SL55/63/65/R230 AMG: SL65 Engine cover question
Old May 5, 2009 | 04:39 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
Have a problem with a cover that has several spots from battery acid being dripped on.
My question is, has anyone been sucessful in refinishing the silver part of the cover.
What say the experts?
I know the option, $1400.00 to replace.
Old May 5, 2009 | 05:00 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
I was thinking of bead blasting to blend the affected area or should it be painted?
How did you get battery acid on it? I usually leave the engine cover off the car and leave it in the garage. Not sure how to refinish it..
Tom
Old May 5, 2009 | 05:07 PM
Oxygen's Avatar
W220 S65 AMG
I needed to remove the AMG logos and the signed plate from the cover so I had the body shop fill the indents, smooth it, prime it and paint it with the same hard ceramic paint as it was originally:
Old May 5, 2009 | 05:16 PM
BeltFedBob's Avatar
Tom
I didn't do it, the dealer did it when they changed a bad battery.
Old May 5, 2009 | 05:17 PM
BeltFedBob's Avatar
He wants to keep all the do-dads.
Thanks for the info!
Old May 5, 2009 | 05:20 PM
Oxygen's Avatar
W220 S65 AMG
Right so you guys need to remove the said do-dads, refinish the cover and the apply the do-dads again.
Old May 5, 2009 | 05:25 PM
TMC M5's Avatar
I thought the SL65 had the battery in the trunk like I have in the CL65.
Tom
Old May 5, 2009 | 05:48 PM
BeltFedBob's Avatar
Tom
Two, one up front to start the engine and the one in the trunk to power all the toys.
Old May 5, 2009 | 07:39 PM
Thericker's Avatar
V12-Biturbo
Why'd you replace your stock 600 cover? The CF on the 65 model has zero cooling effects since it's not carried under to airboxes Did you remove the AMG labels off your Calipers too? looks like you have completed your S600 to S65 transformation...
Old May 5, 2009 | 08:21 PM
Oxygen's Avatar
W220 S65 AMG
Hmmm.. the covers are interchangeable in under 30 seconds.. so why not? I think the CF looks mean.
Yes I actually wanted to repaint the calipers and put the Mercedes-Benz logo on there instead like on the SL600/SLR.
Check out this shot...
Old May 5, 2009 | 08:29 PM
Thericker's Avatar
V12-Biturbo
That's koool! You've done a great job! even swapped out the reg Cluster for the 65 euro version, I'm just thinking you could've easily purchased the real deal S65 w220, if you added $$ all these extra bits up to your original purchase of used S600...
Old May 5, 2009 | 08:32 PM
Oxygen's Avatar
W220 S65 AMG
No I don't think so. This stuff is not cheap - true, but when I bought my car the price difference between an S600 and a S65 with the same miles and condition was many times greater than what I paid for my upgrades.
