SL55/63/65/R230 AMG: Question Re Automatic Transmission
M=Manual...............shift up/down with paddles on back of steering wheel.
C=Comfort...............starts off in 2nd gear and shift points are set much lower for around-town easy driving.
S=Sport.......all 5 gears in use and shift points can go to redline depending upon your use of the throttle.
My '05 shifts up easily in Sport mode, you need to clarify what "doesn't want to upshift here" means.
Obviously if you manually select a gear (whether you are in C or S) it will rev it out to the top and then shift... if you want automatic then leave it in D (by moving the shifter to the right a couple of times, or just holding it there...)
This is how speedshift/tiptronic/whatever works in all cars for the most part... nothing new?? is this your first car w/ that feature?
In M (manual) mode... it might not even shift for you at all and you will redline.
I know that my friends '06 redlines in Manual and bounces off the rev limiter in M mode. My '04 shifts for me however in M.
you have touched the down paddle shift while steering.
Not that unusual for a newbie. Its the one on the left you are hitting in error.
With a little practice you can avoid doing this. No big deal.
