SL55/63/65/R230 AMG: Brake Pad replacement - True or false question
So true of false, you always change the rotors with the pads?
in addition to the profit motive of course
So if they are smooth and no ridges you can get another use out of the fronts and most people several uses out of the rears.
Since mb rotors don't have much in the way of excess they can't be resurfaced
That is why they need to be replaced if not perfect.
And yes the wear sensors need to be replaced but they are only a few bucks each
Why not diy?
As for your question - the rotors are designed to last as long as the pads. True, you can resurface them (a must with every set of new pads, not because of grooves, but because they must be machined back to parallel as due to caliper flex rotors never wear parallel) but after resurfacing the rotors they wont last another pad life duration, i.e. the rotors could very well reach min. thickness after the 2nd pads are only 50% used.
Don't skimp on your brakes, your life could someday depend on them working to their max.....
As for DIY - "don't skimp on your brakes, someday your life may depend on them!" - nuf said
Not track related wear at all.
And no you CAN'T RESURFACE THEM.
As to The DIY suggestion it ain't rocket science That's why brake jobs at the dealer are performed by kids just out of training class.
Frnt brakes Sl 550 takes longer to jack the car up on stands then it does to pop out the pads and replace them and the sensors.
Follow the Akebono bedding in procedure to the letter and be sure to use the paste and you will love the lack of dust.
Been doing my brakes on Benz for a bit over 40 years and they are as simple now as they were then and I'm still here.
Good place to start your Diy that way you won't be in shock next year when your SL is 5 years old and he hits you for A grand to replace $100 worth of off the shelf spark plugs.
Like i said most people get 2 uses out of the fronts(Full pad uses
the book does call for always doing rotors and pads, but in reality when rotors reach minimal useful thickness they will warp and start to "heartbeat" in the pedal when breaking from higher speeds. that is your clue that they need to be replaced.
replace pads only until the rotors warp. then replace rotors as needed.
your mileage will vary, but those are just my 2 cheap cents
alex
