SL55/63/65/R230 AMG: my 03 cl55 slows down and feels heavy after 120 mph
Old Dec 1, 2008 | 12:33 AM
palicl55's Avatar
2008 CL63 AMG 2003 cl55 amg SOLD
Unhappy my 03 cl55 slows down and feels heavy after 120 mph
when i drive my car fast everything is smooth till i hit 90 mph the car takes a while to go faster,,?? what could be the problem, please help ?i'm freaking out
Old Dec 1, 2008 | 12:44 AM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
Is your supercharger shutting off? You could be soaking heat, which means you have an intercooler pump problem. Did you happen to check your engine temp when this occurs? Generally, 03's are testy...
Old Dec 1, 2008 | 12:56 PM
palicl55's Avatar
my car's temp is almost 90 is that normal
is that a big problem??? thanks for your help
Old Dec 3, 2008 | 07:57 AM
danski's Avatar
SL55 AMG
I've just had the same problem with my SL55. Seems to be a fairly common issue with the 211 55K engine, but luckily it's a simple and fairly inexpensive thing to get fixed.
Over in UK a new pump is $300, but I think they're cheaper in US ($200ish). A decent garage should only need 1-1.5hr labour to replace the pump and you'll be back to normal.
Old Dec 3, 2008 | 09:44 AM
crazeazn's Avatar
C55
its a sign from God telling you to upgrade to the 65s
Old Dec 3, 2008 | 10:43 AM
jmf003's Avatar
'03 SL55
Originally Posted by palicl55
is that a big problem??? ....
Yes, it is. Especially if your 2003 is still using the original pump. The pump on my 2003 failed last summer.
LOL. Great perspective!
Old Dec 6, 2008 | 07:35 PM
phackett's Avatar
SL55 AMG (03); SL500 (98); BMW535 (08); Landrover LR2 (07)
Loss of power
I had all the symptoms relating to the intercooler pump failing on my 03 SL55 and therefore changed out the pump for the much recommended Johnson 030unit - but same problem remains. After a hard acceleration (with lots of power on tap), it's as though someone disabled the Supercharger on run number 2.
Any ideas?
Old Dec 6, 2008 | 11:35 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Any ideas?
May need to double check your pump again. I had two fail in a four month period... The 3rd one has been fine for a while now..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 7, 2008 | 11:27 AM
jmf003's Avatar
'03 SL55
+1. Those symptoms point to a cooling problem.
A datalogger will tell you the exact intake air temperature that your car is running. They aren't all that expensive in the context of owning an MB. You are also welcome to borrow mine if you feel like making the trip up US-23 to Ann Arbor.
Old Dec 9, 2008 | 07:29 PM
phackett's Avatar
Thanks for the offer - very generous. I've taken the car off the road for the winter months as it's never seen salt in its life (FL car).
BTW, I just plugged in an OBD II reader and found multiple PO 0451 codes - Evaporative emission control system, pressure sensor range or performance problem. Any ideas if this might be related?
Thanks again.
Paul
Old Dec 9, 2008 | 08:26 PM
jmf003's Avatar
'03 SL55
Thanks again.
Paul
I hear you about the salt.
There's nothing on the Star Service DVD about P0451. Google searching on P0451 points to a problem with the EVAP pressure reading. Possible causes are all over the map, from a faulty gas cap to a faulty sensor to a faulty fuel pump.
So, yeah, possibly related.
If it was my car, I'd probably replace the fuel filter and add some fuel stabilizer as a low cost, low risk shot in the dark. If that didn't work I'd go into the dealer.
Hope you're able to get to the bottom of it.
Old Dec 10, 2008 | 07:36 PM
phackett's Avatar
Thanks again, good advice.
I also checked the code out on the internet and came up with the same conclusions. I cleared out all of the codes and will take the car out when the weather improves to replicate the problem. I'll then see if the same code re-appears - if so, I'll know for sure that it's related.
Of course, I'm looking at 4 months before that will happen - gloom!
Old Mar 15, 2009 | 12:59 AM
c32used's Avatar
LET C32 2002
Question
Have you taken car out yet?
Old Mar 15, 2009 | 01:15 AM
jagass's Avatar
pick up
I have the same problem as yours...
Old Mar 15, 2009 | 03:52 AM
biggs247's Avatar
SL55AMG,S63AMG,2 CAYENNE TURBOS,BENTLEY GT,S6004MATIC
COULD YOU TELL ME WHERE YOU CHECK THE CODE?
Old Mar 15, 2009 | 04:19 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Phacket-- I live right around the corner from you. I might be able to help if you pm me. Mike Scott
Old Mar 15, 2009 | 04:30 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
We have had guys install the pumps wrong. Additionally, it sounds like there are a couple of other issues that need to be addressed. It might be time to visit the dealer!
Old Jul 21, 2010 | 02:28 AM
hatchy's Avatar
Very fast
I have the same code, and don't want to start taking apart the fuel system. How did you guys solve the problem? Thanks
