SL55/63/65/R230 AMG: Some SL65 RennTech Questions
I have been a lurker for quite a while now, and have finally decided to register.
Last year I bought an 05 E55, and recently sold it, and purchased an SL 65.
My 65 supposedly has the RennTech ECU/TCU mods done, but I was wondering if there is any way to tell for sure. Is there some code in the software, or a special sticker, or something to verify that the RennTech mods were done.
My car does have the RennTech Carbon Fiber intake, and the 20" RennTech monolite wheels, so I'm assuming that the ECU and TCU mods are done, but I was just wondering if there is some way to tell, without me having to test the top speed to see if the speed limiter has been adjusted.
The reason I ask is because, although my car is very fast, I just raced my friend (who bought my E55 from me).
For my car being a 65, RennTech to boot, it was a very tight race.
When starting from a 30mph roll, both cars were neck and neck to about 100mph before my 65 started to pull him. And, even then, it was a slight pull, nothing definitive.
The E55 is bone stock.
Neither one of us did anything fancy with shifting or adjusting the transmissions, we both had them in Sport mode, Drive, and just mashed the gas on the 3rd honk.
Any thoughts?
J
How exactly do I go about checking the Intercooler pump? Do I just take it into the dealer and say check it or is there something else?
I was also thinking that with the 20" tire/wheel combo, that with the taller tire it may have affected the final drive enough to take a little "pep" out of it..
But then my next thougth was that it's probably a good thing to have a bit taller final drive ratio..
I'll take it into the dealer on Friday, and ask them to check it. You guys are saying that I ought not waste my time on the Renntech IC pump then?
Thanks for the advice, and I'll keep everyone posted.
And, I'll post some pics of the tire/wheel combo once I take some..
Oh yeah that renntech ic pump does not work better than stock, the stock system is more than adequate for modified HP
I figured that with the turbos that the underhood temps must just be high.
But, now that you guys are talking, I'm wondering that the IC pump must be toast, because those gaskets shouldn't be melted like that.
I just called the dealer, and the soonest they can get me in, is Tuesday. So, I'm going to get it in then.
Also, I'll call RennTech between now and then and ask them to crossreference via the VIN and figure out everything they did.
Thanks for all the help, and I'll keep you posted.
They're a little dirty, but not too bad.
When I dropped the car off, the tech asked what was wrong. I told him that I didn't have the power that I thougth that I should have, and I suggested that it was the IC pump. He said OK, I'll have my master tech look at it.
This afternoon he called me and said that they checked the codes, and most of the errors that they saw were from the RennTech ECU flash. But he did say that the Air Inlet Temps should have put off the check engine light, and that they were apparently high.
I said, that sounds like the Intercooler pump. I told him that I did some internet work and said that it must be fairly common to have air pockets in the IC system and that the IC system should be flushed and possibly replaced.
He said, well, I'll have my master tech keep digging into the high AITs and let me know more tomorrow.
He also asked if I knew which RennTech shop did the mods. I told him that I knew it was the main hq in Florida. So, Bob if youre out there, you may be getting a call concerning my car.
I have a sneaky suspicion that they are going to try and weasel their way out of fixing the IC pump.
Fingers crossed.
Thanks guys.
Cheers
Adam
He said that according to all of their tests, the stock IC pump is fine. It doesn't need to be bled, or re-charged or anything.
He said that the RennTech flash has caused the engine to put more demands on the Stock IC pump, and the stock pump just cant keep up.
Therefore, they recommend that they contact RennTech and have RT send them one of their upgraded IC pumps, and they will install it for me.
So, I gave the tech Bob's name, and I guess now I'll wait for RT to get the upgraded pump to my dealer.
Like I mentioned.. I had a sneaky suspicion this might happen..
He has contacted RT in Florida, and is having them build one of their IC pumps, and once it's built RT is to send it to my dealer and they will install it.
This whole process is going to take about a week or so.
Luckily I'm going out of town for a week, so HOPEFULLY the job will be done when I get back.
Fingers crossed.. AGAIN..
"We thought the RT IC upgrade was going to be a simple swap, but it isn't. It's a whole new assembly. This wasn't in my original bid, so we're going to have to re-estimate for you, since there will be some modifications to the front bumper assembly...blah blah blah"
I said, " just do it, and have it done by Monday (today)."
Well, I called there today, and SUPRISINGLY... It's not done.
I can hardly wait for this saga to be over, and start driving that bad boy.
That was a bull**** excuse from the tech and you fell for it... its to late now, but thought you should be aware that they are making you pay for a warranty-covered issue.
I got the car back from the shop about a week and a half ago, and it does run quite a bit better than before.
I raced my friend in the E55 a couple of days ago from a dead stop, and we were even up to about 60, and then by 90 I had him by about 5 lengths, and still pulling harder. I figure that I was having traction issues up to 60.
I also raced an M3 this morning.. It wasn't even close. We were on the interstate, and he waved me down, and then then we started swerving between the lanes to get a good open spot. Once one opened up, I was behind him, and he hit it, and at about 100, when I noticed that he was giving it all he had, I pulled along side, waved, and blew by him, and at about 130 I had him by about 3-4 lengths.
So, I feel much better now.
