SL55/63/65/R230 AMG: removed the V6 replaced it w/SL55
Old 12-26-2010, 09:43 PM
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
I just had my V6 350HPamg engine tranny and more removed and replaced it with a very low mileage SL55 amg,, now i will be running a 3100lb car with a SL55 ,,without any mods the car will run in the low 11's ,,with pully intake tune ,,i's be in the mid 10.s come out to PBIR( Palm Beach International raceway) in late Jan and see if you can out run me LOL p jim
Old 12-27-2010, 06:08 PM
jmf003's Avatar
'03 SL55
Hey! That's great!
Old 12-27-2010, 07:56 PM
V12Godspeed's Avatar
Your worst nightmare...
Any videos?
Old 12-27-2010, 08:01 PM
kustom2k1's Avatar
03SL55
Wheres the build taking place? Im in for PBIR but I think i'll leave the SL home not a fan of being raped so... having a new turbo installed on my GN and tune.. mid to low 10's seems reasonable.. :-)
Big thumbs up and GL..
Old 12-27-2010, 09:53 PM
EXECMALIBU's Avatar
SL65, 427 COBRA (CSX-3127)73 911S, 246GTS (DINO SPYDER), CORNICHE,1962 PORSCHE TWIN GRILLE ROADSTER+
How are you dealing with all of the ECU, TCU, and other electronics?
I thought that all of the electrical components (ECU, TCU ETC) communicated through the can bus system using the vehicle chassis number...
I was told swapping and engine was not possible and required all of the electrical components to be linked to the same car/engine etc...
Are having custom software designed or are you able to use the SL55 engine ECU?
Old 12-27-2010, 10:53 PM
My understanding is that the crossfire is in an SLK or SL chasis and uses the same CAN bus system as mercedes...thats why it would be a fix without all the headaches, there still needs to be some changes but it will work. I think Rcompart (rudy) has another swap running around, I think this one belongs to one of the guys over at Speedriven if not mistaken.
Old 12-27-2010, 10:55 PM
Kreuzfeuer's Avatar
SRT-6
The same hands are involved in this project...
Old 12-28-2010, 10:02 AM
jmf003's Avatar
'03 SL55
+1. Crossfire is based on the R170 SLK, if I recall things correctly. A much easier engine swap than, say, putting a 55K into a Pinto.
Old 12-28-2010, 11:22 AM
amx1397's Avatar
My car is #3,third one completed this year, also he is putting a 55 supercharged engine into a c32 and not sure what car but it is a mercedes 4 wheel drive,, Rudy has mastered all the electronics, and made every thing work just like factory.in fact he also set the throttle on a progressivemode so that it takes 3/4 of a second from the time i floor it to wot. this way i will not spin that much and not brake anything. My car will be returned to me at the end of Jan.,, after a few miles to get use to it i will see you at PBIR I will post when i am going, jim
I was just informed the the next to receive a e55 may be a 05 c240 ,, and if not a e55 then a c32 amg V6 boy the things that can be done once you learn the computer system, and how to change it. I think this guy Rudy is the only person that knows how to rework the ecu system to make even a std shift transmission fit where there use to be an auto. jim
Last edited by amx1397; 12-28-2010 at 11:57 AM. Reason: to add year and mercedes that may receive e55 next
Old 12-28-2010, 11:36 AM
Kreuzfeuer's Avatar
SRT-6
That's awesome. Good to see some dot-org folks over here, Jim.
--John (JHM2K on the XF forums)
Old 12-28-2010, 02:33 PM
Sorry to hijack..
Rudy is a master! and I take nothing from him...but around my neck of the woods there is a guy named jeffrey who did this one for me. She has been upgraded with precision turbos and is complete in 2 weeks.
Moving her out of the Drive way...
http://s94.photobucket.com/albums/l1...nt=Running.mp4
At idle
http://s94.photobucket.com/albums/l1...ent=Idling.mp4
We consulted various times with Rudy and his advice was well appreciated.
Old 12-28-2010, 05:42 PM
320 dreamer's Avatar
2003 porsche 996 turbo
Sorry to hijack..
At idle
your pics didnt show up. i would love to see the car.
Old 12-28-2010, 08:32 PM
Max.H's Avatar
E55
Nice swap amx1397, should be really quick... Report back after you run the car on the track. Interested to hear your results.
Old 12-28-2010, 09:31 PM
Sorry, Links are fixed.
Old 12-28-2010, 09:57 PM
amx1397's Avatar
I don't know how Rudy does it but when you plug into the OBDII port it shows crossfire V8 here is a quote from someone that has inspection,,
"I have already done my first state inspection with the V8 and had no problem. They hooked up to the OBDII port and it read 2004 Chrysler Crossfire, 5.0 8cyl. and then it ran the normal test and all passed." so what ever he is doing it works. jim
Old 12-28-2010, 10:38 PM
moparrbust's Avatar
2005 Crossfire SRT-6
You're gonna have to change the emblems to "SRT-8" now.
Old 12-29-2010, 09:36 AM
amx1397's Avatar
I was thinking two srt4's = 8 just to be different.
Old 12-29-2010, 05:56 PM
blackbenzz's Avatar
haters crazy
+1. There is more to putting down a number than making power, good luck
Old 12-29-2010, 08:30 PM
amx1397's Avatar
true,, with the v6 I was running 12.2 @ 114,, 1.76 60" it just would not pull in 3 gear,,,307 rear you know.
I just got rid of my 12.7 @109 PT Cruiser. nubbers i keep tring. jim
Old 12-31-2010, 04:54 PM
amx1397's Avatar
new wheels to go with new engine.
Old 01-11-2011, 09:20 AM
amx1397's Avatar
here is the latest update,,,,a lot, well most of you know i am getting a 5.5 amg v8 motor and tranny installed into my black crossfire srt6.. here are some of the details,
I contracted with Rudy and Paul of accelerated industries to do the trun key operation,( transplant)
I shipped my car to Wi in Dacember 2010
Paul had a hard time finding me the engine i want,, he found it and he will get it for me in the middle of Jam 2011
the rear (wavetrac) i am hoping is done before the car is finished so Paul and Rudy can install it.
I contacted patrick( pte), and had him build me a 180 therostat for the 5.5 v8, and he is shipping it to Rudy today
Rudy is working on the lettering for the rear deck of the car.
the intake maniflods, and the intake will be teflon coated black the valve covers will be silver.
Rudy has some peformance parts that he will install,, like pully tune, some exhaust tricks so i can use some the srt6 exhaust.
I also purchased the wheels and tires from Rudy's srt6 before he sold it.
i have two sets of drag radials to use ,,313 35 17 and or 255 50 16 will test them both the best for the ve i keep as both with the 6 got me 12.20 ET.
now we wait!
Old 01-13-2011, 10:51 PM
04Fire's Avatar
'03 ML500 & '11 R350
Jim, that's sounding like it's going to be ridiculous!!
KEEP US POSTED
Old 01-17-2011, 10:08 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Very interesting project! I always thought the SL55 would be brilliant if it was a thousand pounds lighter.
How much heavier than the standard engine is the 55 engine? For all the power you will get, it may throw the car's balance off for anything other than straight line speed.
Old 01-17-2011, 09:01 PM
less than 100 lbs
Old 07-12-2011, 08:41 AM
amx1397's Avatar
car is done and everything is great the E55 is unreal in this car. my pic are too big to post , here is a link to some vedio's i did on street tires ,, Oh ran a 2.7 60' then a 11.89 @ 119
http://www.youtube.com/watch?v=xpl1p7R7PvU
http://s63.photobucket.com/albums/h1...V08212_amg.mp4
http://s63.photobucket.com/albums/h1...08213_both.mp4
Quick Reply: SL55/63/65/R230 AMG: removed the V6 replaced it w/SL55
