SL55/63/65/R230 AMG: Winter Storage Tips
Old Nov 23, 2010 | 11:42 AM
c54fun's Avatar
09 Mercedes SL 63AMG and 98 TT Corvette (702/775 @ rear wheels)
Winter Storage Tips
Consultancy has it pro's and con's, mine is taking me from Houston to NJ for the winter (ugh!). As a consequence, I plan on storing the SL63 until the spring. As I am new to my ride and storing it, are there any special precautions I need to take? I just had the B service completed; I plan on stabilizing a full tank of gas, tire cradles for the tires and placing a trickle charger on both batteries. I will cover it for sure. Any thing else, appreciate the help and thanks.
Joe
Old Nov 23, 2010 | 12:11 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
Joe
Befor putting the cover on it crack the windows slightly to take the pressure off of the gaskets and put a dessicant in the interior to eliminate any moisture . I would also put a rubber/vinyl protectant on all of the gaskets---doors, windows, trunk.
Old Nov 23, 2010 | 03:02 PM
c54fun's Avatar
Thanks for the input Lou, appreciate it.
Joe
Old Nov 23, 2010 | 06:24 PM
cal1's Avatar
SL55, ML500 & Acura TL
Hopefully someone else will chime in and verify, but I don't think you need the trickle charger on the main battery, just the consumer battery in the trunk. That is what I do for the winter and have had no issues.
Old Nov 23, 2010 | 06:53 PM
jmf003's Avatar
'03 SL55
I also use a trickle charger rear only and it's worked fine for me.
Old Nov 24, 2010 | 09:57 AM
c54fun's Avatar
Rear battery it is....thanks guys.
Joe
Old Nov 24, 2010 | 10:53 AM
sprins's Avatar
G55, SLS, smart eq
I'm going to have wooden blocks made to fit under the jack points so that when the ABC pressure eventually goes away, the car won't sink to the bottom. This way it'll also decrease pressure on the tyres.
Old Nov 24, 2010 | 12:20 PM
c54fun's Avatar
Something else to consider; many thanks.
Joe
Old Nov 24, 2010 | 04:10 PM
Sunir's Avatar
SL55 AMG
all good tips....are we missing anything? How long can fuel sit before it goes bad? I also hate the abc lowering the car if it sits for a while but seems like once it's fired up it's back on board and previous ride setting is restored. Any way without wooden blocks to fix this?
Old Nov 24, 2010 | 10:43 PM
lkirchner's Avatar
When I lived back East I would put Staybill in the tanks of my show cars when they went into storage in the winter. I!m not sure that with all of the additives today in gas that it is necessary but it certainly wouldn't hurt anything.
Old Nov 26, 2010 | 12:24 AM
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
i saw the results of gas that was stored over winter and it isn't good. If you value your car, a bottle of staybil is pretty cheap
Old Nov 26, 2010 | 06:43 AM
sprins's Avatar
G55, SLS, smart eq
What was the result?
Old Nov 27, 2010 | 11:38 PM
NEMES1S's Avatar
we put it in a beater car that was going to auction and it wouldn't start if it was cold out and gave it a ton of misfire and hesitation. I wouldn't suggest it, especially on a nice car
Old Dec 1, 2010 | 06:32 PM
Dee El's Avatar
2006 SL55 AMG 030
How long does it take for the ABC to lose pressure or "lower" the car? My 06 SL did not used to drop. Now after several weeks of not driving the car it will drop only at the drivers rear quarter and returns to normal position after starting the car.
Does this indicate a problem or is this to be expected?
Thanks for info or input.
Old Dec 1, 2010 | 08:05 PM
NEMES1S's Avatar
my car drops on the front driver's side, but the rest of the car appears to hold up ok
Old Dec 2, 2010 | 07:38 PM
Sunir's Avatar
SL55 AMG
they tend to droop down on one or more of the corders, I think it's because pressure in the system is relieved over long periods of time. I'm not sure if there has to be a leak of sorts for this to happen but I'm suspecting not because as soon as the car turns on and the pump is activated everything is ok again
Old Dec 7, 2010 | 11:23 AM
Dee El's Avatar
2006 SL55 AMG 030
When they do lower or drop down is it OK to leave them in that position or is some type of support or block system recommended to keep it elevated?
Old Dec 7, 2010 | 09:08 PM
cal1's Avatar
yes, your car should be fine in that position.
As Sunir stated, some cars with ABC tend to droop after sitting for awhile. I would not be concerned about it unless you are getting consistent ABC warning lights.
Old Dec 8, 2010 | 01:56 PM
Dee El's Avatar
2006 SL55 AMG 030
Great. Thank you very much for the reply.
Old Oct 22, 2015 | 11:00 PM
adam_benz33's Avatar
2003 Mercedes SL500
True from what I know but how do you fish the wire out of the trunk to plug it in the wall?
Old Oct 23, 2015 | 05:37 PM
TTtodd's Avatar
2005 SL65
This is what I do
Change the engine oil and filter
Fill with Sunoco 260 (100 octane unleaded)
Add Sta Bil and run until up to temp.
Set car up on jack stands and remove wheels.
Battery tender
Set the garage temp to 68
Now the car is ready for all the winter preventive maintenance and repair projects.
Old Oct 25, 2015 | 07:47 AM
amok55amg's Avatar
SL55AMG + SL600 + E320 + A180
Originally Posted by TTtodd
This is what I do
Battery tender
This is just after my head - engine oil + filter the most important and if there’s no heating, then a moister eater in the cabin but also in the trunk.
Old Feb 29, 2016 | 10:40 AM
Tomcat SL's Avatar
2004 SL55 AMG
My MB mechanic says that if you use a single battery tender, to keep the tender on the front battery (starter battery)...that way, the car always starts and the alternator will then replenish the rear battery as necessary.
Old Nov 30, 2016 | 06:32 AM
ston1058's Avatar
2012 E550
Another suggestion from my dealership was to put Styrofoam between the wiper blades and the windshield. The reason being to stop the rubber sticking to the to the glass. Cheap fix, will try.
Old Nov 26, 2018 | 02:10 AM
Das Geld 2's Avatar
SL55, S500
Seriously thinking of just disconnecting the battery instead of dealing with wires and charging and leaving my trickle charger outdoors for the winter
i don’t see it taking more than 20 seconds to resync the windows...it’s 2 seconds to connect and reconnect the battery...any other downsides?
