SL55/63/65/R230 AMG: USA import numbers...
Old 03-27-2006, 12:10 PM
david_101's Avatar
2005 SL65
would anyone happen to have a rough idea of the yearly USA import numbers for the SL55 and SL65?
Old 03-27-2006, 02:11 PM
david_101's Avatar
2005 SL65
My2007...
and does anyone have a fairly reliable introduction date for MY2007 SLs?
Old 04-02-2006, 01:54 PM
david_101's Avatar
2005 SL65
My2007 Sl65...
does anybody know if there are changes anticipated, other than those for the entire SL range?
Old 04-02-2006, 04:52 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Nobody knows nothin'
Old 04-02-2006, 05:04 PM
sprins's Avatar
CLK63BS, SL55, G55, C43
I do! For the AMGs minimal power increasements are announced from 500hp to 517hp for the SL55 and the SL65 has a similar 'token' increasement. Other than that I believe the under the hood technical enhancements of the entire line (like ABC) will be incorporated. And new rims for the SL55.
Old 04-02-2006, 06:00 PM
david_101's Avatar
2005 SL65
sprins...
i'd previously thought the 65s already had improved ABC. thanks for enlightening me.
regarding the power increases, do you know if the 6.0 L engines are getting the additional valve/cylinder?
Old 04-02-2006, 06:07 PM
sprins's Avatar
Could be that the 65 keeps the ABC it had, the 55 definitely gets an ABC update (according to the press-release). Check here for some links: https://mbworld.org/forums/showpost....02&postcount=4
Nope. Same engines. They fiddled with the engine management and perhaps something about the air intake, but other than that the AMGs keep the same engines.
Old 04-02-2006, 06:25 PM
david_101's Avatar
2005 SL65
65 or 55 or wait or what...
i keep waffling between a preowned 55 and 65, and when to get it. or should i wait for the new models to arrive, then take advantage of likely price declines for the preowned cars.
there was a 2500 mile starmarked SL 65 down at mb miami with a 140k ask. i thought that wasn't unreasonable. as long as the MY7 65 is substantially the same as previous 65s, i think it'd be sensible to wait just a while longer.
what do you think?
Old 04-02-2006, 07:47 PM
prsmith777's Avatar
06 Infiniti FX35, 07 SL55
Here's a recent article about the SL55 AMG Facelift. Lots of info here.
http://www.emercedesbenz.com/Feb06/1...esSL55AMG.html
Old 04-02-2006, 09:41 PM
Juice it's Avatar
Bentley Arnage Red Label
what do you think?
I would say make a deal on that and you can't go wrong. I may be a bit biased but the car is unbelievable. At that price you are close to a new 55 and at only 2500 miles the car is still new. Just my opinion.
Old 04-02-2006, 11:01 PM
david_101's Avatar
2005 SL65
Juice it...
opinions are just what i was soliciting. thank you.
but do you think it'd be wise to wait another couple of months and probably be rewarded with another 10k+ discount?
Old 04-03-2006, 02:02 PM
Juice it's Avatar
I doubt it. You are coming into prime convert season on the east coast and I already see inventory shrinking a bit as the weather turns. Go play hardball and see what number you can get. You can always walk away but you will know where they stand. For a couple grand it isn't worth losing the summer.
Old 04-03-2006, 02:10 PM
david_101's Avatar
2005 SL65
Juice it...
yes, inventory has begun to shrink a bit, but only after swelling significantly.
nevertheless, you're right about the season.
thanks.
Quick Reply: SL55/63/65/R230 AMG: USA import numbers...
