SL55/63/65/R230 AMG: aftermarket headers
Old 08-21-2008, 09:03 PM
coldhammer's Avatar
2003 SL55 Klemman
aftermarket headers
So I have had my car for about 3 months now and new it had some mods done to it prior to me buying it.
The resonators were removed and I believe the cats were removed as well.
Anyways the dealer calls me up after having it in for some service and asks what type of headers i have on the car. Needless to say I was completely suprised by the question. He says there not stock headers. I bought the car from a used car dealer and he doesnt know anything about it.
Anyone know how i can identify the maker of the aftermarket headers?
Old 08-21-2008, 10:05 PM
jmf003's Avatar
'03 SL55
The list of candidates is pretty short: Kleemann, Supersprint, and VRP are the only ones I can name off the top of my head. Evosport and Renntech only offer shorties if I recall correctly.
If you go to the website for those manufacturers you might be able to see where they stamp their headers. You might also be able to tell based on the differences in the design.
Good luck in your search and enjoy the 55!
Old 11-10-2008, 08:17 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
What is best headers for a SL55 AMG, shorties or regular headers. Now that Kleeman has headers sale, I'm looking foward to buy a set.
Old 11-10-2008, 09:54 PM
Rick SL55's Avatar
After reading & searching so many post, here are my choices
Shorties:
VRP vrptuning.com
Evosport evosport.com
Regular (long)headers:
Kleemann
Probably shorties are easier to install. Any big difference in performance between VRP & Kleeman headers?.
Need to know by manana(tomorrow AM) and call Cory (if I choose Klemmann) otherwise I will buy VRP.
Thanks,
Ricardo
Old 11-11-2008, 08:00 AM
jmf003's Avatar
'03 SL55
Yep, shorties are easier to install, as you suspect. In my case, just needed to re-route a heater line and bolt them on.
Long tubes will displace the primary cats and you'd need to deal with that, either by moving the cats and O2 sensor or removing them and reprogramming the ECU to ignore the O2 sensor. Not impossibly hard and Kleemann would take care of the ECU re-program if I recall correctly.
As I mentioned above, I went the shorty route (Evosport; no VRP at the time) and have no regrets. However, if you are looking for every shred of extra performance, long tubes will give you a bit more. How much more? Not sure. Maybe 5 or 10 HP?
Hope that helps.
Old 11-11-2008, 10:39 AM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
VRP has log type headers
RENNtech and EVOsport have equal pressure shortly headers
Kleemann is currently running a great holiday sale, they are shortly headers but also remove the primary cats
Supersprint I believe are long tubes
Old 11-11-2008, 12:53 PM
Rick SL55's Avatar
I already spoke with Cory from Kleemann about installing the Kleemann headers, yes primary cats have to be deleted then O2 sensor relocated, some exhaust modification and finally ecu reprograming by them (Kleemann) to avoid engine lights.
I just had my ecu done by Powerchip Group 3 weeks ago. If Kleemann sales was posted earlier I will do their upgrades, but I live very far away(Puerto Rico) from Kleemann and will be crazy to spend more $$$$ on ecu re-programing.
I will like to avoid engine lights and want then to keep stock exhaust at this moment, yes I will delete the secondary cats, but my question now is, should I buy EVOsport or VRP headers. I'm more incline towards VRP.
Now what you people recommend with my car upgrades? EVOsport or VRP.
Thanks,
Ricardo
Old 11-11-2008, 01:41 PM
jmf003's Avatar
'03 SL55
Nice picture post, James.
I have the Evosport headers and they are great but if I was buying again, I'd buy the VRP headers which should be similar in performance and a lot less expensive.
Old 11-11-2008, 08:38 PM
Rick SL55's Avatar
jmf003
Thanks for your info.
I already order the VRP headers.
Old 11-14-2008, 08:22 PM
MBWorld Founder
otoupalik's Avatar
ones too fast according to CHP!
Great post!
Old 11-14-2008, 08:25 PM
MBWorld Founder
otoupalik's Avatar
Thanks for the nice words and support!
However, there is very little real chance that a log manifold makes anywhere near the power of our or any other shorty header. You ask how I know - well, we built log manifolds and tested them against the shorty headers YEARS ago (when Vadim was working here) and the real results were very clear. That is why we chose to go the more expensive route with a proper shorty header.
Yes, the manifold is cheaper, but it will not give you the same or even close to the same results. FYI, we did recently lower the price of the headers as well, just an FYI.
Brad
Old 11-14-2008, 08:30 PM
Vadim @ FD's Avatar
S600TT, R350
I must respectfully disagree.
My current log design uses 1.75'' primaries vs. 1.625'', as well 2'' collector flange vs. 1.875''. It will out power any other bolt-on design.
Old 11-14-2008, 08:48 PM
MBWorld Founder
otoupalik's Avatar
Sounds like time for a showdown wild west style!
Anyone with a stock 55 that is thinking about headers, I will give you a crazy deal.
Vadim, you get a STOCK car also and we will do a dyno shoot out!
Then the proof is out there for everyone, no problems! We can even use Steve's dyno so there is no hint of bias!
Old 11-18-2008, 09:29 PM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Crazy deal? My PM is open. No need to pay inventory taxes, when I can help out, give track results and dyno numbers.. Just a little over stock.
My B day is this week. Say the word and my wife will call
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 11-19-2008, 12:06 AM
MBWorld Founder
otoupalik's Avatar
Unfortunately you are geographically undesirable. lol
We would need SoCal cars to do this.
thanks though!
Old 11-19-2008, 12:44 AM
MHP
MHP's Avatar
'09 C63 AMG
Good stuff. Can't wait to see your results guys.
Old 11-19-2008, 07:53 PM
PLATINUM SPONSOR
2003 CL55
thanks though!
LOL! Yes , I would have cut the collectors off and made custom down pipes , so I would have modified the mods. They would have made huge power on our sea level track . Full disclosure of course!
__________________
www.ultimatepd.com
Old 11-19-2008, 08:17 PM
MBWorld Founder
otoupalik's Avatar
lol, that is funny. I needed a smile - thanks!
Old 12-05-2008, 10:06 AM
crazeazn's Avatar
C55
what happened to this?
Old 01-04-2009, 01:05 AM
bigmike32172's Avatar
SL65
They both found out like the rest of the dyno shops around the country that headers only made 1 to 3 HP difference over stock
Old 01-05-2009, 09:36 PM
Vadim @ FD's Avatar
S600TT, R350
No, more like 23RWHP on a stock SL55.
Dyno graphs to follow. We had a client who wanted to do our shorties first, before any other mods.
I will post graphs as soon as I get them.
Old 01-08-2009, 07:48 PM
SL65
That could be on an SL55, but I shoud have stated SL65, at least that's what I've been told by most of the dyno shops.
Although that is awesome to get 23RWHP difference over stock with just a header swap. I don't think there has been a car prior to the mid 80's that has benefitted that much from just headers. Those stock headers must have been made in a cave somewhere!
Old 01-09-2009, 04:05 PM
gmethod's Avatar
2004 SL500 Sport
Wrong...wrong...wrong. Headers...specially long tube headers have been proven time after time to give real horsepower improvements. Prior to owning a very tame SL500 I've owned several corvettes and built about a dozen motors for several corvette owners locally. One good example is the brand new LS3 motor (rated at 438bhp) in a the new corvettes. Long tube headers and a tune allowed that car to put down around 475rwhp!! That's about as much as the new Z06 puts down with the LS7!!! By the way, a good set of LT headers in a vette could result in close to 45rwhp after a tune. Look it up if you don't believe me. If shops are telling you that a twin turbo V12 motor(exhaust driven force induction) does not increase horsepower, the I wouldn't let those shops check the tire pressure in my cars much less do any performance upgrades.
Old 01-09-2009, 04:30 PM
SL65
Maybe it's just Arizona then
I've built 2 Z06's now, and both the long tube headers, one made by Kooks and the other by B&B and both never made anywheres near that RWHP at 3 different dyno shops. The Kooks LT's on an 08 Z06 made approx 13RWHP and 9RWTQ. B&B LT's on my 04 Z06 made 6 to 7RWHP and 4RWTQ. Xtreme Motorsports in Tempe AZ builds more Vettes than most shops in the country combined and they will tell you that the days of getting high HP #'s out of just bolting on headers and cat back exhausts went out in the 80's. These car companies have realized long ago that making a free flowing exhaust is cheaper than beefing up the motor to compensate for HP. I remember doing the Headers and exhaust on my 87 IROC back in the day and how much of a difference it made due to the factory restricted exhaust. Nowadays all the money people waste on exhausts does nothing more than give your car a different note to sing. Most aftermarket vendors and mom & pop speed shops don't want to come forward and actually tell you that because it would put them out of business, and the big shops with the dyno's in house can play with the #'s on the dyno to show you false readings after you drop big coin on their recommended exhaust they installed for you.
I guarantee there is no header or exhaust you can slap on an SL55 or SL65 that will give you in excess of 20RWHP if I'm working the controls on the dyno given the same conditions that the car was run at stock.
Trust me it's all just the sales and marketing gimmicks we've all seen over the past couple of decades of bolt on crap that you should have over 2,000HP by the time you put this and that on your car.
Old 01-09-2009, 07:23 PM
Vadim @ FD's Avatar
S600TT, R350
SL65 manifolds have cast-in turbine housings. They are very restrictive, but not easily replaced. Brabus make new castings, but they are $30K.
M113 Kompressor engine uses the same headers as E500, the primaries are 1.5'' and collector flange is 1.75''. This is why we pick 20+ HP on the Kompressor cars.
Quick Reply: SL55/63/65/R230 AMG: aftermarket headers
