SL55/63/65/R230 AMG: Glove box stuck shut on SL55
Old Jul 6, 2006 | 12:26 PM
SL Boy's Avatar
My SL55s glovebox lid refuses to lower/open when the open button is depressed. I have tried turning the emergency key in the glovebox lock and the locking mechanism definitely opens and closes so that's not the problem.
The lid seems to lower very slightly on the right side (nearest the lock) when the open button is depressed but thats as far as it will go.
Any ideas gratefully received.
Old Jul 6, 2006 | 12:49 PM
55User's Avatar
An Affalterbach Beast & Others
LOL, sorry, I don't mean to laugh but that brings back some frustrating memories. You should try to press and hold in the button, and pull down on the top lip of the glove box and it should pop out with some force, I had that problem and then just took it in and they fixed it under warranty. It needed a new latch I believe.
Old Jul 6, 2006 | 02:20 PM
seattlecarfreak's Avatar
eh not a big deal..
I just superglued mine shut.. after having a porsche 996 without one.. don't miss it much.. :> after someone broke into it with a screwdriver, paying $1000 to fix it, only for it to hapen again when i left the top down = no thanks.. not gonna deal with it..
Old Jul 6, 2006 | 03:03 PM
elbowyeish's Avatar
SL55 AMG Black on Berry Red
Being Serviced as we Speak
My SL55 has the EXACT same problem. It's being serviced as we speak under warranty. I think they're just changing out the latch. Take it in to your local dealer and have them fix it.
Old Jul 6, 2006 | 03:45 PM
Scruffyone's Avatar
SL55, ML500, GT3 RS, 997C2S
Mine did not do taht last year, but does it this year. Hold the button in and put the smack down on the front edge. Could be just the plastic sticking together. Same thing happens on the ML.
Old Jul 6, 2006 | 09:22 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Have the dealer adjust it..............it takes 5 minutes.
Old Jul 7, 2006 | 12:36 AM
joec1101's Avatar
'09 E93 335i
Mine was stuck shut as well - simple adjustment by the dealer fixed the problem. Let the dealer handle it so you don't get frustrated
Old Jul 7, 2006 | 01:34 PM
SL Boy's Avatar
Thanks for the advice everyone - will take to dealer tomorrow.
Old Jul 8, 2006 | 05:29 PM
SL Boy's Avatar
thanks for your input guys. Took it in to local dealer today and they removed the trim on the side of the glovebox adjacent to the nearside door and inserted a long, thin blade screwdriver into a channel at the top of the box to tweak the release catch which then sprung the lid open. They think something in the box, possibly a small hand towel, fouled the catch and stopped the release mechanism from working.
Needless to say they have seen this problem before. Not exactly a design fault but care is clearly needed to make sure the box is not overfilled.
Old Mar 14, 2018 | 03:38 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Easiest fix for stuck glovebox door.
Hi all,
The subject in this ancient thread still haunts newbies like me. I saw a fix on YouTube that seems to be overlooked. Once you have wrestled the glovebox open, there’s two black adjustable li’l bumpers in de dash. They’re obviously supposed to prevent the glovebox door from rattling. In my newly acquired car the door was stuck rock solid. Once opened and after some clockwise adjustment (philips screwdriver) of the bumpers it works just fine. (Did some fine tuning with the thumb wheel afterwards, but could have done without that).
Old Mar 14, 2018 | 03:56 PM
FxFormat's Avatar
SL 600
Same here, glove box stuck. I can't even get it open, watch there's a couple kilos of uncut cocaine in there.
Old Mar 14, 2018 | 03:57 PM
FxFormat's Avatar
SL 600
Ash tray also broken, i can't get the lid out.
Old Mar 14, 2018 | 04:15 PM
57staff's Avatar
2008 CL550
My ash tray lid seems to be intermittent. Sometimes it works, sometimes it doesn't.
Old Apr 27, 2020 | 07:52 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
My glove box was stuck closed for a couple of years. Found the directions to open it on benzworld. First take the end panel of the dash off. Comes of very easy with a trim tool. Then with a flash light look in side the opening. You will see a white gear about 8 or 9 inches in. It is the adjustment wheel. Push on it a few clicks with a long flat blade screw driver. Then try to open the glove box. Mine took about three clicks. The white wheel is an adjustment for the cable that opens the lock. It is like the adjustment of the brake cables on a bike. Hope this helps.
