SL55/63/65/R230 AMG: overZealous1's build thread
Old Nov 1, 2012 | 05:06 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
how many miles do you have on your car?
Old Nov 1, 2012 | 05:18 PM
overZealous1's Avatar
sl55 amg
right at 70k.
Old Nov 1, 2012 | 06:25 PM
sl55 amg
this is what happens when i get bored waiting for parts. should look good in the car.
Old Nov 1, 2012 | 06:45 PM
Worth the wait's Avatar
2006 E55
Lord Vader, your boost is ready.
Nice work.
Curious, trunk tank and water injection? Seems like two stones to kill one bird.
Interested to hear your thoughts. Will you be using meth or ww fluid? Tuning for the injection or just for iat's?
Good luck with your project!
Old Nov 1, 2012 | 06:59 PM
sl55 amg
lol, thanks man.
aem recommends a 50-50 water/meth concentration. those numbers come from back in ww2 iirc when the military was testing it on the planes. that was the best combo to wart of heat and detonation. so in other words, yup, probably just ww! they said pretty much anything blue is the correct stuff and the correct ratio.
i am expecting to make alot of heat, so i am setting meth to come on at about 5psi, and full on at 10psi. will have to play with it to see where my final boost will be now and at what point i am making decent boost.
will wait for final tuning once i get my exhaust figured out and on. first tune will be a simple reflash from ec for the larger injectors. will just have to stay out of it till i get it on dyno for final tune.
then, once the nitrous goes on, all heat issues will be gone. i wonder if the iat sensor can read in negative? lol
Old Nov 1, 2012 | 10:36 PM
kustom2k1's Avatar
03SL55
OZ, is this work or play Where did you find the 82tb? Amazing the transformation made with some black paint. Going to be one bada55 engine bay. What paint did you use for the plastics?
Old Nov 2, 2012 | 12:08 AM
  #32
sl55 amg
i must admit, i have been skipping out on work lately to work on the car, haha. luckily my gf is interested in cars too, so i don't catch any flak for the long hours in the garage!
i got the tb off ebay. after talking with shardul, it sounds like the audi v8 one is just swapping 2 wires and can be had for $150 all day long too!! got one of his adapter plates and should be getting both tomorrow. only half day of work tomorrow so the latter part of tomorrow and weekend will be spent pretty much wrapping the project up.
the paint on the blower i used gloss black engine enamel. pretty tough stuff once cured! the plastics i used a rustoleum paint. it is their industrial line. very tough once cured. i have painted wheels with it before and it holds up the best right next to powdercoating! great stuff. i always keep a few cans around, you always need satin black for something.
http://www.rustoleum.com/CBGProduct.asp?pid=95 home depot carries it, but very limited colors.
Old Nov 2, 2012 | 11:05 AM
  #33
shardul's Avatar
Looks killer!
Old Nov 2, 2012 | 06:33 PM
  #34
sl55 amg
Originally Posted by shardul
Looks killer!
thanks shardul. got the parts today too. didn't realize your adapter plate was such an easy bolt on item. i will be done stat!
Old Nov 2, 2012 | 07:00 PM
  #35
kustom2k1's Avatar
03SL55
OZ thanks for the info. I'm going to have to hit up Shardul.
Old Nov 2, 2012 | 10:15 PM
  #36
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
That black blower looks intense
Old Nov 3, 2012 | 12:07 AM
  #37
sl55 amg
i was incorrect! it does not just bolt on. gotta weld it. pics to follow.
Old Nov 3, 2012 | 12:09 AM
  #38
sl55 amg
intensity in ten cities!!
Old Nov 3, 2012 | 12:16 AM
  #39
sl55 amg
welded on the adapter piece. just melted together basically.
how much material comes out for a 74mm to 82mm. big hoss grinder about to do it's thing.
visual of 74mm and 82mm
ground out, sand rolled and blended.
painted and ready to assemble tomorrow. the adapter has 2 holes that were tapped, but other 2 were designed for a bolt to go through it. no prob, tapped the larger hole and drilled out the throttle body holes for a bigger bolt.
now, trying to figure the wiring so i can use the side cap from the mercedes throttle body and be able to use mercedes plug.
Old Nov 3, 2012 | 06:54 AM
  #40
shardul's Avatar
Wow once it is painted you can't even tell if has a welded flange on there.
Old Nov 3, 2012 | 02:02 PM
  #41
sl55 amg
yes, it did blend in pretty well.
engine should be back together today!! still have hoses from trunk tank to do and final wiring of the meth kit.won't have tcu back till probably wednesday, so decided to paint wheel centers while i am at it. doing something outside the box i think. time to look at color charts!!
Old Nov 8, 2012 | 01:51 AM
  #42
sl55 amg
one cool thing about having 2 identical sets of wheels/tires, one black and one silver, is you can swap out combos. think this might be a winning combination! silver and machined centers, black barrels, and black bolts. only painted a few bolts to get a vision of it. will get one set black oxide coated.
previous all silver
my spoiler,..................for my spoiler. it only took 48 hours to start messing up the lower front of the cf spoiler. took some 1/4" thick abs and made a splitter/protector to mount underneath. heated it and bent it to follow the contours on bottom of spoiler too. total cost=zero. already had abs, rivets, and screws.
waiting on parts again to get car wrapped up. just staying busy in the mean time.
Old Nov 8, 2012 | 01:43 PM
  #43
RonnieRenaldi's Avatar
SL55 AMG & BMW F10
OZ, you painted black your TB also?
Any pic installed?
Old Nov 8, 2012 | 04:30 PM
  #44
sl55 amg
I painted Tb alum color. Wanted the contrast. Will get a pic up tonight. The stock intake will not fit anymore though. Waiting on some silicone elbows and see if I can make them work.
Old Nov 9, 2012 | 01:15 AM
  #45
sl55 amg
got elbows today. looks like i can make them work. here is a pic of just the rough fitment. transition will be smooth though and no kinks. to do it, you will have to have 2, 3" 45 degree silicone elbow with atleast 4" legs. there wasn't much to spare at all, just need to cut ends at correct angles. waiting on t-bolt clamps for them now.
couldn't attach pics and photobucket is down right now. pics tomorrow.
Old Nov 9, 2012 | 09:36 PM
  #46
sl55 amg
Old Nov 9, 2012 | 09:47 PM
  #47
kustom2k1's Avatar
03SL55
Hell yes OZ!! You going to run it at the track? How does it run with the 82mm, idle etc.
Old Nov 9, 2012 | 10:22 PM
  #48
sl55 amg
i plan on it! tracks closed till spring i think though.
i have yet to start it. waiting to get everything done first. been a long work week, so still have to run the trunk water lines and finish meth wiring and a few other things.
i did test the tb though, seems to work fine. it does however go to throttle blade wide open when peddle is at about 60%. hahah. should make it exciting! i am having a feeling though that since engine was not running and ecu had no other parameters to go off of, it won't act like that with engine running. will find out.
once it is all together, then can schedule remote tune flash with ec. they said they have maps that will work with my combo. will run the meth kit as safety till i can fine tune with the meth kit later. maybe after adding the nitrous. just got my tcu back from ec, so lots of changes happening in one shot. can't wait to drive it again!!
i am building another car right now, and fabbing a tt kit for it. the car won't be done for a long time as it is literally building a car from almost scratch. i keep eyeing the turbo set up for that, and been having ideas of fabbing for the sl instead. would be one of a kind! 2 ball bearing gt35r's. i think 2 gt30's would fit the sl better though.
Old Nov 9, 2012 | 11:07 PM
  #49
kustom2k1's Avatar
03SL55
Where do you reside OZ? I got to say, you work fast. All that work done in a matter of 2 weeks is impressive considering you have an actual job.
You have to share some more info on the other build, big fan of turbos. I just bought a billet 7168 from precision for my stage 2 GN. I wish we had more room to work with, I would have done a nice single turbo setup on my SL. A 6265 BB would make 650 without breaking a sweat.
Old Nov 10, 2012 | 04:53 AM
  #50
sl55 amg
i live in the suburbs of portland oregon. it has been abit exhausting, but, it would have been finished by now if it wasn't for shipping times. won't have last parts till about wednesday next week. hence, the painting of wheels and other little things while waiting.
i was entertaining a rear mount turbo set up. the area where the mufflers are is huge. you could do a large water to air intercooler in the trunk also. there is always room. lol
my other project is a protouring 67 camaro. doing a tt lsx. viper 6spd, 350z irs, custom built frame, speedtech whole front subframe, and making it a widebody by spacing out all the stock sheetmetal. will look kind of stock, but, 3" wider in rear. running 19x10 and 20x13 adv05.1 one piece. they are the exact wheels that came off of the owner of adv's (jordan) blue z06 vette they used in their very first advertising.
long ways to go on it. only thing stock or untouched will be the roof. floor pan and firewall gone too. so, it is pretty much building a car from scratch. will have abs and traction control also. it will be a top car for sure!!
a couple pics-
so ya, doing some bolt ons and minor fab to the sl isn't too big of a deal compared to this project. lol
glad to see you're interested in the older domestic stuff too. this camaro was actually my first car i got when i was 15. can't ever sell it!
You have already rated this thread Rating: Thread Rating: 22 votes, 5.00 average.
