SL55/63/65/R230 AMG: Can't rev higher than 4000RPM
Old Aug 19, 2010 | 03:20 PM
Erunithug's Avatar
2003 SL55 AMG
I was driving my SL55 last week when I decided to step on the gas hard. The car jumped and got to about 30 MPH when all of a sudden it lost all power and came almost to a complete stop. I pulled over, turn it off and on, and the car wouldn't rev passed 4000RPM; not in P, N, or D. I called the dealer and they said it needs to be towed in and they have no clue what the problem is, but its in "limp mode" right now and won't know whats wrong until they see it. Any ideas?
Edit: No check engine light on.
Old Aug 19, 2010 | 04:17 PM
sprins's Avatar
G55, SLS, smart eq
Might be the intercooler pump.
In N and P there is a rev limit I think.
Old Aug 19, 2010 | 04:18 PM
Sunir's Avatar
SL55 AMG
i dunno sounds kinda wierd I think ...def get it checked out. And let us know what it is...I'm curious to find out.
best of luck to you
Old Aug 19, 2010 | 04:28 PM
AdrockTT's Avatar
SL65
Does sound like limp mode (as that's the description from the manual of what to expect in limp home mode). IC piping always a good place to start as loss of vacuum will cause similar symptoms.
Old Aug 19, 2010 | 04:56 PM
Erunithug's Avatar
2003 SL55 AMG
thanks for all the responses... I'll let you guys know what happens.
Old Aug 19, 2010 | 06:33 PM
Thericker's Avatar
V12-Biturbo
I'm bettin' Coil-Packs... Chk engine light will be intermittent..
Old Sep 15, 2010 | 11:06 AM
lippu70's Avatar
2015 mercedes E63 AMG, 2002 Rolls Royce LOL, 1997 Mercedes 300 TD
I was told by Mercedes mechanic that while stationery the engine will not rev. up more than 4000 revs is to protect the compressor.
Old Sep 15, 2010 | 12:00 PM
M3nv's Avatar
Yup, car will go in to limp mode to prevent any damage to the motor. Let us know what happens with the dealer.
Old Sep 16, 2010 | 02:27 AM
lippu70's Avatar
Hi M3nv the Dealer said that that the engine is governed to rev only up to 4000 while you are stationery,that is if you press the accelerator while the car is not in gear it will only rev up to 4000, if you drive the car it will rev more than.
