SL55/63/65/R230 AMG: AUX input and Ipod help??
Old Oct 29, 2009 | 05:36 PM
Grk-AMG's Avatar
2003 SL55 AMG
guys i found the input and i just dont know how to get it to work i read all the posts on this but it doesnt really help me cause im not familiar with the car iv only had it for about 2 days now
p.s sorry to sound like a noob but i just couldnt really figure it out
Old Oct 29, 2009 | 07:08 PM
Grk-AMG's Avatar
2003 SL55 AMG
nevermind i figured it out
Old Oct 29, 2009 | 07:18 PM
cal1's Avatar
SL55, ML500 & Acura TL
I hope you are referring to the jack in the glove box. That is the AUX port. On the left side of your command display is the SVC button. Press the SVC button and then rotate the right side dial to scroll and highlight SYSTEMS SETTINGS. Now press the right side dial in. You should now see an AUX option. Use the right side dial again to scroll by rotating and highlight AUX. Press or click the dial again. You should now see AUX on the screen. Turn on your I-pod and enjoy.
If my recall isn't accurate enough for you to follow, PM me and I will get you better step by step info.
Good luck
Old Oct 29, 2009 | 07:19 PM
cal1's Avatar
Cool, glad you figured it out. I was a few minutes late with help
Old Nov 2, 2009 | 10:34 AM
Grk-AMG's Avatar
2003 SL55 AMG
Thanks anyway for your help
Old May 8, 2013 | 01:31 AM
traumadoc's Avatar
2022 AMG SL 63. 2021 APR stage 1 Audi SQ7.
Thank you...
Almost 4 years later, I needed the same help! thank you!!!
Old Jul 2, 2016 | 09:45 PM
m-svt-amg's Avatar
2003 SL55
Does anyone know if the svc aux in signal is analog, or if it converts to digital in the amplifier like the radio?
I ask because the eq settings do not save and it also does not have the same settings as the bose surround...
If the aux in is purely analog, the sound quality will improve from using a DAC such as the oppo ha2 between the ipod and the aux connector.
If there is a digital conversion in between, the ha2 likely wont help at all...
Does anyone know for sure?
Thanks!
Old Jul 4, 2016 | 08:31 AM
32of32's Avatar
2016 Audi Q5 - 2015 E63 AMGS - 2010 Acura TL SHAWD - 2009 VW GTI - 2004 SL55 AMG
My '04 does not have an aux input in the glovebox. Is there another option to connect an iphone/ipod to the AUX?
Old Jul 4, 2016 | 10:55 PM
m-svt-amg's Avatar
2003 SL55
Ive heard you can add one, but im not sure as the 04+ has a very different audio system
