SL55/63/65/R230 AMG: amok55amg build thread
Looped fuel rail ..... in the process
So; after all that talk ..... felt like going for it and made the looped fuel rail since I have the feeling that a upgrade of the size of the fuel piping from the tank will take care of any gasoline delivery problems but should this turn out to be wrong then it's not a big job to alter this later. https://mbworld.org/forums/sl55-amg-...injectors.html
I decided to make it in stainless steel piping with welded fittings to the exists fuel rail. Also; went over the supercharger instead of down under - easier and also the gasoline is not that near the warm engine. Saved the release valve also on the original fuel rail ......
It will take a little cutting in the engine cover but that will end up ok - will paint it anyway ....... don't get heated with the piping - it's just a dummy for now ......
looks good! that valve is called a schrader valve. it is for diagnostics primarily so you can check actual psi in the rails. i ultimately am going to do a return system on mine so i can tap into the regulator for pressure since my schrader valve is gone.
Painting the engine
So - decided to paint the engine block ... or not?
Not totally sure if I paint the block ..... will have to see when I have blasted it ....... aluminum isn't that bad .... could give it a clear coat instead ..... will be done in a day or two with the blasting ...... hopefully
Pulley bolt
Was getting started on the blasting today ---- will blast the engine so I can get a even and clean surface to paint on
. gotta go the whole way or no way at all
Had to get the bolt out of the pulley mounted on the crankshaft . first off with a electric ½ impact wrench rated for 200 nm. didnt believe it could do it but had to try .. after that unsuccessful attempt I got hold of a Ύ impact wrench air driven .. when holding it . still didnt believe it could do it .. and no! so it was time to bring out the big guns! back to tool man and got hold of a 1 air driven impact wrench (see pic.) holding the wrench, then I had fate but will you believe it . the bloody bolt will not give . hmmm thinking .. seeing the hose from the compressor was two different sizes (in mm.) but something like a Ύ hose and then going down to ½ the last couple of meters . could it be? did the impact wrench not get enough (volume) air? me dragging the engine to the end of the Ύ inch hose (through the gravel not easy with a pallet) . then .. of it went )))) - thinking of the fuel rail too in this situation gotta upgrade the size of that fuel pipe .
Looking at the bolt . only cobber pasta no Loctite and the new bolt has to be fasten with 200 nm. think the AMG man has used a little more than that ........
All in all wouldnt have enjoyed to do this job with the engine in the car . must be a p in the a ..
Blasting info. tomorrow ..
#32
Blown away! almost
This was a god experience but it took longer than I expected
. one and a half day
.. but I had trouble with the air freezing up even I had a water separator connected to the compressor I had water now and then freezing up in the connection and sometimes coming out of the pistol also - again the hose was'nt big enough - not enough voloume of air and on top of that didnt had enough of this Doloblast either(dolomit kind of marble gravel) so I reused some of it. This doloblast comes in different sizes and its supper for aluminum you can blast on rubber sealings etc. whiteout anything happening to them this stuff is great
. just dont use more than 4 BAR working pressure - had I used regular quarts or similar then the engine had been gone
Now I will go and washout doloblast from the ears and a lot of other places where it doesnt belong .
#33
#34
Supertherm painting
So Cal - did manage to paint some parts today painted the engine mounts relays and the transmission
First painted the mounts, and then have to wait an hour for drying up then in the oven for one hour at 160 to 200 degrees C. then cooling off so clear coat and another hour for drying .. then another hour in the oven again at 200 C. Finished and looking good what do you think?
I cannot heat the transmission and the engine up to 160 C. . dont think gaskets and seals and electronic can take the heat so it will just be as it is didnt like the coat on the transmission .. something wrong with the first can and I think I put too much on .
#35
Mercedes Benz Tool
Some of the tools I have made for the work-over ......... don't know the total but just take the tool for changing the rear crankshaft seal - tool A111 589 08 43 00 - cost 4.400SEK ($700)
OK - it's not in harden metal but in hard nylon .... it goes a long way and money saved will be put into upgrades instead
#36
Some progress in the heat
Oil pans and covers cleaned, blasted and painted
. only need to be baked now
.still on my way down to the block
#38
So the heads came off
. 170.000 km. showings its ugly face !
So glad that I decided to go all the way down here …….. what caused this could be many things during the 12 years of “living” but it all comes down to maintains …. gotta make sure this is clean before upgrading ells a lean condition (knocking) would definitely occur and with a high probability cause a pre-ignition with a devastating result … just look of all this “clocking” and residual ……..
Should have been checking this out before ….. I mean - most people go to the dentist to have their teeth cleaned once a year – right?
https://mbworld.org/forums/sl55-amg-...jectors-2.html
#39
.. what caused this could be many things during the 12 years of living but it all comes down to maintains
just look of all this clocking and residual
Should have been checking this out before .. I mean - most people go to the dentist to have their teeth cleaned once a year right?
#40
What I have been able to read is that a product called REDEX has what it takes as a preventive additive and a solution solver when the damage has been done
. can see people has been using this product for decades
. I will try it out
#41
Pandoras box
So this is a never ending story
did a simple water test on the valves and as expected several of them are not holding
have to clean and probably regrind them all
.. but worse is that cyl. 1 +2 is not holding
purred diesel on the top of the pistons and not long after the diesel came out of the bottom of the engine (have not tested cyl. 5-8 but expect the same)
.. so going for new pistons rings and hope that will take care of the issue. Have anybody tried this before? I am not of the opinion I need to go one size up?
This is an engine with 100.000 miles and guess this is normal have to remember its not a normal car which drives in average 40% of its potential . this is a high-end car and have been driven like one .. this takes its toll on the equipment . and I was mocking Ferrari when they overhaul an engine for service .
#43
So the cylinders in the engine is coated with nikasil and as workshop/professional repair people say - there is no need to have them re-bored (http://en.wikipedia.org/wiki/Nikasil)
MB says just to change the piston rings and drive it in ......
#44
More from Pandoras box ....
When I took of the oil pump I discovered the chain for the pump has chewed on the timing chain cover
When I align the chain and the sprockets on the pump and the crankshaft it's clear that it will eat material on the timing chain cover - most probably the sprockets are worn down but on the other hand ... they don't look that worn.... also there were no metal dust on the magnet in oil pan
Any one experience something like this? ... or have any idea where the fault is?
Only good thing here is there cant come more out of the Pandoras Box Im at the bottom .
#46
Prepping cylinders
Prepping the cylinders for the new piston rings
My greetings to Sir-boost-a-Lot https://mbworld.org/forums/w211-amg/...ml#post5754564
#47
Received 1,067 Likes
E55, GLS450, GL63, GLE350
So the cylinders in the engine is coated with nikasil and as workshop/professional repair people say - there is no need to have them re-bored (Nikasil - Wikipedia, the free encyclopedia)
#48
Cleaning of pistons
Hmmmm have new original rings for the pistons
also new crankshaft bearings
and valves and heads are being machined
just one thing remains; the proper cleaning of the pistons from carbon deposit.
Sir-boost a-lot has this to say:
I have talked to two different professional engine workshops (one in Denmark and one in Norway) and Mercedes Benz in Germany and they all say theres no coating on the pistons
If thats the case, then I cannot see anything wrong using a brass broom on a slow drill for cleaning this carbon deposit both on the top and on the side on the pistons
I take that as a compliment since its me whos doing the job
Definitely do not use a wire brush or anything similar on the pistons. Theyve got a special coating to keep from gouging the aluminum walls of the cylinder case and disrupting that coating will certainly light the fuse for another build. Try using heavy solvent like Brake-Kleen or lacquer thinner and get as much of the carbon off as possible.
For the valves, it's ok to use the wire brush or a grey scotch-brite ( not on the stem) since you'll be doing a valve job anyway.
#50
There is also no coating in the bore. It is Alusil. There is a special honing process that brings the silicon molecules out of the aluminum to the surface of the bore. It gives the bores an almost diamond like hardness.
