SL55/63/65/R230 AMG: Removing front bumper - R230
Jack front of car off ground
Remove front wheels
Remove forward front wheel well liners and left and right front undertray filler panels and center undertray panel. (Many small screws and nuts. )
Remove grill (4 screws on top of grill) slide back and up.
Remove 2 screws on top of bumper at both sides of the grill.
Remove front left and right mesh grills. Remove 2 nuts behind the grills.
From inside fender wells, remove screw facing up very near wheel well lip.
Grab metal clamp near the place the screw was and pull inward toward engine. Then pull the metal clamp out. It clamps the bumper lip and front fender lip togather.
Unplug parking sensor harness plug, drivers side strapped to bumper liner.
Unplug fog light plugs.
Temp sensor will pull away on its own, when bumper is removed.
Pull bumper straight forward and remove, carefull not to scratch against fender and other parts.
Assemble same way. Replace temp sensor after install.
you jack under the front (or rear) rubber bumpers for jacking
and is "drivers side strapped to bumper liner" referring to the location of the connector for the park sensors?
I was removing it to try to get in behind to mount up hid fogs, which I did hook up for a test run, used the resistors that were supplied so no error lights, the one side I did was awesome for about 20 seconds, then I heard a loud pop and the resistor started smoking some horrible fumes that will probably give me some sort of cancer, not sure what happened there.
The parking harness does have a connector on the drivers side. but you should unplug it before you take the bumper off.
Your HID lights; I dont know what youve got. But the ones Ive used have a ballast, small metal box that the 12v will have to plug into. Your fog 12v will have to be used as the input for the ballast. Then the ballast feeds the HID bulbs. But There shouldnt be any problem with the load sensing a fault. there isnt a need for a resistor. I dont have any and theres no faults. Did the dealer you bought the lights from say you needed them?
If you want to explain that more maybe I can understand what you have.
You either have one of two problems.
It could be a bad capacitor.
Or you have it wired in reverse. Are you sure you have the + and - 12v wires right?
Either way, its burned and you have to get another one.
But its not going to work unless you have the + and - right. then follow their picture instruction sheels.
