SL55/63/65/R230 AMG: SL55 owners need to ask a favor!!
Old Oct 6, 2009 | 08:11 PM
santomen's Avatar
would you mind going to your car and start it put it in drive select sport mode and by useing your shifter buttons on the steering wheel see if you can change it from drive to 4th,3rd,2nd,1st and back please!! Pat.
Old Oct 6, 2009 | 09:08 PM
manithemoneyman's Avatar
SL55
You cant, the buttons on the wheel only work when in "manual" mode... at least on my car.
UPDATE: this is only for 2003 model years...
Old Oct 6, 2009 | 09:14 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
Mine works in sport or comfort modes.
No, the left button will put it in first then the right button shifts it from 2,3,4,D. When driving the left will drop it 1 gear per push of the button.
Old Oct 6, 2009 | 09:25 PM
Thericker's Avatar
V12-Biturbo
my SL does it in both C/S also both left & right buttons behind steering wheel upshift & downshift.
Old Oct 6, 2009 | 09:33 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
03's had paddles that only functioned with the C/S/M mode in Manual. 04 and newer functioned regardless of mode selected.
Nick
Old Oct 7, 2009 | 06:57 AM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Nick
It does not have manual, you mean auto overide.
If you select 4 th gear it will overide and start in 1st or 2nd.
Old Oct 7, 2009 | 03:02 PM
Thericker's Avatar
V12-Biturbo
Why do you even post? All your content is either pro SL63 or ripping on any 600/65 models? To top it off you're 600/65 info is always wrong
The AMG models do have Manual mode, but the 04-up NON AMG models do shift manually as well, NOT over ride like you describe, if I shift gear selector into say 4th then tap padles dwn a gear it indeed shifts directly to 3rd, I can see it listed in Instrument Cluster.
If I want, I can shift thru all 5 gears manually up & down all day long thru shifter buttons, left button upshifts & downshifts same w/right button. It'll even hit the rev limiter & stall until I upshift if I leave it in say 2nd & wind it out to 5700 rpm's
Old Oct 8, 2009 | 08:16 AM
sound 8's Avatar
I never even mentioned the SL63, are you becoming paranoid!
Going on my experience my SL55 and my CL65 will change gear at the red line whether you want to or not, it will also not change down if it is too near
the red line. SL55 was 02 and CL65 was 04. However are you telling me that
a newer car with an auto box will just hit the limiter, and NOT change up.
On my car the left button was for down shift and the right for up shift.
Old Oct 8, 2009 | 10:45 AM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
YES.. Its called Manual mode
Old Oct 8, 2009 | 11:18 AM
sound 8's Avatar
Then it must be on cars after 04!
Old Oct 8, 2009 | 03:36 PM
Fantasm's Avatar
Car Whore
Even the SL63 will hit the rev limiter in manual mode and not shift.
Old Oct 9, 2009 | 01:20 PM
sound 8's Avatar
I realize this happens on a 63 because it has an MCT box, but an auto box has a torque converter so I can't see that proper manual mode can be achieved.
This is one that TMC-M5 could answer.
Does an auto box have proper manual mode?
Old Oct 11, 2009 | 09:35 AM
sound 8's Avatar
So when you are in your E55 in manual mode, when it hits the red line the
rev limiter comes in to play, instead of changing gear. Is That right
Old Oct 11, 2009 | 02:58 PM
lauer87's Avatar
E550
Old Oct 12, 2009 | 12:36 PM
sound 8's Avatar
Sorry, but I just want an answer!
Old Oct 12, 2009 | 05:06 PM
Thericker's Avatar
V12-Biturbo
Why do you need an answer from us? You already know everything
Old Oct 14, 2009 | 01:33 PM
sound 8's Avatar
Who is us? This is a forum where questions like mine are answered by other
members like you, no sorry you obviously don't know
But surely one member may know the answer
