SL55/63/65/R230 AMG: 20" wheels with 295/30/20?
Old Sep 29, 2011 | 09:39 AM
EsEl's Avatar
2003 SL55
Guys,
I am interested in upgrading my SL55 from the AMG 18" wheels to either 19's or 20's. I am leaning towards the 19's for concerns about ride quality but do agree with most of you that the 20's would look better on the car.
So..if I went with 19" wheels I would get a 305x30x19 rear and all would be fine regarding staying compliant with the rolling diameter. But I have read that some of you are running a 295x30x20 rear with a 245X35X20 front which provides for more of a sidewall / air cushion (just like the 19" set up) but are a 27" diameter set up instead of the 26" diameter spec.
My car is not lowered so my question is if you think this would mount on the car without any rubbing issues? Any other issues other than some minor speedo calibaration might be required?
Thanks...David
Old Sep 29, 2011 | 12:05 PM
150shot's Avatar
08 CLS63, Honda Accord, 04 911
it shouldnt, i am moving to this size and I am lowered with links. Sidewall construction ( rounded vs squared off) can make a diff, but it looks like I've got space.
Old Sep 29, 2011 | 01:22 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
Originally Posted by EsEl
Guys,
Thanks...David
If the offsets are correct you will not have any problems. My SL has 305 x25x20's on the rear with no issues.
Old Sep 29, 2011 | 03:52 PM
threeMBs's Avatar
Only MBs - the best or nothing
How is that helpfull to him? He's asking about issues running 27" diameter at the rear, you're running stock 26".
Old Sep 29, 2011 | 04:52 PM
lkirchner's Avatar
Go to the 1010 tire size calculator and the 295x30x19,s are 25.96" in diameter and the 305x25x20's are 26.0' in diameter. That is how it is helpful.
Old Sep 29, 2011 | 06:36 PM
EsEl's Avatar
2003 SL55
Thanks for the replies, guys, but I am trying to understand if a 295x30x20 will work because it is a 27" diameter tire.
150shot...when will you be putting them on your rims? 10.5 or 11" rear? 9 inch front?
Old Sep 29, 2011 | 06:38 PM
threeMBs's Avatar
I intentially left out tire sizes in my reply since I knew that's what you were refering to and not to what he wanted to know.
His question was about 295/30-20 which is 26.96". Read his question, its at the end of his post. He knows about 19", he wants to know about 20" with increased tire diameters to have more sidewall.
To the OP: I do know that 245/35-20 front and 285/30-20 rear produce no rubbing issues to speak of on a stock hight R230. I do not know about 295/30-20.
Old Sep 29, 2011 | 07:07 PM
Pomppe's Avatar
SL 55 AMG 2003
I run with rear 295 / 30 / 20", 10,5" wide rim, front 245 / 35 / 20", 9"wide rim, with Carlsson suspension lowering kit. NO problems with rubbing, or anything else, not even with lowest mode. No speedometer correction needed either. Everything is nice and smooth.
Old Sep 30, 2011 | 07:41 AM
EsEl's Avatar
2003 SL55
Pomppe...do you happen to know the offsets you used on your rims? I assume they were different from the stock offsets, due to their size, so that is why I am asking.
Thanks!
Old Sep 30, 2011 | 10:46 AM
Pomppe's Avatar
SL 55 AMG 2003
First correction. Front wheels are 8,5" wide, not 9". ET is 32 all round. AMG brakes almost touches the wheels, so I´m thinking to put 1-2 mm spacers in the rear, but so far all good.
Old Oct 2, 2011 | 11:14 PM
sprucegoose's Avatar
03 SL500, 07 S550, 92 500SEL
too close for comfort
Guys,
Thanks...David
Hi Dave,
I have 255/35/20 frnt and 285/30/20 rear. I have not had any scrubbing but what I do have is a wheel that sticks out past the fender.... not very attractive. Just got the car and 20s are just way to rough. I'm going back to the stock setup 255/40/18 and 285/35/18 as soon as I sell these wheels and tires on eBay or I wear out the tread. My setup exceeds the three percent rule for brake safety and the larger diameter also stresses the tranny and drive train. My speedo reads 3 MPH low so tickets are always a possibility. You seemed to be leaning towards the 19s and I'd go for that as any sidewall at all will help the ride. Mines sticks to the road like glue and makes 90deg turns at speed but they are rough and noisey. Use the calculator at 1010tires.com, and just solving for the diameter is only half the battle. The offsets might save your calipers but put you outside the fenders like mine. UGH! I don't have the offsets for my lowenharts but they only clear the fender by fractions. 305s are going to be pushing it. A word of caution about getting the wheels... make sure you get to try them on first. I know of a couple of cases where the EXPERTS at some of these tire dealers had little or no information on MBs and made a lot of assumptions on offsets and the buyer was then was forced to eat the two rear tires on his 600SEL due to scrubbing.
