SL55/63/65/R230 AMG: Serious IAT problems - S65 Eurocharged tune w/ upgraded Meziere pump - HELP!
IATs get to 145-165F just crusing arouond after 5 minutes! This even happens in 20-30 degree weather. WTF.
So i had the pump (wasn't Johnson pump) swaped out for a Meziere. NO DIFFERENCE in IATs.
Car feels lame and weak and is dead even to 1 car behind a STOCK E55 (I know its stock).
Just got the car checked by MBenz and they said there was an issue with the thermostat and they replaced it. Car still feels ****ING LAME.
What would you do at this point? Car has very very low miles. thanks.
The car is fighting itself because the tuned ECU is telling the engine to make huge power but the other systems get overloaded and some V12s often will go into semi-limp mode... The car still drives but at minimal (60-70%) power
This seems to happen more in lower temps below 70 degrees when the air is very dense...
The tuners are aware of these problems with some V12s and often will modify your tune (custom tune)to boost less or boost at higher RPM...
Interesting, i will talk to Jerry as i have the Eurocharged tune. Thanks for this information, very helpful.
One of the well known tuners has reinstalled his tune 4 times each time lowering/moving the boost thus changing the power curve...
This helped a lot! Finally they got it to where he only has the jolting loss of power problems when the ambient temp is well below 70 and in very thick air...
try turning your car off/on and see if this helps..
However I'll seen it a bunch of times, its the IC pump. Go back to the Johnson of even a stock pump. It should solve your problem.
I spent 1,200 ****ing dollars having it installed. I will do it again with the Johnson pump along with a larger Heat Exchanger but can anyone give me names of shops that don't charge and rape you? I got a quote that installing a HE would be $3K from Funktion auto. I have done ALL of my work there for the past 5 years but when the book time is like 4 hours and it ends up taking 14 I mean WTF.
thanks for your help!
Not sure what the size of the heat exchanger is on your S65, but my SL65 has awesome cooling with the Meziere and no other mods. I can watch temps (Scan Gauage II) and they rarely top 120 or so degrees with the car moving over 20-30mph. At the dragstrip temps get into the 140s-150s at the very end of the run. When I had a dead pump, they would rise to about 190 and get hotter from there depending on boost.
Not sure what the size of the heat exchanger is on your S65, but my SL65 has awesome cooling with the Meziere and no other mods. I can watchient to temps (Scan Gauage II) and they rarely top 120 or so degrees with the car moving over 20-30mph. At the dragstrip temps get into the 140s-150s at the very end of the run. When I had a dead pump, they would rise to about 190 and get hotter from there depending on boost.
Check out benz elite in alexandria, emile is pretty good and has very good pricing. Funktion auto is a rip off, I called them to lower my SL via star and they told me $700. Benz elite quoted me 110 for lowering and -10C mod
