SL55/63/65/R230 AMG: VRP825 SL600 DYNO, AFR, BOOST
Old Oct 28, 2009 | 12:02 AM
soulsearcher's Avatar
SL600 (1000 hp), Cayenne S, 996TT EVO GT750, F430 Spyder,A real Ford GT, 08 Gallardo Spyder
So I put 100 octane and went back to test per Marcins request. He wanted wideband, boost and torque (previous had none of that) so he can solve why this car did not make the expected 630-660 rwhp and crack 185-187 in the mile.
Notice the boost problem (Should be 23 )! Short test on Star came up clean.
NOTE: Fuel pressure feed is actaully boost.
HOW DO I INSERT PICS DIRECTLY INTO THE BODY WITHOUT LINKS
Attached Thumbnails VRP825 SL600 DYNO, AFR, BOOST-jc-boost-afr-4th-gear-rpm.bmp   VRP825 SL600 DYNO, AFR, BOOST-jc-boost-afr-4th-gear-speed.bmp   VRP825 SL600 DYNO, AFR, BOOST-jc-hp-tq-4th-gear-rpm.bmp   VRP825 SL600 DYNO, AFR, BOOST-jc-hp-tq-4th-gear-speed.bmp
Old Oct 29, 2009 | 02:20 AM
Thericker's Avatar
V12-Biturbo
I can't view your files?? what #s did you lay down w/100 oct? Is there indeed a boost leak?
Good Luck w/issues you're in great hands, Marcin is wicked smart!
Old Oct 29, 2009 | 03:06 PM
Thericker,
I really wanted feedback on the graphs. How do I insert the actaul pic into the body? Anyone?
No leaks found. Testing Map and wastegate adjustment today. This car has always been 30-40 rwhp low, even with Renntech so maybe the wastegates r an issue or the Map is reading boost higher than actual. Also checking for Vac. leaks. I bet it is the Wastegate
Old Oct 29, 2009 | 03:41 PM
Thericker's Avatar
V12-Biturbo
Thericker,
Try loading graphs to Photobucket.com then link them here...PM me if more help is needed
Old Oct 29, 2009 | 06:59 PM
blazeone's Avatar
2010 E350
I could see the charts, you can open them up in Photoshop or MS paint. Posted below. I would send them to the tuner and have them check it out. You are short boost, could be the ECU flash or hardware. I'd try the easy route first and have the tuner re-flash your ECU and then dyno it again.
You're only seeing a max of 18.8 psi. That is an issue and I would think that tune should pull 20-22psi? The drop off could be caused by high IAT's or fueling. It shows way rich 10:1 at max boost and then leans from there. Your hp line does not dive at the upper rpm range, so to me it looks like your max boost is too low and holding down your power output. Are you running mufflers?
Old Oct 29, 2009 | 09:58 PM
No mufflers, custom x exht.
Its not a fueling nor an IAT issue.
tune was set to be rich on high boost to be on the safe side. the tune has not been well tested on the 600 so 2 rich is better than 2 lean at this point.
here is the other 2 graphs (550 rwhp) in jpeg.
Attached Thumbnails VRP825 SL600 DYNO, AFR, BOOST-jc-hp-tq-4th-gear-speed.jpg   VRP825 SL600 DYNO, AFR, BOOST-jc-boost-afr-4th-gear-speed.jpg
Old Oct 29, 2009 | 11:00 PM
blazeone's Avatar
2010 E350
I have heard that removing the mufflers can cause a loss of 1.5 - 2psi of boost. This is second hand info so consult an expert. I do know that adding headers to a supercharged car will cause a drop in boost. They get power from the headers but lose some power from the boost loss. They fix this by going to a smaller pulley though.
Old Oct 30, 2009 | 12:11 AM
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
has anyone ran a dyno before and after cutting out the mufflers on an sl600 or sl65?
Old Oct 30, 2009 | 07:00 PM
x
I did with a Renntech tune. No change with or without.
Old Nov 5, 2009 | 07:09 PM
2003 S600's Avatar
2003 s600
I had my right wastegate rod nut fall off so the wastegate was always open, took 4-5000 rpm to make boost and exhaust was so loud. Found the problem and did double nut so it wont happen again. I have kleemann tune and max boost is 22.3 psi on Dashdaq.
