SL/R107: 7" Screen Android Radio Installed in R107 560SL
As far as installation goes. It's about as easy as it can possibly get. These cars are old, so the wiring is not complex at all. You just hook up the power and ground wires, and then the positive and negative front left and right speaker wires and that's it since there are no rear speakers or amps etc. Not only that, but the wire colors match because they're universal. Just match up the colors and connect.
The only other thing to do is place the wifi and GPS antennas behind the radio, and that is also incredibly simple because there's a ton of space behind the radio and glove box to secure them down.
https://www.joyingauto.com/joying-la...4g-module.html
If they link is no good, they recommend the "Joying Latest 7 Inch Single Din 4GB+64GB Android 8.1.0 Car Media Player With Built-In 4G Module".
Hope this helps.
I guess this is the only guide to use to match the position of the 560SL harness wires currently soldered to the Becker socket to pair them with the ISO equivalent since they do not match in color. Anyone has a lead? Thanks
Question for the group - I have 1972 US version. 350SL. I believe I have a standard raise and lower by hand antenna. I thought I read somewhere that if I buy a power antenna, all I need to do is plug up the connection as power is already in place and ready for conversion to a powe antenna - turn on radio it goes uo, turn off it goes down. Does anyone know? Have experience with that?
