SL55/63/65/R230 AMG: SL55 Oil Change DIY
Old Dec 1, 2011 | 02:27 PM
solomed's Avatar
2004 SL55 AMG
Great. I'll get one on Amazon today. Did you also drain the oil from the plugs also to see how much was left over, if any, after you sucked it out?
Old Dec 1, 2011 | 03:13 PM
Benz-O-Rama's Avatar
No need. It gets 99% of it out.
I change mine every 5K miles in my SL600, and every time I get 8.5 qts out. The Mityvac has liter markers on the side of it, so you can see how much comes out. My car burns damn near zero oil in between changes.
Old Oct 16, 2018 | 10:24 PM
dTsL's Avatar
@sl500 04' @slk230 AMG 02'
Originally Posted by chiurw
The Mercedes dealership told me that most of the oil could be drained from one drain plug but that was BS. They also tried to discourage me from changing the oil because it would "mess up" the engine computer and it would cost $1200 just for the computer. I checked my invoice from last year's oil change at the dealership and it showed they replaced one copper ring so they only drained about half of the oil, yet they charged me for 9 quarts. Hope this helps!
Robert
glad there are people like you, pissing on the dealerships faces.congrats
Old Oct 17, 2018 | 10:02 AM
kittyandgary's Avatar
2003 SL55 AMG
Since it wasn't posted here, the best $$ value for Mobil 1 0W40 oil is at Walmart. Five quarts for about $25. Occasionally Mobil will have a promotion, and you can buy 5 quarts (maybe two 5 qt jugs, I've forgotten) for less than $20 each.
Having changed the oil in my SL55 3 times since purchase, I do not understand how the vacuum can drain the oil that is in the front of the two portions of the oil pan. I am fortunate to have a 2 post asymmetric lift, so my car is level when the oil is drained. Seems that if I drain the rear area via removing the rear drain plug first, at least a quart comes out the front plug when I remove it.
Gary
Old Jan 29, 2023 | 02:14 PM
Tomcat SL's Avatar
2004 SL55 AMG
I got 9.5 quarts of oil out of the two drain plugs...probably 3/4 quart or more out of the front/side AFTER the rear quit draining.
Old Apr 21, 2024 | 01:29 PM
Chris_87_300D's Avatar
MBZ 87 300D, 08 SL55
Vacuum method can't get all of the old oil out
Post deleted, redundant.
Last edited by Chris_87_300D; Apr 21, 2024 at 01:31 PM. Reason: Issue addressed in previous post that I missed.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
