SL55/63/65/R230 AMG: amok55amg build thread
Old Sep 9, 2013 | 05:52 PM
  #51
amok55amg's Avatar
SL55AMG + SL600 + E320 + A180
yes I do believe you guys …. I see on the side of the pistons an area that’s appear smoother …. pointed that out to all the companies I talked to ….. guess it shows the real value of this forum – thanks a lot
thou ….. the side of the pistons where the rings are placed doesn’t touch the cylinder wall …… only the rings touches ….. (also MB doesn’t renovate engines themselves ……. they sell them ….. ha ha ha )
What will you say for this cleaning procedure? Step one and two only …… http://www.ehow.com/how_8516657_clea...m-pistons.html
Old Sep 9, 2013 | 06:41 PM
  #52
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
It's not just the skirt , the whole piston is coated. And you're right, the ringland areas don't touch the bore( unless you run the mixture really lean and swell the piston material) if they do, you've got bigger problems
I like the carb cleaner solution. Ive used lacquer thinner and mineral spirits with great success also, but carb cleaner will be more aggressive I think. Take a paint brush and cut the length of the bristles in half. This will make them stiffer and more suited to brush away carbon. It won't take much after soaking in carb cleaner!
Good luck with it! I've got extra stock pistons you can have in case you messed some up.
Old Sep 11, 2013 | 05:30 PM
  #53
amok55amg's Avatar
Sir-boost-a-Lot ....
I will start cleaning the pistons next week with the technique you suggest
………. was also thinking of ultrasonic cleaning ….. it can be done …… you can see the picture of aluminum pistons ……..
Thanks for the offer - I could be interested in you pistons … PM ?
Attached Thumbnails amok55amg build thread-ultralydsrensningfoslashrampefter004_zpsc261e012.jpg   amok55amg build thread-ultralydsrensningfoslashrampefter005_zps42620205.jpg
Old Sep 11, 2013 | 07:27 PM
  #54
cal1's Avatar
SL55, ML500 & Acura TL
Wow! what a difference and only sound waves, plus maybe the proper solvent.
Old Sep 14, 2013 | 06:55 AM
  #55
amok55amg's Avatar
It's only water and a little dish soap .............. just not sure if it will take the protective coating also ..... ... but it certainly interesting ..... you can get them in every size and prices are reasonable
Old Jan 17, 2014 | 12:44 PM
  #56
amok55amg's Avatar
Over the top …..
Had now finally cleaned all pistons - cleaned them the hard way – never would have imagined it could be so difficult. Pistons are very delicate and even so you have to take this carbon deposit off them.
Got my heads and valves back from the machine shop – nice job - Having all parts painted – valve covers and other smaller parts I had to repaint - from my first experience with Super Thermo Dupli Color I used clear coat. That didn’t turn out right – it never dried up … also I didn’t like the look so had to blast all items again ….. puhhhh
Attached Thumbnails amok55amg build thread-imgp2932_zps3a6d3417.jpg   amok55amg build thread-imgp2933_zps38180733.jpg   amok55amg build thread-imgp2944_zps5d751ae0.jpg   amok55amg build thread-imgp2951_zps60946b8c.jpg   amok55amg build thread-imgp2956_zpsd11a3f94.jpg
Old Jan 17, 2014 | 02:20 PM
  #57
Ekselent's Avatar
SL600 / SL450 (107) / E350 / BMW M5 E60 / BMW 745i (E23) / BMW X6M / Toyota Hilux 4 WD/ Honda CBX 10
Maybe the car is ready to next warm summer..
Good luck
Old Jan 17, 2014 | 04:51 PM
  #58
I never heard back from ya so I was assuming you got everything ok? Looks good so far, now comes the fun part!
Old Jan 18, 2014 | 05:53 AM
  #59
amok55amg's Avatar
Vulture
Yes the funny parts starts now.
Always looking for stuff on eBay and an engine came up – pulled from a car wreck – lots of good parts on it but have mixed feelings about this since I don’t know what happened to the person driving it … felt like a vulture …… The engine block itself is in good shape – better than my own – it has now been tucked away for another build in the future.
Sir-Boost-a-Lot – am very impressed with your build – especially now where you have gone from alusil to iron sleeves – will that mean you can “save” an engine which alusil bores have been striped with this method? Does it make sense moneywise?
Attached Thumbnails amok55amg build thread-t2ec16dhjike9qu3lq8brm5jobiu60_57_zps08777525.jpg   amok55amg build thread-t2ec16dhjgiffo01oyvjbrm5khsb60_3_zps59dcce6c.jpg   amok55amg build thread-imgp2808_zpse3a98575.jpg   amok55amg build thread-imgp2757_zps125d6200.jpg   amok55amg build thread-imgp2925_zps9de5918b.jpg
Old Jan 21, 2014 | 10:10 AM
  #60
amok55amg's Avatar
Pistons
New parts for the pistons; rings and bearings ….. ………. as said before this cleaning of the pistons had until now been the most time consuming and difficult to figure out. Internet and fellow members help have helped me a long way and finally I got feedback from Mahler …….. but even so I’m not 100% satisfied and have to live with this state. An experience richer.
Attached Thumbnails amok55amg build thread-imgp2981_zps81d4bbad.jpg   amok55amg build thread-imgp2982_zps0c40fc64.jpg   amok55amg build thread-imgp2986_zps4a08fb1f.jpg   amok55amg build thread-imgp2987_zps12294b84.jpg   amok55amg build thread-imgp2991_zpsf4d139d8.jpg
Old Jan 21, 2014 | 10:15 AM
  #61
amok55amg's Avatar
Pistion
.............. more pics.
Attached Thumbnails amok55amg build thread-imgp2997_zpscac09815.jpg   amok55amg build thread-imgp3004_zps5297825c.jpg   amok55amg build thread-imgp3005_zps87c20ee4.jpg   amok55amg build thread-imgp3008_zps0d61b2f2.jpg   amok55amg build thread-imgp3010_zpsa07f99b2.jpg
Old Jan 24, 2014 | 11:21 AM
  #62
amok55amg's Avatar
Pistons in …..
finally I’m getting somewhere …..
Attached Thumbnails amok55amg build thread-imgp3014_zps657e5830.jpg   amok55amg build thread-imgp3022_zpsb9d9082e.jpg   amok55amg build thread-imgp3025_zps0819a4c4.jpg   amok55amg build thread-imgp3029_zpsb8b1cf00.jpg   amok55amg build thread-imgp3034_zpsd55a7ae8.jpg
Old Jan 24, 2014 | 05:01 PM
  #63
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
very nice
Old Jan 25, 2014 | 11:40 AM
  #64
amok55amg's Avatar
Vinter
............. still a long way ............. and winter is here.............. pic. from our E320 ...... frost and after the snow ......
Attached Thumbnails amok55amg build thread-imgp2792_zps22f088c2.jpg   amok55amg build thread-imgp2843_zpsbae3102c.jpg
Old Jan 26, 2014 | 11:42 AM
  #65
amok55amg's Avatar
Chain cover chewing – part 1
My chain cover also have this stupid chewing of the cover from the chain that drives the oil pump. No doubt it’s a design flaw – the tolerance are simply to narrow ……. https://mbworld.org/forums/5750426-post44.html)
I bought a new spring and it’s as strong as the one I took out …. I grinded half of the aluminum tap off to give the chain more room. This aluminum taps purpose is to keep the timing chain in place on the crankshaft gear when you’re working on the timing. I tested it to see if it made any different and all looks good. The timing chain will not lose the grip on the gear.
It will also be possible to have a much stronger spring or another solution will be to enhance the diameter of the gear on the crankshaft and the oil pump …. but both solutions is too complicated and is not worth the effort.
Attached Thumbnails amok55amg build thread-imgp3041_zps277112de.jpg   amok55amg build thread-imgp3043_zpsc1db3579.jpg   amok55amg build thread-imgp3044_zpsfab25b48.jpg   amok55amg build thread-imgp3047_zps57c3dbad.jpg   amok55amg build thread-imgp3048_zps1ac35fa5.jpg
Old Jan 26, 2014 | 05:46 PM
  #66
cal1's Avatar
Looks cold!!!
A winter pick from southeastern Wisconsin. The SL hasn't left the garage since before Thanksgiving. Of course it has been even longer for your R230
Old Jan 28, 2014 | 04:07 PM
  #67
amok55amg's Avatar
Chain cover chewing
Hi ha Curt ….......
you should put a big star on your snow blower ))) ha ha ha … but you don’t have any probs. getting from A to B with that nice ML …….
Now it’s time for the timing chain + cover etc.
Important to be well prepared since this Loctite 5970 only gives you 10 min. working time. Great stuff but very very important that every part is cleaned and free from oil ……… notice the huge numbers of different length on the bolts …. also a few specific bolts need Loctite as well. I have marked the bolt holes with different colors and ditto the bolts – then it’s easy for fast picking the right one.
Attached Thumbnails amok55amg build thread-imgp3064_zps1f5f9f15.jpg   amok55amg build thread-imgp3066_zpsdcbba7d8.jpg   amok55amg build thread-imgp3067_zps5215d8d5.jpg   amok55amg build thread-imgp3068_zps65b13b03.jpg   amok55amg build thread-imgp3069_zps666fa012.jpg
Old Feb 5, 2014 | 04:29 AM
  #68
amok55amg's Avatar
Oil pans
Time for the oil pans – two parts - again using this Loctite 5970 and for degreasing Loctite7063
Attached Thumbnails amok55amg build thread-imgp3072_zps9ec8a3e3.jpg   amok55amg build thread-imgp3073_zpsc654316c.jpg   amok55amg build thread-imgp3076_zps2610ff7a.jpg   amok55amg build thread-imgp3078_zpsc655010c.jpg   amok55amg build thread-imgp3079_zps6a696bc5.jpg
Old Feb 5, 2014 | 12:03 PM
  #69
cal1's Avatar
Hi ha Curt ….......
I have some engine mods in mind first, I will get to the appearance stuff after that.
Your making some nice progress.
Old Feb 12, 2014 | 03:38 AM
  #70
amok55amg's Avatar
Still moving on ……..
Attached Thumbnails amok55amg build thread-imgp3083_zpsc6081aec.jpg   amok55amg build thread-imgp3084_zps5a74f5b3.jpg   amok55amg build thread-imgp3085_zps2b542eae.jpg   amok55amg build thread-imgp3086_zpse9196c66.jpg   amok55amg build thread-imgp3095_zpsc6716cd6.jpg
Old Feb 12, 2014 | 03:51 AM
  #71
cm60k's Avatar
What a great job you do MaaaN....,
that's a FABULOUS coated as well....
ZAYED,,
Old Feb 12, 2014 | 03:58 AM
  #72
amok55amg's Avatar
Heads & valves
As I never have done this before my tool is not the most professional but it gets me there – it just take some more time ….
Attached Thumbnails amok55amg build thread-imgp3087_zps6c0d4797.jpg   amok55amg build thread-imgp3089_zps49f14cd8.jpg   amok55amg build thread-imgp3091_zps77d3f429.jpg   amok55amg build thread-imgp3092_zps8db87aad.jpg   amok55amg build thread-imgp3094_zps08c6a7b7.jpg
Old Feb 12, 2014 | 04:05 AM
  #73
cm60k's Avatar
Agreed,,
Like your prof. project = more time & damn patience.....
ZAYED,,
Old Feb 13, 2014 | 03:49 AM
  #74
amok55amg's Avatar
Sealant on the heads
Yes my friend – patience is the key word here ……
When assembling this engine at the MB factory the whole gasket gets a thin layer of Loctite 5970 but it is not recommended later when doing repairs except if damage of pigging etc. is present – they do however want sealant on the left head in the area of the chaincover as shown ….. even I had my heads machined I did give it sealant …..
Attached Thumbnails amok55amg build thread-imgp3207_zps54019d3b.jpg   amok55amg build thread-imgp3211_zps8d8cdf5b.jpg   amok55amg build thread-imgp3215_zps109affc6.jpg   amok55amg build thread-imgp3216_zpsc5443e2d.jpg   amok55amg build thread-imgp3217_zps9dbd7675.jpg
Old Feb 13, 2014 | 03:55 AM
  #75
Looking good Klaus
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
