SL55/63/65/R230 AMG: Aftermarket Audio Install...
Old Feb 11, 2011 | 05:30 PM
  #51
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
Agreed, I am not 100% if that is the same way back to the 03 and 04 though
Old Feb 11, 2011 | 07:02 PM
  #52
MustGoFaster's Avatar
04 SL600
Set time
The 03 and 04 must have different programming. You can't set the time via the instrument cluster on the 04. I understand this can be done 05+
Old Feb 11, 2011 | 07:15 PM
  #53
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
That might be the case...my SL is an 06.
Old Feb 15, 2011 | 01:51 PM
  #54
JosanK's Avatar
2003 SL55 2007 S550
I have a 2003 SL55. I want to do a COMMAND replacement similar to what jmejones is doing. I am concerned that I will lose the dash clock (which is also the parktronic display). The 2003 offers no way to set the clock other than through COMMAND.
I have been told that if COMMAND is removed that a manual clock set menu will appear but I have never been able to confirm this.
Has anyone with an 03 or 04 replaced COMMAND? What happened with the clock?
Old Feb 15, 2011 | 02:34 PM
  #55
jmejones's Avatar
I haven't gotten an answer back from MBUSA tech support but I have a call into them. My car is still getting some finishing touches so I won't be able to check until later in the week. I will keep you posted.
Old Feb 15, 2011 | 04:49 PM
  #56
04 SL600
In my 04 with parktronic the clock works, but you can't set it.
Jmejones I would greatly appreciate it if you could post the response from MB
Old Feb 16, 2011 | 09:23 PM
  #57
jmejones's Avatar
Unfortunately from MBUSA..."Based on the information listed below, there simply isn't any additional course of action that can be recommended as the SL-Class clock is only set
through the COMAND unit directly for MY 2004."
Old Feb 17, 2011 | 05:59 PM
  #58
JosanK's Avatar
2003 SL55 2007 S550
Oh my. This is a problem.
Thanks for sharing the information.
If I upgrade COMMAND I'll have a clock that is wrong at least half of the year (daylight savings) or longer (battery removed, etc.). If I remove the clock I lose the front parktronic display.
Looking for ideas.
Old Feb 17, 2011 | 07:29 PM
  #59
jmejones's Avatar
To set clock unhook both batteries right before noon and rehook at noon (midnight). That will do the trick.
Old Feb 18, 2011 | 02:48 PM
  #60
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Save your money guys, the sound level in the cabin of an SL will be about
80+ db, with the roof down in traffic up to 90 db or more, the finer subtleties
of a good system are lost. However for posing at 30 maybe it's worth it.
Old Feb 18, 2011 | 02:54 PM
  #61
NEMES1S's Avatar
I am ok with it, for the most part I drive around at 35 in town and top is usually up on the interstate.....I am hoping to get done battling my insurance over getting keyed and then it is audio time!
Old Feb 18, 2011 | 03:00 PM
  #62
sound 8's Avatar
People who key cars should have their bol**cks chopped off, piece at a time.
Old Feb 18, 2011 | 03:02 PM
  #63
NEMES1S's Avatar
Agreed, and any insurance adjuster that tries to tell me some of the scratches on the roof are from the movement of the top also deserves a beating
Old Oct 1, 2017 | 07:23 AM
  #64
777ufo's Avatar
sl55 amg
radio double din trim
I would like upgrade my radio for pioneer avh-x8700bt but dont want any cutting to my console I try as you as you wrote
"installer.com $94.
Looking into all options. thericker actually has a great mod on his headunit that didn't require cutting."
http://www.installer.com/cars/by_car.php?carid=3724
and no success pls help
need radio double din trim for sl55 2003
Old Jun 12, 2018 | 03:20 PM
  #65
Rasite1's Avatar
Mercedes 2002 sl r230
Removing and replacing rear panel
UPDATE:
Well, just like at the very beginning in my excitement I bought too much s---t. The wireless cheetah laser readout was not needed after installed so we are re working the install for a more stealth look. This and weather has caused delays. The box built for the sub that will replace the rear panel behind the seats had to be redone. The installer wasn't satisfied with the first one. Also, those who own a pre-2005 know the dash piece goes around the entire unit. BIG problem because the double din kit is fits >2005 so we are trying to mod fit the dash, i.e. cutting the top off the carbon fiber dash kit and seeing if it survives enough to look good installed. Overall I'm extremely impressed with the creativity and craftsmanship of World Wide. If they got rid of my **** retentiveness and over eagerness with equipment...my install could have been done by now
Hi, i am interested in putting a speaker in place of the rear storage panel, i recall there being a metal mesh, how did you fit the new speaker in place of the storage panel?
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
