SL55/63/65/R230 AMG: AMG 63 Aluminum paddle conversion gonna be plug and play for early AMG 55 models
Old Feb 24, 2012 | 11:00 PM
DCTMOTORSPORTS's Avatar
SPONSOR
W211 Estate
DCTMS is excited to release another great products for AMG cars
The AMG 63 paddle conversion module which can make the desirable AMG aluminum paddles plug and play to all AMG steering wheels with +/- pins in the front and silver buttons in the back. No more "hotwiring" conversion to these wheels
Since Mercedes AMG models share the same airbag module from W209, R230, W219 to late W211, The paddle steering wheels gonna fit all early years AMG55 cars without intense modification
With our paddle converter, these wheels will be an easy fit to the CLK55,SL55 and CLS55
contact us: sales@dctms.com
for product and ordering information
Attached Thumbnails AMG 63 Aluminum paddle conversion gonna be plug and play for early AMG 55 models-amg-paddle-conversion-module.jpg   AMG 63 Aluminum paddle conversion gonna be plug and play for early AMG 55 models-img_0349.jpg   AMG 63 Aluminum paddle conversion gonna be plug and play for early AMG 55 models-cls63-leather-sport_02.jpg   AMG 63 Aluminum paddle conversion gonna be plug and play for early AMG 55 models-sl55-cls63-wheel.jpg   AMG 63 Aluminum paddle conversion gonna be plug and play for early AMG 55 models-img_8577.jpg
Old Feb 25, 2012 | 12:49 AM
Auraraptor's Avatar
Email Sent
Old Feb 25, 2012 | 09:20 AM
rlh23's Avatar
2004 SL55
Can you PM me a price for the paddles in silver?
Old Feb 25, 2012 | 09:23 AM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
very innovative
Old Feb 25, 2012 | 01:49 PM
nir's Avatar
nir
2008 s63
wish you guys would have come up with that earlier! just converted my sls mercedes steering and the paddles were a pain.
Attached Thumbnails AMG 63 Aluminum paddle conversion gonna be plug and play for early AMG 55 models-sls-steering-compared.jpg
Old Feb 25, 2012 | 03:48 PM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
+1 I could use a set as well
Old Feb 25, 2012 | 04:54 PM
SPONSOR
W211 Estate
Nice! did you make everything work?
We tried fit a SLS wheel on CLS, too much work!
Old Feb 25, 2012 | 05:28 PM
nir's Avatar
nir
2008 s63
Yes, wheel is on car, paddles working etc.... . The only minor disturbance and one i can live with, is that at night, the left hand indicator is a little tight (close to wheel) to use paddles, although still works fine( during day I leave it in bright mode). You are right it took some thinking outside the box, but the girth and feel of the new wheel makes it all worth the effort. it feels like a new car! I will post a few pics next week. I Still wish I had ur solution as it would have saved some time.
Old Feb 25, 2012 | 06:25 PM
SPONSOR
W211 Estate
excited to see it!
Old Feb 25, 2012 | 07:04 PM
cij911's Avatar
one car at a time
Please send price for paddles and wheel - 06 e55.
Old Feb 25, 2012 | 09:00 PM
mdotpoker's Avatar
03 SL55,01 acura cls,05 lotus elise RIP
PM me the price for an 03 SL55.
Old Feb 25, 2012 | 09:38 PM
geeaccord's Avatar
E500(Sold), SL500(Sold), C350(Sold), ML350, SL65
PM price for 05 sl65..
Old Feb 25, 2012 | 09:40 PM
.trunzx's Avatar
2003 SL55, 1978 280SL, 2007 ML63
Do you have to cut into the wheel to make them fit? Also will it fit my DCT e55 wheel?
Old Feb 26, 2012 | 11:04 AM
CHP_H8_ME's Avatar
'03 SL55. Wife drives '06 SL500 and Range Rover Evoque
Me too please, sir, in silver
Old Feb 26, 2012 | 11:30 AM
okbarnett's Avatar
the install problem will be to fit the new style switch into the rectangular hole. It has to be wider, it wont fit as is. the rectangle panel should be cut up and trimmed to fit to the new switch. its a cut and fit job.
Old Mar 20, 2012 | 04:37 PM
SPONSOR
W211 Estate
With this converter, SL55/CLK55 owners can
1) buy the 63 AMG steering wheel with paddles in the back and make it plug and play to the column socket
2) Just like Member okbarnett said, using the existing 55 AMG wheel and do some DIY work to attache the paddles in the back
3) We can offer the total solution for conversion
Old Mar 20, 2012 | 04:41 PM
SPONSOR
W211 Estate
SL55 wood leather steering wheel with AMG 63 paddles
We now have this wheel for SL55 early models
with this wheel and our paddle conversion, SL55 owners can upgrade the wheel to 08~ type (AMG 63 paddles in the back)
Old Mar 25, 2012 | 06:40 AM
brandonq's Avatar
SL55 AMG
Pm for price?
Old Mar 25, 2012 | 12:06 PM
jobe's Avatar
sl500
can this be retrofitted to SL500 2005, currently no paddle shifters?
Old Mar 25, 2012 | 02:25 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
if the your 2005 SL500 can be option coded for the shift buttons that were used in 2005 SL55's .... then yes, this module will then allow you to use the new AMG paddles in your car. (additional support wiring may be required).
if option coding is not available, there is potentially a work-around that will allow you to use the new paddles in your car (again, along with the converter module)
If you want to PM me your VIN, I can see if I can give you a somewhat more specif answer for your car.
Chris
Old Mar 25, 2012 | 03:32 PM
jobe's Avatar
sl500
Chris
thanks, Chris
PM sent
Old Mar 25, 2012 | 07:21 PM
thanks, Chris
PM sent
I Checked your VIN in the EPC and found that if If I remove your datacard as a filter, shift buttons were called out (with option coding 428).
then, I looked on Ebay and found a 2005 sl500 sport .... that HAS shift buttons http://cgi.ebay.com/ebaymotors/Only-...item3f1559ef17 and checked its VIN in the EPC and it shows the shift buttons are applicable and that the car was option coded 428 and has the 7speed .... the implication is that your car could be coded the same and use the buttons (or paddles along with the converter module). I have to take a little time to compare the equipment on your car to VIN of the one in the Ebay add to see if you need anything else (support wiring, different TCU, clockspring or Jacket tube module) ... it is posible that your car would only need the coding .
I will look a little more when I get back in town tuesday or wednesday
Chris
Old Mar 25, 2012 | 07:43 PM
seattlekleeman's Avatar
Birel Shifter,2003 Ferrari ,1992 Mercedes 500E,Superformance Cobra,2005 SL55, 2004 996tt X50 PCCB
2005 SL55 conversion
Please send options for my 2005 SL55 wheel conversion.
Thanks!
Old Mar 26, 2012 | 08:12 AM
jobe's Avatar
sl500
Chris
thanks,-
Old Mar 26, 2012 | 06:21 PM
150shot's Avatar
08 CLS63, Honda Accord, 04 911
PM sent for price on this..let me know thanks
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
