm Rotors cost me!
I wonder if it is possible to put the old calipers and rotors from the front on to the rear!
Old Sep 9, 2025 | 04:36 PM
toolguy4u's Avatar
Veteran: Army
2015 sl550 Designo
No but the sport rear, which are drilled are the exact dimensions as the standard non drilled rotore, , about $30 more from Rock Auto.
Order them and you'll end up with drilled rotor front and rear. .
