SL55/63/65/R230 AMG: Check Key Battery???
Old Mar 24, 2011 | 10:02 AM
SRQLAW's Avatar
Hi Guys:
Long time... work/life crazy (but good). Went to start car today and got quick "Check Key Battery" then a "click" sound and then take car to shop warning.
Car does not start. Any suggestions or thoughts????
Thanks,
D-
Old Mar 24, 2011 | 10:34 AM
alx's Avatar
alx
replace your key battery?
i think they all are CR2025
Old Mar 24, 2011 | 11:30 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Yup! Easy fix. No reason for a trip to the dealer, unless you want to spen an extra $100!
Old Mar 24, 2011 | 11:34 AM
ohlord's Avatar
Did
you try your other key?
Then replace the 2 key batteries. pg 389 of your owners manual.
keyless go key? I assume,since the regular ir key does not need a battery to work in the ignition switch.
Old Mar 24, 2011 | 11:39 AM
SRQLAW's Avatar
I actually did not try the 2nd key. I was in a rush so I took my wife's X5 since she is out of town. I did nto realize the the failure of key battery would actually prevent the car from starting. Damn - I feel stupid.
THANKS!
Old Mar 25, 2011 | 09:32 AM
SRQLAW's Avatar
apparently there is something else wrong... seems like a battery issue - car will not start with either key...
Old Mar 25, 2011 | 09:40 AM
alx's Avatar
alx
it is possible that your main starting battery (front) is dead. if you have never replaced your battery and your car is an 06- it is about time it died. try to charge the existing one a bit and see if it makes a difference? if it does- you need a new battery. if it doesnt- take it to the dealer as your problem is deeper.
Old Mar 25, 2011 | 12:09 PM
SRQLAW's Avatar
I am thinking it is the battery. Oh well... any suggestions on the best battery for this car?
Old Mar 25, 2011 | 01:28 PM
alx's Avatar
alx
do not assume that it is the battery
as i said- charge battery and try to start car. if that does not work- take battery out and bring it to your local auto store- they can test it there. if it is bad- buy another one, if it is good- take car to dealer...
this is what i would do if i dont have the means to troubleshoot and repair car at home
