SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: URGENT HELP - 380 SL FRONT SUBRAME BROKE
Old Apr 13, 2020 | 10:15 PM
FBolanos's Avatar
87 560SL
I am asking for your expertise help to identify by the pictures what part of the front frame has broken down in my 82' 380 SL just arriving home tonight. Can anyone help by looking at the picture to identify what part has broken down to find it? Thanks so much for your help.
Old Apr 13, 2020 | 11:18 PM
TheShadow619's Avatar
1981 380SL
My '81 happens to be up on ramps right now. Looks like the rear of the lower A-arm(control arm) mount broke off the frame. Don't drive it! You may be able to carefully put it on a trailer or tow truck if needed. Best is to jack it up where it sits and have someone with a mobile welder fix it, or weld it yourself if you can.
Old Apr 13, 2020 | 11:57 PM
FBolanos's Avatar
87 560SL
so it looks like a similar situation,:I do have planned to have it lifted with a towing truck and delivered to my repair shop nearby, but I wasn’t sure if this was a broken standalone part or component Or like you are pointing, it is a welding job .
Old Apr 14, 2020 | 01:13 PM
myway's Avatar
450SL
Subframe failure. It is not a welding situation. Start here. https://www.benzworld.org/threads/c-...ation.1450267/
Old Apr 15, 2020 | 11:56 PM
1981 380SL
Great article and pictures. I can't find that the kit is still available anywhere. Do you have a source or is it a build-your-own thing now?
Old Apr 16, 2020 | 11:25 AM
myway's Avatar
450SL
Check with your dealer. The gussets may be available again. If not I guess you could make your own. Find an '86-'89 subframe or a reinforced earlier model.
Old Apr 16, 2020 | 11:37 AM
Ireti's Avatar
2018 Mercedes benz
URGENT HELP... Power steering of 2018 Mercedes Benz c300 coupe!!!
My 2018 Mercedes Benz c300 coupe has a power steering malfunctioning.. steering is super hard and I can’t drive it. Anybody with any idea please help...
Old Apr 16, 2020 | 11:41 AM
myway's Avatar
450SL
Wrong forum. This forum deals with R/C107 models. 1971-1989.
