SL55/63/65/R230 AMG: Dyno'ed the SL55 today
My first impression was... "I though this thing would be faster" Other than that, Its a super nice car, I like it alot.
Today I hit the dyno.. I guess I was expecting more power
I made 385whp and 450wtq.. Thats 100whp and 130wtq less than my lighter C55... Maybe that why Im so jaded about these numbers.
Thats like a 30% or something driveline loss???? whats up with that?? IC pump is fine, everything looked to be in good working order.
Im going in for a software update from the dealer, Maybe that will help some. My brothers CLS55 made 420whp and 450wtq Stock. All he had was the latest MBZ software. We will see what happens
As of right not I got a whopping 385whp.
Lets let the modding begin
how dirty are the intake filters? you sure the i/c pump is fine? was it heat soaked while putting those numbers down...did you see it pulling timing anywhere while on the dyno? those do seem like low dyno numbers.
just a few things to check and cross off the list :P
gl and grats
Make sure your Intake Temps are below 120 at the start of the run.
You didn't say if it was a dynojet or Mustang dyno....
Your brothers car is strong. You should see anywhere from 405-415 for a normal 55 engine.
I don't know what's up with the CLS55, sounds like a super freak engine
If it dynoed 420 whp on an already low-reading dyno dynamics, I would expect it to dyno at 450 to 460 whp on a regular dynojet
Has he taken it to the track yet?
The dealer I bought the car from sent it to me with a full tank of gas. I should have known better. A 2005 with only 25k on it. Might have done some sitting around before I bought it. My guess is the dealer or someone topped the car of with some 87oct or something. Thus killing the power of this car.
All is now well in hooleyville power wise.
However, I had to track down a leak that was found by the rear drivers side tire. Turned out to be the ABC reservoir seal. It was tracking all the way back to the rear of the car.
Little off topic, but thought I'd try you here... We have your old C55 at our shop and are slowly peicing it together. Just wondering if you can give us a heads up on any info or parts you might have around. Namely looking for the ECU. Our customer would like to purchase the ECU if you've got it by chance or know where it might be. Subframe is on the way now along with oil pan and much of the front end. Would really appreciate if you can let us know any lines on the ECU. Thanks and enjoy the new SL!
