SL55/63/65/R230 AMG: How to remove shifter knob on 06 SL65?
Old Jun 29, 2008 | 12:37 PM
smess's Avatar
2019 E63S
I bought a 06 SL65 and replaced the Burl Walnut wood with carbon fiber.
The only step left is the shifter knob.
It has keyless go and I can not find any instructions on how to remove the knob, anyone know?
thanks
Old Jun 29, 2008 | 05:46 PM
smess's Avatar
2019 E63S
figured it out thanks anyway.
Old Feb 1, 2014 | 07:56 PM
robert1's Avatar
2008 SL 550
Hi There. I want to replace my shifter knob in my 2008 Sl with Keyless go as well, any help would be appreciated on how you remove it.
Robert
Old Feb 1, 2014 | 09:36 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
put on rubber gloves, or latex. this makes it a firm grip and you wont slip. put in in straight up position, and pull straight up, hard and quick
Old Feb 1, 2014 | 11:02 PM
robert1's Avatar
2008 SL 550
Boot
Thanks, How do you get the rubber boot off? Do you have to take the whole console apart?
Old Feb 2, 2014 | 02:48 AM
Wolfman's Avatar
Super Moderator
It just snaps on. Just pull on the leather until it comes off, then pull the leather over the shift knob. This reveals the locking ring. Rotate counter clockwise (if I remember correctly) maybe half turn. Then pull straight up
Old Feb 2, 2014 | 09:58 AM
okbarnett's Avatar
its all meant to unscrew and up clip, but to pull it off you just rip and it comes apart, to put it back togather make sure the tabs are all clipped back in, the boot, is not on some cars, the top collar ring does unscrew like wolfman says, the boot is then compressed on the knob with another ring
Old Feb 2, 2014 | 11:01 AM
robert1's Avatar
2008 SL 550
Thanks everyone for the input. I will attempt this in a few weeks, just wanted to get prepared. Herd it could be tricky with the two pins breaking off on the push start button. I'll let you know how it goes.
Old Feb 2, 2014 | 12:59 PM
Wolfman's Avatar
Super Moderator
It's super easy. Just never twist the shift knob. Just pull and push to re-insert.
Old Feb 2, 2014 | 01:28 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Only tricky part is prying off the plastic piece in between the the leather boot and the shift knob. Get something that's very thin to help pry it off.
Old Feb 2, 2014 | 02:21 PM
robert1's Avatar
2008 SL 550
Thanks, Gave it a test run, all came off no issues, the shifter knob actually pulled strait off with out much pulling, slid right off, no pin issues. Thanks for all your help!!!
