SL55/63/65/R230 AMG: Any delimiter driver here ?
Old Sep 7, 2002 | 07:59 PM
Shine's Avatar
Question Any delimiter driver here ?
Sorry to ask such a question.
I'd like to know if any owner of SL55 delimit your SL55AMG ?
Mine is still a factory 260 km/hr speedo meter.
I test run as fast as I can,then rpm reads 5800
while speed needle stuck at 260 km/h & ~4900 rpm to hit that speed.
What is the possible speed for 5800 rpm ? same gear box
we used.
Thanks for any reply.
Old Sep 7, 2002 | 09:46 PM
pocholin's Avatar
Volvo V90 CC
Re: Any delimiter driver here ?
we used.
I'd guess 285-290 km/h, about the same as an E55
Old Sep 7, 2002 | 09:48 PM
pocholin's Avatar
Volvo V90 CC
How long will your car take to get to 240 km/h??? (almost 150 mph)
My E55 takes about 43 seconds, yours must be a lot faster.
Just trying to make comparisons to estimate what i have to do to be as fast as a SL55
Old Sep 7, 2002 | 10:42 PM
Shine's Avatar
Not an accurate one, just use a digital watch.
0~ 240 km/h(150 mph) 23.5" here in Taiwan at 28 C (82 F)
For reference only.
Put a S/C on you E55, SL55 will stay away from you, IMHO
Nevertheless SL55AMG is my dream car.
Old Sep 8, 2002 | 10:52 AM
pocholin's Avatar
Volvo V90 CC
For reference only.
about 23.5 sounds right, NICE!!!
I only need tosave 15,500.00 more for the kleeman s/c for my car, I'm getting closer now
Old Sep 9, 2002 | 08:00 AM
davidegai's Avatar
2007 CL 550
mine is limited HOWEVER the tacho shaows up to 300 km/h
Old Sep 10, 2002 | 01:22 AM
Felix's Avatar
C-Class
one of our customers has a new tacho and a 300km/h limiter. they changed nothing in the gearbox at AMG, only new wheels and tires. the 19" AMG dual-spoke multi-piece, looks really awsome.
in a german "auto motor & sport" test, the SL55 reached "real" 325km/h, problem is the at the moment there are no tires for cars that drive over 300 and weight over 2000kg.
Old Sep 10, 2002 | 09:07 AM
pocholin's Avatar
Volvo V90 CC
Originally posted by Felix
...in a german "auto motor & sport" test, the SL55 reached "real" 325km/h, problem is the at the moment there are no tires for cars that drive over 300 and weight over 2000kg.
That makes more exciting driving at those speeds, doesn't it???
Old Sep 10, 2002 | 10:15 PM
Shine's Avatar
So, assumed 325 km/hr was in 6100~6200 rpm/redline of SL55
5800 rpm may close to 300 km/h ?
6000 rpm/redline of stock V8 with Vmax to 315 km/hr (not sure ?)
I could push my car to 6000 rpm(5th gear), chassis is ok
by Y grade tires & much stiffer spring & shocks.
Old Sep 11, 2002 | 08:02 AM
Tezta's Avatar
CLS350
Shine, have you clocked your car doing the quarter mile? How is the 0-60 times?
Old Sep 12, 2002 | 08:36 PM
SteveL's Avatar
C43, SLK32, CLK63 Black Series
we used.
If you can tell me the transmission ratio of 5th gear, I can tell you what the speed would be at 5800 rpm.
With a rear axle ratio of 2.82 (found at mbusa.com), 26" diamater tires (285/35R18 Pilot Sports), and a 5th gear ratio of .83 (this is what it is in my SLK32), at 5800 rpm you would be going 191.75 mph. At 6100 rpm, 201.67 mph. At what rpm does the SL55 rev limiter kick in?
If you tell me what the rev limiter is and what the 5th gear ratio is, I can tell you max speed assuming the car is not drag limited.
Old Sep 13, 2002 | 12:45 AM
blueSL's Avatar
SL55 AMG
Both the SL500 and SL55 have a 0.83 5th gear ratio. The SL500 power peaks at 5600rpm, the SL55 6100 rpm, so your calculation of 202 mph sounds correct and matches the high speed runs which have been done. I think the Vmax will be at this engine speed, not at the rev limit, drag/rolling losses are certainly going to be the limiting factor.
Old Sep 13, 2002 | 12:50 AM
pocholin's Avatar
Volvo V90 CC
Re: Re: Any delimiter driver here ?
Does that apply for the 1999 E55? It has a 2.82 and it reds at 6100 rpm.
Old Sep 13, 2002 | 08:28 AM
Shine's Avatar
Great ! exactly what your found in mbusa.com,that's it.
rear axle ratio -> 2.82
5th gear -> 0.83 5800 rpm -> 191.75 mph -> 307 km/hr ?!
rev limiter -> 6000 rpm, thanks for telling its Vmax.
Old Sep 13, 2002 | 01:57 PM
SteveL's Avatar
Re: Re: Re: Any delimiter driver here ?
Yes, this applies to all cars but only addresses what the car is geared to run, not what it will actually run. If you have a 100 hp motor with the same ratios, it is still geared to run 201 mph but can't possibly do it because it would be drag limited, ie., the engine is not strong enough to overcome the forces of resistance against the car going faster.
Old Sep 13, 2002 | 02:27 PM
pocholin's Avatar
Volvo V90 CC
Re: Re: Re: Re: Any delimiter driver here ?
I understand, but a beefed you E55 with out the sped limiter can do that if other factors help, GOOD!!!
I've taken my car to speed limiter and there was plenty of acceleration to go, once I beef it up and get rid of the speed limiter I'll be more dangerous!
Old Sep 13, 2002 | 03:12 PM
SteveL's Avatar
Re: Re: Re: Re: Re: Any delimiter driver here ?
What beefing up are you planning on doing? Who is removing the limiter?
Old Sep 13, 2002 | 03:27 PM
pocholin's Avatar
Volvo V90 CC
Re: Re: Re: Re: Re: Re: Any delimiter driver here ?
I'm still not sure, need to save a lot of money first, but upsolute is my first choice for computer tunning and removing limiter.
I'm trying to come up with bolt ons like cold air induction or something like that, headers, chip, etc. i don't like getting inside the engine, a S/C is a good option but I need more that 16 grand for Kleeman
Old Sep 13, 2002 | 03:35 PM
SteveL's Avatar
Re: Re: Re: Re: Re: Re: Re: Any delimiter driver here ?
Originally posted by pocholin I'm still not sure, need to save a lot of money first, but upsolute is my first choice for computer tunning and removing limiter.
Forgot to ask you your tire size. That will affect your top speed. What tires, size/brand on the rears?
I have an SLK32 with many Renntech parts, ECU, pulley kit, forged wheels, brake upgrade, and springs. ECU mod raised electronic limiting to 186 mph from 155 mph. Top speed would be 187.46 mph. The ECU mod raises the redline to 6420 from 6220 which helps on the top end. Of course, I don't drive 180mph much on US roads.
Old Sep 13, 2002 | 03:39 PM
pocholin's Avatar
Volvo V90 CC
Re: Re: Re: Re: Re: Re: Re: Re: Any delimiter driver here ?
They are OEM sizes for the E55, 245/40/18 front and 275/35/18 rear, Z rated.
Old Sep 13, 2002 | 03:43 PM
SteveL's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Any delimiter driver here ?
Geared for 199.34 mph.
Old Sep 13, 2002 | 03:54 PM
pocholin's Avatar
Volvo V90 CC
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Any delimiter driver here ?
cool, thanks!
