SL55/63/65/R230 AMG: Front pad question.
Old Sep 30, 2010 | 01:19 AM
maxabo's Avatar
2008 MB CL600. 2020 MB E300 de. 1987 BMW M535i.
Front pad question.
I need new front pads (SL65 from 2007).
The Stealership wants $600,- for those, here in Sweden.
So I called the "after-market-shop".
Theirs cost only $140,-!
BUT he said, according to his books, they are the same as to the 55's..!
Is that really true..?
Old Oct 9, 2010 | 10:18 AM
jmf003's Avatar
'03 SL55
I'd be skeptical about that.
I just had my rotors and pads replaced with Evosport's lightweight rotors and Akebono pads.
The Akebono pads are working well for me but another forum member had issues with his: https://mbworld.org/forums/sl55-amg-...rake-pads.html
Old Oct 12, 2010 | 03:30 AM
Tirreno's Avatar
SL55 AMG
As I understand it, commonly, the noise comes from using different pad compound on used rotors; the used rotors have residue of a different compound stuck to it. Remember that in order to minimize noise and increase braking power, you need to "bed-in" the brakes (a series of ~10 controlled hard stops and a cooling period) , especially when changing pad compound. The concept of bedding your brakes is to "bake" some of that compound onto the rotors.
Here are some alternatives:
- Get new rotors and pads: For street use, bed or don't bed your brakes.
- Get new pads for your used rotors: If you are mounting pads with a different compound, you'll need to bed you brakes or re-machine your rotors.
I'm getting Akebono Ceramic pads with new OEM rotors in a few days. Although I don't expect any problem and don't require a true bedding of the brakes, since the bedding will happen slowly as I use the brakes, I may still do a true hard bedding to accelerate the process...and it's fun!
Check out those articles/videos:
- http://www.youtube.com/watch?v=4adZE...eature=related
- http://www.zeckhausen.com/bedding_in_brakes.htm
- http://www.youtube.com/watch?v=kd_PtFJW3_g
