SL55/63/65/R230 AMG: 2006 SL 55 Retractable Top Problem
Old Sep 11, 2011 | 04:54 PM
mooneypilot's Avatar
2006 55SLAMG 2006 CL500 Previously 1968 280SL 1983 300D 1987 420SEL, 1997 E420, 1991 500SL
The folding roof on my SL55 goes down just fine. When I try to raise the top, the last step, folding the trunk lid down, it just stops with the trunk lid up. The red light on the top activator goes out.
In other words, the top mechanism appears to be OK, but something is wrong in the switches. Is there a way to recycle or reset everything?
I was able to do a reset on my SL500, but can't find anything on the newer SL. Or is it time to call my friendly mechanic?
Old Sep 11, 2011 | 05:28 PM
cal1's Avatar
SL55, ML500 & Acura TL
Check out this link: https://mbworld.org/forums/sl55-amg-...y-fix-diy.html
This is a common problem on our SLs. I just had a flap replaced under my extended warrantee six months ago.
You might check the flaps when the top stops closing and see if one of them is jammed. When this happened to me, I was able to gently move the flap out of the jamb and then activate the closing switch and it closed the rest of the way.
Old Sep 12, 2011 | 01:16 PM
rsr911's Avatar
2003 AMG SL55, 2002 AMG CLK55, 2002 AMG ML55, 2005 ML350, 1995 S320 LWB - totaled
Perfect fix for my SL has the same issue exactly.
Many Thanks -O
