Some SL65 RennTech Questions
Subscribe
Sep 11, 2010 | 07:12 AM
How does one check if the ic pump is bad? Or can it only be checked by the shop?
Reply 0
Sep 11, 2010 | 09:31 AM
Is there a way of testing for the bad ic pump? Or can it only be done by the dealer?
Reply 0
Sep 11, 2010 | 12:08 PM
Quote: Is there a way of testing for the bad ic pump? Or can it only be done by the dealer?
An AutoEnginuity reader (as well as any similar tool) will display the Intake Air Temperature (IAT). If the IATs are high, odds are the pump is failing or has failed.
Hope that helps.
Reply 0
Sep 11, 2010 | 07:55 PM
looks like you got the fix taken care of...what's the difference between a standard IC pump and RT's pump just out of curiousity??
Reply 0
Subscribe
Currently Active Users (1)
