SL55/63/65/R230 AMG: SL55 Deep Exhaust
Old 02-29-2008, 03:57 AM
BallzyS55's Avatar
06 S55 AMG, 03 SL55 AMG, 02 S430(sold), 05 F150, 06 Ranger, My baby 07 HD Rdking
SL55 Deep Exhaust
I went to a muffler shop today, they cut out my resonators, and the car sounds just absolutely wonderful, I mean it's just a little bit louder, but a whole lot deeper, I love it. It sounds classy but yeat ballzy.
Old 02-29-2008, 04:22 AM
Fantasm's Avatar
Car Whore
post VIDEO of full throttle take off and pass by or GTFO
Old 02-29-2008, 05:54 AM
BallzyS55's Avatar
I'll try
Old 02-29-2008, 08:03 AM
alroumi's Avatar
G55 & SLK55
congratulations, just a fact you should get an X-pipe as you obviously lost lower end torque, If I wanted a bit more sound of the oem setup I would remove the front primary cats extended the o2 sensors way back or add headers.
Enjoy!
Old 02-29-2008, 03:25 PM
BallzyS55's Avatar
I didn't know removing resonators would make me loose tq, I just talked to vadim, and he said it wouldn't, it's strictly sound related.
Old 02-29-2008, 10:03 PM
DynamicMotoring's Avatar
2007 Escalade EXT, Stealth TT 600 AWHP
If you remove some of the restriction of a stock exhaust, you lose torque. Backpressure=exhaust velocity=(scientific exclamation deleted) torque.
Edit: explanation, not exclamation.
Old 02-29-2008, 10:48 PM
alroumi's Avatar
G55 & SLK55
It was discussed in the many topics that are relevant to Resonators and catalytics on the W211 AMG board.
Old 03-01-2008, 12:08 AM
Cyrusx7's Avatar
Benz SL55 AMG, Jag XJR
Yea, id like to hear some audio/video clips as well before I go out and do mine too..
Old 03-01-2008, 01:16 AM
BallzyS55's Avatar
Believe me you'll love it.
Old 03-01-2008, 01:20 AM
Cyrusx7's Avatar
I straightpiped my XJR and loved it, so I dont think the idea sounds too far fetched. If you had to put a percentage on it, how much louder/deeper would you say it is? Also, which resonator did they cut? I know there are multiple ones under the car.. Ex, 2 cats (front), 1 resonator (mid), 2 mufflers (rear) on the XJR, cant recall whats under the SL55..
Old 03-01-2008, 04:41 AM
R230_Nicke's Avatar
SL 600 640bhp/1000Nm
There are only two resonators/mufflers. The two in the back.
The two in the front and the two in the middle is primary and secondary cats.
Old 03-01-2008, 07:02 AM
komp55's Avatar
ML550
Here's the stock exhaust. Two resonators.
Old 03-01-2008, 03:32 PM
JKK
JKK's Avatar
Audi AS4
If back pressure = torque, why don't race engines that achieve max hp/trq try to make back pressure? They don’t. The goal is to flow the exhaust gas out with the most efficiency based on the engine configuration and dump it into the atmosphere as quickly as possible. A good example of this is a F1 exhaust system. Once the exhaust gasses are tuned through the headers to aid the intake, they send it out in the shortest amount of distance with the least amount of resistance. This is one of the biggest misconceptions with engine tuning.
Old 03-04-2008, 06:35 PM
david7979's Avatar
Post a VIDEO!!!
Old 03-05-2008, 12:07 PM
BallzyS55's Avatar
I'll try to day
Old 03-05-2008, 04:45 PM
Timeless's Avatar
2005 E55 ///AMG
Any drone at interstate speeds? I am thinking of doing this also.
Timeless's Avatar
2005 E55 ///AMG
Enjoy!
It already has an H pipe...so no need for an X pipe.
Old 03-06-2008, 01:19 PM
UKSilverArrow's Avatar
SL500 R230
I'm confused, I've looked at the diagram and don't see an 'H' pipe. Left and right bank looks separate from header to tip. Am I missing something?
David
Old 03-06-2008, 02:18 PM
Timeless's Avatar
2005 E55 ///AMG
David
Was referring to this post on it: https://mbworld.org/forums/classifieds/231566-211-e55-x-pipe.html
Old 03-06-2008, 07:13 PM
SL500 R230
Originally Posted by Timeless
Was referring to this post on it: https://mbworld.org/forums/showthread.php?t=231566
Oh I got you, my mistake.
David
Old 03-06-2008, 08:54 PM
Fantasm's Avatar
Car Whore
cmon dude, take a video already
Old 03-10-2008, 05:22 AM
BallzyS55's Avatar
Check you the thread, in w211 I did it to my S also. It has a vid
Old 03-10-2008, 06:26 PM
BrabusTrojanSL's Avatar
Can't you just take out one of the Cats 1st or 2nd to make it sound deeper? And just a question, which cats would you take out for this modification? Id rather not cut the pipe, just so I can put the cats back in if I don't want it that loud and I just want to cruise on the PCH, you know.
Old 03-11-2008, 01:49 AM
BallzyS55's Avatar
I didn't want to take out the primary cats, cause of the simple fact that the o2 sensors are right there, and also because that could be a major issue with smog. I took off the secondary cats, because it's very easy just to go back to any muffler shop, and have them weld them back on, also I took out the resonators for deeper, and louder sound, as for the cats off, you get better flow, I also think with them off they give you better the sound.
Old 03-11-2008, 06:04 PM
Cyrusx7's Avatar
Any vid yet? Im dying to hear it!
Quick Reply: SL55/63/65/R230 AMG: SL55 Deep Exhaust
