SL55/63/65/R230 AMG: Anyone know the Part # for the Upgraded Bosch Intercooler Pump
Old May 22, 2010 | 10:38 AM
NikleinR6's Avatar
08 ML350, 2011 E550 Cab
I have searched and searched and cant find it.
I have heard that Merc changed their design 3 times and have finally perfected the intercooler pump. I have also heard that the newly designed Bosch pump is better than the Johnson CM30.
Anyone have the part number for the new pump?
Nick
Old May 22, 2010 | 12:34 PM
mf1's Avatar
mf1
2003 sl 55 amg, 2010 RRS TDV8
I had my waterpump replaced last summer at the stealer. Original Bosch Kuehlwasserpump (242,16 € + labor). It failed more than the first one. Replaced it by a CM 30 and never had an issue again and 50 % cheaper.
Old May 22, 2010 | 12:37 PM
Sathinas's Avatar
S65
I agree with mf1. Go with a Johnson pump. I've been reading up on them (here and elsewhere), and I think I'll be purchasing two of them shortly.
Old May 22, 2010 | 01:28 PM
NikleinR6's Avatar
Read some of the info here...
https://mbworld.org/forums/w211-amg/...ses-bosch.html
Maybe it will change your minds...
Maybe not.. I am just doing alot of reading and i was positive i want to "Upgrade" to the Cm30, but now I am not so sure its an upgrade...
Nick
Old May 22, 2010 | 02:24 PM
Sathinas's Avatar
S65
Good read, thank you.
Will be doing more research now. Damn you!
Old May 23, 2010 | 02:03 PM
mf1's Avatar
mf1
Here it is : realy don't know if this is the bigger version
http://www.siliconeintakes.com/produ...oducts_id=1001
Old May 23, 2010 | 03:34 PM
FLSL55's Avatar
SL65
The CM30 can't keep up to the heat demands like the new OEM Bosh pump.
The CM30 might flow similarly but under higher load and pressure it can’t keep up to the OEM one.
I use a scanguage II and the IAT's skyrocketed when I used the CM30.
The dealer replaced my CM30 with the updated (7th gen) OEM pump and my car picked up 4 MPH at the end of the 1/4 mile. YES that's 4mph or roughly 40rwhp!
If you care about true performance then get the OEM pump. It's hard to feel an actual seat of the pants difference, but a dyno or 1/4 mile trap speed will tell the tale.
Old May 23, 2010 | 04:26 PM
NikleinR6's Avatar
The dealer replaced my CM30 with the updated (7th gen) OEM pump and my car picked up 4 MPH at the end of the 1/4 mile. YES that's 5mph or roughly 40rwhp!
If you care about true performance then get the OEM pump. It's hard to feel the actual seal of the pants difference but a dyno or 1/4 mile trap speed will tell the tale.
Happen to know the part number for the 7th gen OEM pump?? How much can you get one for???
Nick
Old May 23, 2010 | 07:44 PM
FLSL55's Avatar
SL65
look below....
Old May 23, 2010 | 07:48 PM
FLSL55's Avatar
SL65
Found it:
It states 000-500-03-86 Coolant Pump $567
Old May 23, 2010 | 09:27 PM
NikleinR6's Avatar
Found it:
Just looked it up. Genuinemercedesparts has it for 275. However, the part number says it is for the 5.5L V12 only. Not the 5.5K V8????
Nick
Old May 24, 2010 | 01:44 AM
maxabo's Avatar
2008 MB CL600. 2020 MB E300 de. 1987 BMW M535i.
Damndest thing;
I just bought two CM30's, for an upcoming project of mine;
A reservoir tank in boot, with theese two installed, as well as the OEM in front...
Bad idea..??
Old May 24, 2010 | 07:26 AM
NikleinR6's Avatar
I really don't know.. I have searched through dozens of threads that tell you to get the cm30, and that its the best thing ever...
Now I am starting to find people saying the new updated stock is the way to go. I ordered my cm30 a few days ago. Now i am not sure what i want to do either.
Old May 24, 2010 | 11:52 AM
FLSL55's Avatar
SL65
I tested the OEM back to back with the CM30. The OEM brought my intake temps down faster and kept them down longer during 1/4 mile runs.
Heat = HP loss on our cars big time!
RENNtech also says the CM30 doesn't work well in our cars for max power.
The pump is easy to swap out and bleed. Why don't you guys test it as well. I could have had a bad CM30.....who knows.....
Maxabo,
I think in your application the CM30 will work just fine.
Old May 24, 2010 | 12:12 PM
Sathinas's Avatar
S65
http://www.trademotion.com/partlocat...&siteid=215078
Old May 24, 2010 | 02:28 PM
Sunir's Avatar
SL55 AMG
good thread...interested in this topic as well so I'm subscribed
put the pn 000-500-03-86 into mercedesparts.com and it says for the 2007 - 2010 MB 5.5L V12???
wondering it it's all interchangeable between the IC pumps for the sl55 and sl600?? anyone can confirm this?
Old May 25, 2010 | 12:19 PM
Auraraptor's Avatar
And conversely, if later V12 pumps work in our older cars.
Old Dec 27, 2012 | 07:56 PM
RNSL65's Avatar
SL65 AMG, X5-4.8i M-Sport, 530D, 528i
Interesting information on intercooler pumps:
http://www.zzperformance.com/blog/intercooler-pumps/
Rolf
Old Dec 30, 2012 | 10:11 PM
nidyanazo's Avatar
550HP+ ///AMG CL55 Kompressor, Ducati 916bp, Yamaha R1 WSBK replica
The upgraded pump ends in 010.
Old Jan 9, 2013 | 08:42 PM
B-tsai's Avatar
CLK320, ML550, SL55, GL450
0 580 000 010 seems to be the new part number for anybody whom was still looking.
(Caveat.. I can't seem to find it online on oem parts' websites)
Old Jan 9, 2013 | 10:13 PM
nidyanazo's Avatar
No that's not it.
The correct, HI Flow number is:
0 392 022 010
Here's my installation instruction video:
Old Mar 10, 2013 | 11:26 PM
g9s8r's Avatar
1998 Acura Integra GSR-T
youtube
Says video is private.
Old Mar 10, 2013 | 11:48 PM
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
What did you want to know? It's a very simple install. Clamp the two hoses going to the pump, remove the 4 screws holding the pump, remove the harness clip from the rear, and then install the new pump.
Old Mar 10, 2013 | 11:55 PM
g9s8r's Avatar
I think I just wanted something to do and decided to watch what he had to say or do. LOL. Besides, I like visuals.
Old Mar 15, 2013 | 10:18 AM
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
If anyone needs a pump, let me know, I believe I have an extra in my tool box I would sell, I had it replaced and after 5k or so I went to a bigger heat exchanger and pump setup, this was replaced a year about two years ago and has been off for almost a full year
