SL55/63/65/R230 AMG: Anyone have a front mount HE installed?
Old Nov 2, 2011 | 09:56 PM
kustom2k1's Avatar
03SL55
Anyone here have one installed? Whose HE and has it been beneficial?
Old Nov 3, 2011 | 09:54 PM
jmf003's Avatar
'03 SL55
Yep.
VRP, which is no longer in business AFAIK.
Keeps intake air temperatures a handful of degrees lower while in motion.
Old Nov 4, 2011 | 03:31 PM
kustom2k1's Avatar
03SL55
Thanks for the reply, Im trying to source one but no luck yet.
Old Nov 4, 2011 | 05:05 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
contact speedriven, they offer them
Old Nov 4, 2011 | 07:02 PM
jmf003's Avatar
'03 SL55
Eurocharged sells them, too.
Old Nov 4, 2011 | 09:13 PM
kustom2k1's Avatar
03SL55
I contacted Eurocharged in an email, have yet to hear from them. Will try SD... Busy on my end but, will try and contact by phone..thanks guys much appreciated for the info!
Old Nov 8, 2011 | 06:41 AM
NikleinR6's Avatar
08 ML350, 2011 E550 Cab
Create your own kit with a heat exchanger from Frozenboost.com.
You can pick up the HE for 150. Then all you need is some Hose.
The mod is WELL worth it!!!
-Nick
Old Nov 8, 2011 | 12:50 PM
cfi_luz's Avatar
2006 SL55
Which heat exchanger did you use? Also, what did you use to mount it (brackets?).
Old Nov 8, 2011 | 10:25 PM
gixxerss's Avatar
2005 SL65, 2012 Audi A8L, 1993 BMW 850Ci, 2004 Ducati 999S, 2008 Harley Softail Custom
Are you using the new HE in unison with the stock one?
Old Nov 8, 2011 | 11:28 PM
jmf003's Avatar
'03 SL55
Yes. Output from the existing into the new one.
Old Nov 9, 2011 | 12:16 AM
Benz-O-Rama's Avatar
What are you guys doing with the little oil cooler that's down there?
Old Nov 9, 2011 | 07:55 AM
NikleinR6's Avatar
Yes, they are used in series. The new HE will sit in front of the little oil cooler.
Old Nov 9, 2011 | 07:49 PM
jmf003's Avatar
'03 SL55
My supplemental HE is mounted to the bumper so it sits above and in front of the oil cooler.
Old Nov 9, 2011 | 11:27 PM
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
why I haven't done anything about this is beyond me. I make things like this. I live in Satan's home town and here I am running a stock heat exchanger. I just the other week upgraded my pump due to the MBZ stock pump crapping the bed. After 3 stock pumps it gets old fast.
Let me see if I can get my car in for this mod. I bet I can. Just pressure me to do it and it will happen.
Old Nov 9, 2011 | 11:59 PM
grane's Avatar
GLK350, SL63 AMG
What are the
Dimensions on the HE you choose? Is the tubing diameter MB size compatible?
Looks like a nice setup. Subtle!
-Nick
