hi is SL 55 amg transmission fit to SL500 engine?
I will install kennes bell supercharger to sl500 ... but I worry about transmission...
SL55's transmission fit to sl500 engine? at least bolt pattern..
and how about comuncation with ecu?
I think It will be no problem..
Thank you for reading
Former Vendor of MBWorld
shardul
close
- Join DateMay 2008
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive2003 W211 E55, 2003 W220 S600
Liked:295 Times in 244 Posts
yes it will fit you may need to reflash your TCU to accept the 722.643 SL55 transmission
Quote:
Wow amazing!! Thank you so much...
You are my saver..
BTW... SL55 and sl500 transmission is exactly same??
not bolt hole I mean all part...
Is it worth change transmission from sl500 to sl55. If I upgrade sl500 engine with supercharger My aim is 700 hp...
^___^ plz give me advice my gurus
Quote:
OH how about I change to SL55's TCU?Originally Posted by alx
He will need also coding password/ authorization to mate tranny to car.
How can get password?
shardul
close
- Join DateMay 2008
- LocationHouston
as long as the TCU has the software for a 722.643 you will be fine and will not need any password in DAS
you can also get the 722.649 which a transmission from a v12 TT cars they have a higher torque rating than the 722.643
yes they will bolt up. Make sure you also get the torque convertor for the same transmission.
a different new unit in the r230 of even identical transmission needs to be coded. i know that for a fact. you cant just swap transmissions as they are serialized. Originally Posted by shardul
as long as the TCU has the software for a 722.643 you will be fine and will not need any password in DASyou can also get the 722.649 which a transmission from a v12 TT cars they have a higher torque rating than the 722.643
i assumed that a different transmission model and unit will even more so require coding/ mating.
it is interesting to note that similar transmissions in the e class do not require coding/ mating- just adaptations reset and that is optional too. go figure. i do know that for a fact too.
come to think of it is it possible that brand new transmissions need to be coded (those are the only ones i have seen swapped) while already coded transmissions to some other car might be transplanted without a problem. not sure.
Wow....Wow..Originally Posted by shardul
Stunning!! If I need some mechanical help I definitly go to you..
Wow... You are master Wow..
ExploreQuote:
It's little problem for me... If I confront software issue.. I must reassemble transmission with new transmission part.. I think It's okay with it..Originally Posted by alx
a different new unit in the r230 of even identical transmission needs to be coded. i know that for a fact. you cant just swap transmissions as they are serialized. i assumed that a different transmission model and unit will even more so require coding/ mating.
Hmmm... mating.... It's bother....^____^ thank you for deep knowledge
