SL55/63/65/R230 AMG: Roof opening problem
Old Jul 24, 2011 | 02:16 PM
Champdelay's Avatar
SL 55 and Range Rover Sport Supercharged
One of the small flaps the must fold under the trunk lid in order to open and close the roof is loose and therefore triggers a sensor that prevents it from opening/closing. Mercedes says I have to replace both flaps and the system that goes with it for around $1,000. Does anyone know of an alternative? Thanks!!
Old Jul 24, 2011 | 02:47 PM
aluthman's Avatar
2003 SL55 AMG
They are probably full of **** and it can most likely be fixed with a $65 kit sold by MB. Do a search as this is a common issue and has been discussed before.
Old Jul 24, 2011 | 03:12 PM
Champdelay's Avatar
I hope you are right. Not sure how to do a search, please suggest a search topic or subject - I tried 'roof problem' but mainly found gear grinding issues.
Old Jul 25, 2011 | 10:15 AM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
Try a search under roof flaps
Old Jul 25, 2011 | 10:24 AM
jrgator's Avatar
ML63, ML320
the part number for the updated version is 230-750-01-11. In your search you can even find the instructions on how to replace it, and there are even pictures. My dealer did it under warranty, so I don't have the search info to help you. It's here, you just have to look.
Old Jul 25, 2011 | 07:57 PM
aluthman's Avatar
2003 SL55 AMG
https://mbworld.org/forums/sl55-amg-...y-fix-diy.html
Old Jul 11, 2012 | 02:02 PM
Champdelay's Avatar
roof flap not working
My roof flap dips as many of yours has. I understand there are some adjustment papers being sent around. Would someone kindly send them to me? Also, I understand there is an inexpensive part that can be ordered to do it ourselves should the adjustment under the flap not work...would someone also kindly send me the website and part number to order it from? Thanks a lot!!
Old Jul 12, 2012 | 10:16 AM
chiurw's Avatar
2006 Dodge Viper, 2006 SL55
Just follow the link that was previously posted and order the replacement part. I used it to replace the defective part and my flaps work really well. The adjustment procedure works only if your flaps are too tight against the trunk lid or a small gap between it and the trunk lid, but if the flap is loose and hangs down, then it's best to replace the part.
Old Jul 12, 2012 | 11:39 AM
Champdelay's Avatar
thanks! I ordered the part and it arrives Friday...hoping I can use my extremely limited Irish brain to install myself!!
Old Jul 12, 2012 | 01:59 PM
cal1's Avatar
SL55, ML500 & Acura TL
i suggest a few pints of Guinness prior to starting.
Just joking, the DIY is nicely done. You should have no troubles at all.
Old Jul 12, 2012 | 03:51 PM
Champdelay's Avatar
Indeed! A few pints of any Irish beer is a must before taking on technical projects of any kind!
