I have been looking for a set of 18" split spoke wheels for my 03 SL55 and have not been able to find any. I have found several sets from CLS550's, but the offset is 5mm different. What problems, if any, would it cause if these were put on an SL?
I put a set of 18" CLS 18" wheels on my 05 SL55 without any issue. If you look at the wheel chart in the owner's manual you well see looks of different offsets for an SL. 5mm is is less than 1/4".
CLS wheels fit the SL just fine despite the offset difference. Just with the 10J wide rear wheels (only Style IV two piece 19") AMG requires fender rolling.
I know cause I have em.
Style 3: 8.5J and 9.5J (winter wheels)
Style IV: 8.5J and 10J
Sprins - Thanks for the reply. Are your winter wheels 18" or 19", and what did they come off of?
19" winter & summer.
I bought them new to upgrade from my 18" stock SL55 AMG wheels.
I attached the AMG brochure PDF with the part numbers.
what do you guys think of these wheels for a SL55 ? made by TSW
http://cgi.ebay.com/ebaymotors/20-WH...Q5fAccessories
Originally Posted by xircom200
what do you guys think of these wheels for a SL55 ? made by TSW http://cgi.ebay.com/ebaymotors/20-WH...Q5fAccessories
Summer of 2007, I bought EXACTLY that set, from the same dealer for my old 2004 SL600!
They fit perfectly, and don't require any spacers!
(See my photos.)
And the guy working there, Bob, is very helpful and polite!
I highly recommend them!
ExploreMBWorld Fanatic!
Same here CLS500 WHEELS!!!! SL & CLS have similar off set and it can be shared between the two . This set is for SALE if anyone is interested . it has less than 500 miles . MICHELIN PILOT SPORT . Also have this for sale 19" CLS55 WHEELS
Quote:
I sold that car back in october 2007.Originally Posted by xircom200
maxabo, very nice car. May i ask why you dont have them on your car any longer ?
But since I was sooo pleased with their look, I bought another set from eurowheelsusa, that I have in stock for "future projects"..!
And the reason why I don't have them on the car I have today, is because it's a Carlsson, and therefor Carlsson rims is the only way to go (my opinion)!
However, I like the looks of the "AMG style" better...
Quote:
As a matter of fact, NO they don't..!Originally Posted by carcommander
They bend really easy.
I was actually suprised to see, after a summer, that they still were nice & round!
So these have good quality.
Otherwise, I get your point there.
Most copies are terrible when it comes to potholes...
I have a set off my 04 E55 with 14K miles and are mint. They are for sale @ $600 for the set.
Don't go stock, Get something that gives the car a wider yet classic stance.
I HAD 2 OF THE ORIGINAL WHEELS ON MY SL65 THAT WERE BENT! THE CAR NEVER HIT ANYTHING AND IS PERFECT! THE RIGHT REAR ON THE INSIDE WITH NO APPARENT CONTACT DAMAGE BUT HAD A HUGE FLAT SPOT. THE FRONT WHEEL ALSO HAD INSIDE DAMAGE WITH NO EVIDENCE OF CONTACT DAMAGE.
THEN I BOUGHT ANOTHER SET THAT LOOKED PERFECT AND TWO WERE ALSO BENT. AGAIN ONLY ON THE INSIDE..
What tire and tire size did you use?Originally Posted by maxabo
As a matter of fact, NO they don't..!I was actually suprised to see, after a summer, that they still were nice & round!
Quote:
Will the CLS AMG type IV with an offset of et25 front and et28 rear fit an SL55?Originally Posted by carcommander
Will this offset make the wheels stick out more or be set in more?
Did MB ever make these in 18's?
The higher the (positive) offset the more "set-in" the wheels are. Originally Posted by FLSL55
Will the CLS AMG type IV with an offset of et25 front and et28 rear fit an SL55?Will this offset make the wheels stick out more or be set in more?
So if the original wheel is ET35, and the new wheel is ET25, then the new wheel will sit further out by 10 mm, and appear more flush with the fender, with the risk,of course, of hitting the fender and wheel well.
ET stands for Einpress Tiefe, German for offset.
