SL/R232: Dramatic fan level 7
It would be very welcome if there was a level 6.5 to split the difference. I wonder if there could be an easy software fix to recalibrate those speeds, versus it being purely mechanical so not easily changed.
Just passing 16,000 miles and still loving the car so this is a pretty minor issue relatively.
Also 16k miles on the odometer is impressive. I’m approaching 2k.
An easy fix could be to manually adjust the airvents. As you twist them, you can have them all the way to close. That could set your 6.5 If you put all of the driver side ones to 50-70%
However, I did have an issue in a recent new C300 loaner. Somehow the AC wasn't actually in Auto even though on the screen it showed Auto. I hate the new touchscreen UI. Just doesn't work right and is a pain to operate while driving. Don't remember what I did, but it eventually started to work correctly. At first it wasn't cooling as it should and I noticed the interior warming up, but after punching Auto for a few times it eventually seemed to start working correctly. Maybe your AC isn't actually working correctly as it should.
