SL55/63/65/R230 AMG: AIRMATIC Problem?
Old Feb 7, 2006 | 10:25 AM
55User's Avatar
An Affalterbach Beast & Others
AIRMATIC Problem?
The driver's side seems to slowly sink lower everyday it isn't driven ('04 SL55 8K), I came home yesterday and the whole left side was about two inches lower than the right side, I started the car, raised it up with AIRMATIC, then put it at the lowest level. Today it is where it is supposed to be. Just curious if I was alone, I thought I had read about it at one time, but I couldn't find any information while scrolling the the archives on the forum. Any help would be appreciated.
Old Feb 13, 2006 | 04:09 PM
X-Ricer's Avatar
too many cars
same thing
i have an 03 SL55 and have noticed this just once in a while. It's REALLY bad on my friend's 03 SL55. If he lets it sit for more than 1/2 hour, bam! Slammed to the ground on the driver side. This used to happen in my S600 as well, although it was the passanger rear.
dunno about any fixes...
Old Feb 13, 2006 | 04:47 PM
sprins's Avatar
G55, SLS, smart eq
No error messages in the display? My '03 SL55 throws an "ABC! Visit Workshop" malfunction in my face every other day since a couple of weeks when I start the car. But when I stop/start the car the error is gone (reboot?). I'll take it to the workshop soon as per display advice.
Old Feb 13, 2006 | 04:52 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
You don't have AIRMATIC you have ABC.
Your problem is a leaking valve, most likely in the front valve block, that is letting the fluid out of the strut and lowering that corner of the vehicle.
Old Feb 14, 2006 | 04:32 PM
AAG's Avatar
AAG
SL55 AMG
Let's hope it isn't your shocks
Just had to change the rear two shocks on my SL55 (03)... cost me Euro 4000... that is after I managed to get a discount from MB on the parts. Good luck
Old Jun 7, 2007 | 06:23 AM
Chris-W's Avatar
sl55 AMG
I get the same ..
"ABC! visit workshop" but dont have any of the problems with the car sinking at all stays upright.. Im praying its just a sensor or something cheap!
C.
Old Jun 7, 2007 | 11:33 AM
sprins's Avatar
G55, SLS, smart eq
Originally Posted by Chris-W
I get the same ..
In my case it was indeed a sensor... Inside the ABC strut. $1.500 lighter and the error was gone :-/
Old Jun 7, 2007 | 04:32 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
+1
Old Jun 7, 2007 | 05:18 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
I had the same leaky valve or whatever on the left front. When I started the car it raised back up. Dealer replaced system under warranty.
Old Jun 7, 2007 | 05:25 PM
Anthony 98 GTS's Avatar
SL55, 996TT, Viper 700R, H2
I just had my right rear shock replaced by Sunil. Problem solved.
Old Jun 7, 2007 | 06:38 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
+2
Old Jun 8, 2007 | 06:03 AM
Chris-W's Avatar
sl55 AMG
Ouch..
Well thanks for the update, I went to Mercedes London wiht the problem and they told me I needes a new ABC pump and the unit and install was going to cost me £2200!
Ive since then found a merc specialits who burst out laughing when I told hime and said mercedes were flat out lying because if the ABC pump went then the power steering would go on my sl55. He is sure its a computer problem and is looking at the car for me today.
Im having a little pray!
