SL55/63/65/R230 AMG: ***Lower and Raise Top while Driving***
Old Aug 15, 2007 | 10:03 AM
SLcharger's Avatar
SL55AMG, ML420CDI, E320TCDI
A have been absent for a while and maybe this topic have been solved in the meantime, but i will give it a shot and tell you anyway.
The disadvantage of the SL, having to stand still, before you can activate the opening or closing of the top, can now be overcommed by an additional module installed.
I had mine done a month ago, and it sure is nice, activating the top up til a speed of 25 MHP., ( at higher speed, the hydraulic of the boot cant cope with the drag ) be able to open and close the top, in distance, ( aprox 25 feet away ), only with the standart key, etc.
When you walk away from your car, just press the lock button, on the car key, three times, and the top will close, the doors will lock, and the alarm be activated, all automatic.
It workes great and has given me only pleasure up til now.
Check out this web page.
https://www.wilhelmy-it.de/sms/shop/...ZmVyZXIiO047fQ==
Old Aug 15, 2007 | 11:03 AM
GeorgeJ's Avatar
2005 SL65 w/RENNtech Stage 2, 2013 MB GL550
Why would you want to lower/raise top while moving?
I see that the mod does some other things but why would you want to raise or lower the top while moving? I see nothing but bad things happening if you could do that!
Old Aug 15, 2007 | 11:52 AM
SLcharger's Avatar
So, what bad could happen ???
I choose to install the module, because i found it anoying to have wait, when parking the car, that the roof came in place. Also i wanted to be able to open the top, while approching the car, so that could drive of instantly.
Old Aug 15, 2007 | 01:44 PM
Murtaza's Avatar
C63S coupe, X5M
Was the first mod on my car. It's a must have for all SL owners...
Old Aug 15, 2007 | 05:39 PM
clk554me's Avatar
SL55 2006 previously Triple Black CLK55 Cabriolet 2002
Install
Who did the install for you locally, or did you install it yourself? All the literature indicates that anyone can do it...
Old Aug 21, 2007 | 02:29 AM
Black SL Bullet's Avatar
2006 Lamborghini Gallardo, 2004 MB SL600, 2005 GMC Sierra Diesel Crew Cab, 1999 Lexus GS400
I have to get one. Did you install it yourself? Is it hard to install?
Murzata: you're in SOCAL. where did you get it?
Frank.
Old Aug 21, 2007 | 02:40 AM
Murtaza's Avatar
C63S coupe, X5M
I did it with the help of a friend who installed it on his SLK55. It's very easy as long as you know what to do. The instructions are a tad confusing...
Frank.
Same as the original post:
You're in the OC, if you need some help installing it send me a PM
Old Aug 21, 2007 | 02:46 AM
SLcharger's Avatar
[quote=Black SL Bullet;2376696]I have to get one. Did you install it yourself? Is it hard to install?
No, i didnt do it myself, i had a mechanic do it. He told me it was fairly straight forward, but he had trouble with the colors of the wirering, in the car, because it didnt match the ones in the manual. The installation manual is very instructive, taken you ahead, step by step, and maybe the coloring is just a problem on my car.
When the module is installed, and you turn on the ignition. the module is self diagnostic, and will tell you if you installed it correct.
I surgest you take it to a shop, and let them install it. It took my mechanic 2 hours, and he is not even a MB guy.
Old Aug 21, 2007 | 03:11 AM
Murtaza's Avatar
C63S coupe, X5M
2 hours
It took me 45minutes, and I got stuck and had to call my friend for help.
If I had to do it again, it'd take around 20 minutes...I just don't see 2 hours unless he took a lunch hour.
Was he on the clock?
Old Aug 21, 2007 | 03:49 AM
SLcharger's Avatar
2 hours
As i told, he had trouble with the color of the wirering. He had to figure out what colors to use instead. That can be troublesome.
I think 2 hours are not so bad, given the circumstances.
Old Aug 21, 2007 | 01:48 PM
Murtaza's Avatar
C63S coupe, X5M
I had the same problem...
Anyway, as long as your happy
