SL55/63/65/R230 AMG: special care for superchargers?
None of that applies to a supercharger. It is powered by a belt or gears off the crankshaft, and no exhaust gasses get near it. So it doesn't get hot enough to coke its lubricating oil. It's still not a good idea to drive any car hard and then immediately shut it down, since there is a lot of residual heat buildup left in the block which can boil the coolant if left to its own devices, but the cool-down period for a supercharged engine is considerably shorter than for a turbocharged engine.
As to whether your car is turbocharged, I don't know, but your owner's manual should make that clear immediately. If the engine specs say nothing about a turbocharger, maximum boost pressure (measured in BAR) or the name of the turbocharger builder (it's not M-B), your engine isn't turbocharged.
Also, you could look under the hood - a turbocharger is easy to spot if you've seen one before. If you haven't, it may just look like intake manifold plumbing. You might be able to find it by looking for a gizmo near the top of the engine at the rear of the engine compartment that would fit inside an 8 inch cube and that says "Garrett" or "Rootes" on it. The name is cast into one of the plenums, not stuck on a placard.
In the early days of Porsche's turbos, they used to have a small electric pump that continued to pump coolant around the turbo to stop it cooking from the heat soak.
I am sure that MB thought about this when releasing the Bi-Turbo.
