SL-Class (R232) Discussion on the 2022 R232
SL/R232: LOT OF ERRORS
Old Feb 17, 2024 | 05:18 PM
Greggds's Avatar
SL43 AMG, LAND ROVER DEFENDER
Exclamation LOT OF ERRORS
Driving today in NYC in the cold/damp. No snow falling. Car was working well then parked via park assist. When started up again got a lot of errors. Tried restarting but to no avail. Perhaps sensors need to dry? Absurd....
Less than 3600 miles. will be 3-4 times going to shop to be fixed for different issues.
Old Feb 18, 2024 | 01:45 PM
Raulr's Avatar
SL63AMG
It happens when the car is dirty. It’s gonna happen on any car when the sensors are covered with dirt. Just wipe de sensors clean and start up the car again.
Old Feb 18, 2024 | 01:53 PM
Greggds's Avatar
thanks! yeah - tried that but bigger issue. check engine light is also on.
Old Feb 19, 2024 | 12:19 AM
Raulr's Avatar
SL63AMG
Sorry to hear that. Let us know what was it when you find out from the dealer. My brother had a broken injector on his month old S63 e-performance. The dealer fixed it quickly, all is good now. I am wondering what issues the SL gets, I got nothing on mine, one year all good. Only upgrades/software updates. Oh, and a cracking noise that was some bearing at front left tire that they changed right away. That was actually the only issue, first month of ownership.
Old Feb 20, 2024 | 12:29 PM
SoCalAl's Avatar
MB SL43
Picked up SL43 3 days ago and drove from San Francisco to Los Angeles. 400 miles on the car and check engine light is on. Car drives fine. Keep me posted as to what you find out with your car, and I'll update you with my news. Thanks
Old Feb 20, 2024 | 04:21 PM
philenan78's Avatar
2025 AMG GT55, 2023 AMG SL43, 2023 GLS 450
I picked up my SL43 two weeks ago and check engine light came on immediately as well. I'm bringing it in Monday but fingers crossed it's nothing major. My past experiences with MB check engine lights have always resulted in a quick fix or nothing actually wrong.
Old Feb 20, 2024 | 06:11 PM
Raulr's Avatar
SL63AMG
Maybe it s a feature in the MB Store. You pay something like 200$ and they remove it.
That s how I got my recording working for the front camera.
Old Feb 20, 2024 | 10:35 PM
khiroshima's Avatar
2023 SL63 + 2021 Cayenne e-hybrid
My Aston used to do the same when the battery was "old", I wonder if this is a similar problem, we are all familiar with the battery drain issues . . . Good luck, KH
Old Feb 22, 2024 | 02:25 AM
SoCalAl's Avatar
MB SL43
I took the SL 43 to the dealer today. They told me that they need to replace the thermostat. It will take a week because they will need to bleed the system at regular intervals. I truly hope that this will be the only issue and that they can fix it for good.
Old Feb 22, 2024 | 10:57 PM
SoCalAl's Avatar
MB SL43
Correcting myself, They are NOT replacing the thermostat. They are only going to bleed the system. Service advisor says they see a lot of this issue in AMG SLs.
Old Feb 23, 2024 | 10:44 AM
Mike P's Avatar
SL65(R231), SL65(R230), 600SL, 560SL(86), 560SL(89),250SL(68),250SL(67), 190SL, 300SL(GW)
The dealer is claiming it takes a week for a coolant bleed??? Is this another example of over complicating the simple???? Any guesses on the cost of a coolant change??? It takes about 30 minutes( including breaks) change a 560SL coolant.
Old Feb 23, 2024 | 10:59 AM
SoCalAl's Avatar
MB SL43
They claimed they can't even start bleeding it until they get the go ahead from Germany, which apparently takes several days. So they will start on Monday. They also stated that the bleeding needs to be done in stages. The madness.....
Old Feb 24, 2024 | 07:46 PM
Greggds's Avatar
update
drove today and all errors/check engine are done! i cancelled my service appt. TBD....
Old Mar 7, 2024 | 03:26 PM
SoCalAl's Avatar
MB SL43
So my car has been in the dealership for 2 weeks now. They found dirt in the coolant. They are replacing the entire radiator system. Apparently it's a common issue that they've encountered. Hope this will be it!!!
Old Mar 7, 2024 | 03:57 PM
philenan78's Avatar
Fingers crossed that fixes it. I got my SL43 back Monday after a week in the shop. Was just a faulty exhaust value that was staying open and causing the check engine light to stay on, they replaced the hose and valve and everything is working fine now.
Old Apr 30, 2024 | 08:20 AM
AndreiM's Avatar
SL43AMG / sep 2022
Hello - @SoCaIAI - I have a similar issue with my SL 43 AMG - is everything ok now with your car?
Old Apr 9, 2025 | 04:43 PM
timcpark's Avatar
2023 AMG SL43
Check engine light came on yesterday, and I brought the car in to the dealer. I did not notice any vibration or driving issue other than check engine light is on. The service advisor told me he needs to keep the car more than a week to replace the whole coolant system. The car has less than 7000 miles on it. I wonder how much it would cost if my car did not have the warranty.
Old Apr 9, 2025 | 04:47 PM
W205C43PFL's Avatar
Very likely just a software issue.
Old Apr 12, 2025 | 11:25 AM
Streamliner's Avatar
Really? Dirt in the cooling system and replacing the radiator system is a “common issue?” If so, some folks in Germany need to be fired. And, how MUCH dirt are we talking about? I’ve never heard of such an issue with a new car, let alone one from MB. Crazy!
Old Apr 12, 2025 | 01:19 PM
W205C43PFL's Avatar
Oops please ignore this quote, apparently this quoted the wrong thread.
Old Apr 12, 2025 | 01:21 PM
W205C43PFL's Avatar
Is it the molding sand?
Old Apr 12, 2025 | 01:22 PM
W205C43PFL's Avatar
If it is the SL 43, then it is possible it is the molding sand: https://www.reddit.com/r/AMG/comment..._molding_sand/
Old Apr 12, 2025 | 01:23 PM
W205C43PFL's Avatar
I see, so OP does have the 43 version of the R232 SL, it is possible it is the molding sand as mentioned. It was reported on the W206 C 43, with the same engine.
Old Apr 17, 2025 | 07:11 PM
timcpark's Avatar
2023 AMG SL43
Heard back from the MB service advisor. They flushed the system many times, and still finding dirt from coolant. Escalated to MB corporate about next steps, and they are waiting for responses from MB. Told me it may take about 2-3 weeks. My SL has less than 7000 miles on it. Dealer told me to file a case against MB. Called MB customer service and gave all information. Case was created and MB customer executive will call within 3 business days. I want to find out what options I have. I am not enjoying this at all thinking how much money was spent on buying this car.
Old Apr 18, 2025 | 07:31 AM
W205C43PFL's Avatar
Sorry to hear that, did they confirm such dirt was the molding sand?
