SL55/63/65/R230 AMG: New best tonight!! 2006 SL65 AMG
Time to start adding some mods....... I was told to look into a company called Eurocharged. Anyone heard of them?
PS, Very nice times! Looks like you spun some , so 11.4`s should still be there with a little more traction..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
For comparison, I'm running 11.5x at 120 in my Eurocharged tuned SL600, with a 1.79 60'. You should be able to run that same E.T. in a stock SL65.
Traction control is what's limiting your 60' time to 1.9x. Try using a little less throttle next time...just enough to keep traction control from engaging. With practice you should be able to drop a couple of tenths off the 60' time and .3 to .4 off your 1/4 mile ET.
I was the guy in the Redskins hat hanging out with the Eurocharged crew...
Best ET to date in my SL600 is listed in my sig.
11.15@125. Your car should be close to that with a good launch and great air. Good luck!
Jerry called me from the passenger seat of your Lambo a few days before the Mile. Said he'd never ever, felt a car pull like that.
Car is sick. I'd like a shot at your SL65 though?
So far tonight in the SL65.... 11.70@121.69
