Macht schnell E55 project
Rating: Thread Rating: 5 votes, 5.00 average.
Old Aug 19, 2013 | 10:08 AM
  #126
Forrest Gump 9's Avatar
shrimp boat
Originally Posted by Sir-Boost-a-Lot
Yes sir! Its Steve's (mindbend) old car from Pennsylvania. We made the trip down the coast last week.. I wish we had more time to take the scenic route.
Aside from being the exact car i was looking for when I bought my E, it already had some of the hardware I have so now theres extra parts to improve upon with
Hit me up if yall ever come to Orlando I'd like to see that car of yours in person
Congrats sir. That's one hell of a car.
Old Aug 19, 2013 | 10:27 AM
  #127
viren.89's Avatar
2004 E55 AMG
Congrats. Enjoy it in good Health.
I saw this for sale and I assume this is the one that already has Weistec Blower on it right?
Old Aug 19, 2013 | 10:28 AM
  #128
berti_00's Avatar
2016 Cls63s AMG
well congrats man, and yah def hit you up when i am up that way.. what are you going to be doing with the new build engine?? put it back on the E?
Old Aug 19, 2013 | 04:20 PM
  #129
MAN55LE's Avatar
04 E55 AMG
Thats awesome, enjoy the car and be safe! What are the plans for your vehicles now?
Old Aug 19, 2013 | 08:20 PM
  #130
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Thank you. I always loved this body style and am exited to get some videos of it racing friends with liter bikes in Mexico.
Thank you! Mental health escaped me quite some time ago, but I masquerade as normal most the time Yes this car has the same blower and headers I have for the engine built for the E.
No suh! The built engine is most definitely going in this CLS along with every CFM that blower can scrounge up!
The E is most likely going to a friend of mine. I wasn't sure what to do with it when a buddy called me wanting me to go and check out a 6 cylinder CTS with him. It turned out to be a s**tbox and I told him he could get my E55 for the price he was going to pay for that junk and he jumped on it. I have another 06E parts car still complete that will donate its stock engine to my old car, as soon as that's done(later this week) I'll have space to move and will start swapping parts on this CLS!
Old Aug 19, 2013 | 08:42 PM
  #131
Nah it doesn't feel much quicker than my stock E55 to be honest. That E is a freak though, it always felt absurdly fast for being stock and hung right along a good friends C6 that runs almost 120 in the 1/4. I know that's not scientific at all, but the SOTP doesn't fail me often. Also the E has no options, and lots of weight saving parts like a light battery, no smog equip, monoblok HREs and light 2 piece Evosport rotors.
I never took the E to the track, but took the CLS last Friday just to see if my suspicions were right , and here are the times it ran
1st run, 1 second burnout to clean the tires, left TCS on
60' 2.02
330 5.391
1/8 8.073
MPH 91.76
1000 10.308
1/4 12.308
MPH 117.27
2nd run, there was a spill that shut the track for nearly 2 hours, so i ran nearly 100lbs of ice through the trunk tank and IC system. Kept circulating until the heat exchanger up front was frosting Stage: quick hop after driving around the water, I tried to feather it with the TCS off, spun my *** off.
60' 2.331
330 5.651
1/8 8.28
MPH 93.76
1000 10.54
1/4 12.43
MPH 119.38
Those would be some great times with a bone stock car, but hilarious for one with a sheet full of mods. It's not as bad as it looks at first though. There's a ton of improvement to be had without changing anything except tires, tune and practice. AFRs were in the low 10s the entire passes, boost a steady 14, and timing around 20'. Its a start!
Originally Posted by urbamworm
Is it fast?
Old Aug 19, 2013 | 09:15 PM
  #132
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
I'm glad someone is getting use out of that CLS. Looking forward to the progress.
Old Aug 19, 2013 | 10:26 PM
  #133
RAWAMG's Avatar
SL55 AMG EC Stage 5 Beast / ESS S/C E92 M3
Old Aug 20, 2013 | 05:18 PM
  #134
amok55amg's Avatar
SL55AMG + SL600 + E320 + A180
Here's my felt cylinder hone rig for the Sunnen honing paste
I originally rigged up a plastic lid to some gelato wrapped in masking tape to slide down to the bottom of the bore, and keep the paste out of the crankcase. However this was only important because I was going to leave the crank in the block and just swap pistons. After the crank was determined to need its counterweights lightened for the new lighter pistons, there wasn't much point since the block was naked now anyways. I tried it on the first hole just for future reference , it worked.
Taping the decks up makes for easier cleanup later.
When crap falls into places you don't want it like an oil galley, here's a cheap tip to retrieve it (from my painting days) roll a small section of tape backwards around a screwdriver and it makes a sort of "magnet on a stick" for things nonferrous.
Thanks a lot for the write-up Sir-boost-a-lot ...... I have followed in your footstep and I only pray it will turn out OK - my own responsibility of curse
You were going for new pistons .... I'm not ... any special trick to know about cleaning them and the valves for carbon deposit ...... an air driven rotating brass brush perhaps?
Old Aug 20, 2013 | 05:59 PM
  #135
Thank you very much, there's much more to come shortly ( I know, I said that a month ago)
Definitely do not use a wire brush or anything similar on the pistons. Theyve got a special coating to keep from gouging the aluminum walls of the cylinder case and disrupting that coating will certainly light the fuse for another build. Try using heavy solvent like Brake-Kleen or lacquer thinner and get as much of the carbon off as possible.
For the valves, it's ok to use the wire brush or a grey scotch-brite ( not on the stem) since you'll be doing a valve job anyway.
Old Aug 20, 2013 | 06:43 PM
  #136
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
60' 2.02
330 5.391
1/8 8.073
MPH 91.76
1000 10.308
1/4 12.308
MPH 117.27
60' 2.331
330 5.651
1/8 8.28
MPH 93.76
1000 10.54
1/4 12.43
MPH 119.38
Wanna' go faster - - - add lightness.
Old Aug 20, 2013 | 08:16 PM
  #137
Ha! Spoken like an ME.
Want lower IAT - - - add cooling
Old Aug 20, 2013 | 09:30 PM
  #138
RedBullJnky's Avatar
you to Hate
60' 2.02
330 5.391
1/8 8.073
MPH 91.76
1000 10.308
1/4 12.308
MPH 117.27
60' 2.331
330 5.651
1/8 8.28
MPH 93.76
1000 10.54
1/4 12.43
MPH 119.38
I haven't seen those times since I was stock on street tires.
Old Aug 21, 2013 | 01:33 PM
  #139
amok55amg's Avatar
Ahha .... I see ... but this coating - is this some kind of "paint" - should have thought it was a special kind of body coating; that being the metal having a special treatment which you cannot remove with brass brush
So; how delicate is these pistons?
This carbon deposit is very sticky and have no intension to go away ....... is it not allowed to touch whit anything what-so-ever? if so; maybe Berryman Chem-Dip Carburetor and Parts Cleaner can do the trick? or the more exotic of ultrasonic cleaning?
Also; congratulation on your new car …. I love the curves of the cls ……. from day one …. MB hit head-on whit these lines and everybody ells followed suit …… the work you did on the M113 engine ? gone with the E-car? …….
Old Aug 29, 2013 | 10:01 PM
  #140
Today she got fitted with some sexy new shoes that shed a ton of weight plus put a nice big traction pad on the ground via Toyo R888 315/30/20 rear tires
Old Aug 30, 2013 | 06:55 AM
  #141
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
More pics of these wheels
plus get the face lift tail lights, they are just
Old Aug 31, 2013 | 05:25 AM
  #142
Kelvin07's Avatar
CLS55 AMG, ML63 AMG, Cayenne S
Awesome, awesome thread, this near uninanimous praise from other knowledgeable members is rare, and your meticulous approach to your build is refreshing and easy to follow.
What sort of cooling mods do you have in store for that sweet CLS?, I am sure a lot of members will follow your lead.
Thanks for sharing Chris!, congrats on the new car!
Old Oct 10, 2013 | 06:59 PM
  #143
MindBend's Avatar
'05 E55
I see you're taking good care of 'er! I am surprised she didn't turn a better 1/4 mile, but that tune is SUPER conservative and the boost is low(er) without the smaller pulley.
Miss that beat a little, however, she's dog-*** slow compared to my new ride!
Kelvin, for cooling mods has all it will ever need: a BIG meth nozzle!
Old Oct 10, 2013 | 07:35 PM
  #144
Those are my favorite wheels right now.
Old Oct 10, 2013 | 11:53 PM
  #145
Thanks! Not so slow anymore but still need much more!
I'm focusing on getting it to look the way I want right now, I got the newer taillights, gonna pull the headlights and black them out and I'm building a new front bumper that'll look a million times better without looking like a "Transformers" mutant like most aftermarket deals.
Old Oct 11, 2013 | 07:35 AM
  #146
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
You mean it will break 120 in the 1/4 now?
Old Oct 11, 2013 | 11:07 AM
  #147
Denroll's Avatar
'06 E55
What is the flow rate and location of your nozzle?
Old Oct 11, 2013 | 07:33 PM
  #148
Pjnash's Avatar
2005 E55
those wheels ...your taste in looks matches your ability to build engines.
Old Oct 11, 2013 | 08:37 PM
  #149
novae500's Avatar
W211
Nice hre rims!!!!
Old Oct 12, 2013 | 08:38 PM
  #150
PS94's Avatar
2004 SL55 AMG Kompressor
What did you ever do about the oil pump chain playing chainsaw with the timing cover?
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
